Engine bogs at higher RPM - Chevelle Tech
 81Likes
post #1 of 71 (permalink) Old May 31st, 20, 12:20 PM Thread Starter
Hi folks, my 66 El Camino with a near stock 327 high output motor sat for a long time. I started it periodically to keep the battery up and the seals lubed, etc. but hadnít taken it out on the road due to non-op status. I recently switched it to operation status and pulled her out for a drive. She ran great at lower RPMs, right up to about 3500 RPM (no tach so not exactly sure) and then it just kind of bogged, almost like it ran out of gas, but then was fine again at lower RPMS. I drove around a while thinking it was just cold but no, every time I tried to get on it a little, sheíd crap out just as soon as Iíd hit that sweet spot where it would normally scream. Bad gas? Bad fuel pump? Any other ideas?
Many thanks in advance, Rick
Rick-P is offline
post #2 of 71 (permalink) Old May 31st, 20, 1:30 PM
Greg.
Re: Engine bogs at higher RPM
How fresh is the Gas ?
Vapour Lock because of Hot Fuel !
Carb needs some refurbing / Power Valves wore out !
Timing !
blue_69_malibu, rp930 and Rick-P like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 71 (permalink) Old May 31st, 20, 1:33 PM
Is the spark advance working?
Rick-P likes this.
B52bombardier1 is offline
post #4 of 71 (permalink) Old May 31st, 20, 1:38 PM
gary
Did a animal stuff something in the tail pipe?
hydro462, Kirk's67SS and Rick-P like this.
post #5 of 71 (permalink) Old May 31st, 20, 1:42 PM Thread Starter
These all sound like things worth looking into, particularly old gas, maybe itís not volatile enough for the higher power band. Thanks for the tips.
Rick-P is offline
post #6 of 71 (permalink) Old May 31st, 20, 2:11 PM
Terry
Clogged fuel filter. Terry
68-13427 is offline
post #7 of 71 (permalink) Old May 31st, 20, 9:13 PM
TKG
Terry
Same thought, different idea, bad fuel pump
TKG
64 Malibu Coupe
283, Fitech
2004r, 4w discs
TKG is offline
post #8 of 71 (permalink) Old May 31st, 20, 10:11 PM
what Terry said.
Rick-P likes this.
post #9 of 71 (permalink) Old Jun 1st, 20, 7:29 AM
Does it happen in every gear? if it happens worse in the higher gears then it is most likely fuel pump
Rick-P likes this.
moncam is offline
post #10 of 71 (permalink) Old Jun 1st, 20, 8:26 AM
If it is the stock distributor the spring on the points might be weak. In the day that was a problem. I carried preadjusted points in the glove box.
Rick-P likes this.
mrpaticular is offline
post #11 of 71 (permalink) Old Jun 1st, 20, 9:16 AM
This happened to me last summer in my 65 Impala. It was the fuel strainer inside the fuel tank that was clogged and sucked closed.
WHT/73, Kirk's67SS, rp930 and 2 others like this.
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #12 of 71 (permalink) Old Jun 1st, 20, 9:40 AM
I would check all the hoses on the fuel line between the tank and the fuel pump. If they have holes, they will let in air and cause bog... Also make sure the hose between the fuel pump and the tubing that goes to the gas tank isn't kinked. I had all kinds of issues with mine. I finally sleeved a piece of 3/8" tubing with the proper bend inside the 3/8" hose. No issues ever again..
Name:	fuel pump hose 2.JPG
hydro462 is offline
post #13 of 71 (permalink) Old Jun 1st, 20, 11:25 AM Thread Starter
Thank you all for the suggestions, I see there are a couple of common threads here, fuel and distributor, with fuel being the most common. Iíll start with the easiest (fastest) and work my way toward the more complicated repairs if it doesnít clear up.
@moncam , yes, it happens in all gears, and very consistently at that, meaning it happens every single time I get above some RPM. Given the car sat so long, Iím inclined to think bad gas is probably the first place to start, followed by checking the gas filter at the carb, and also replace points and check to make sure the timing advance is working. Fortunately, itís low on gas, so filling up with premium fuel will help determine if that is the cause.
Thanks again everyone! I will report back when I figure it out. I sure hope itís not the strainer in the tank, that doesnít sound fun.
Rick-P is offline
post #14 of 71 (permalink) Old Jun 1st, 20, 12:18 PM
If you're gas is bad, your motor would be running poorly at almost all RPM levels. But I'd burn off as much old gas as possible before filing up.
Start with the easy stuff: fuel filter, fuel line, and then your timing.
Can you quickly/cheaply get a fuel pressure gauge installed between your fuel pump and your carb?
hydro462 and Rick-P like this.
blue_69_malibu is offline
post #15 of 71 (permalink) Old Jun 1st, 20, 12:44 PM
Louis
That bogging is caused a blocked main jet on one of the primary.
67-468, BB68 and Rick-P like this.
Louis
Original owner
lg1969 is offline
