Power Valve Tuning??? - Chevelle Tech
 4Likes
  • 1 Post By malibujason79
  • 1 Post By 427L88
  • 2 Post By 69-CHVL
post #1 of 15 (permalink) Old May 26th, 20, 1:08 PM Thread Starter
Jason
I have a tuning issue with my Holley 750 HP carb and I'm looking for some advice as to how I can resolve the issue. If I'm driving down the road in 4th gear (car is a 4 speed) 45-50 mph, 2200 rpm and I floor it, I get a lean bog that I can't clear up. I've confirmed that this is a lean bog with my LM2 wideband, while I'm cruising*my AFR is at 13.7. The bog or lean spike only lasts for a split second then clears up and my AFR is back on track. I've tried changing to larger squirters, going from one step at a time from 31 to 37 and there is no difference. I've adjusted the accelerator pump arms correctly and have tried different profile cams but still no change. I have disconnected the secondary's to see if the issue is with the primary's or secondary's*and*I'm getting it in the primary's alone.*
I think the issue is with the power valve and would like to confirm before I just throw parts at it. I've read a lot online and found some good posts on here as to how to get the correct power valve for your application. When I went through the carb I installed a 6.5" power valve, it's what came in the kit and the car idles at 11"-12" of vacuum so I figured I was pretty close if you use the divide by 2 method. Further reading, I've seen it referenced that the power valve should be 2" less than your idle vacuum, which would be roughly 9" of vacuum. By changing from a 6.5 to an 8.5 or 9.5 will that help in my bog and allow it to richen up faster? Is there something else I'm missing and should look for?
malibujason79 is offline
post #2 of 15 (permalink) Old May 26th, 20, 1:27 PM
Re: Power Valve Tuning???
What is the engine vacuum at the cruise point, just before you "floor it"?
Dave Ray is offline
post #3 of 15 (permalink) Old May 26th, 20, 1:34 PM Thread Starter
Jason
Forgot to post that, 18"
post #4 of 15 (permalink) Old May 26th, 20, 4:15 PM
Install the highest pv made and drive it.
68 malibu 402 cid w/iron ret ports
[email protected] 1.47 60ft so far
[email protected] 1.452 60ft more to come!
Support our Troops!!!
1968 hot rod is offline
post #5 of 15 (permalink) Old May 26th, 20, 4:18 PM
install a quick opener 105 if you have a lean stumble. ignore all those old wives tales about dividing numbers , all that.
post #6 of 15 (permalink) Old May 26th, 20, 8:35 PM
Kerry
Install a 10.5. The idle vacuum divide by 2 is not correct no matter if you hear it from Holley or not. Idle vacuum in gear and 1-1.5 below that is closer. But half of vacuum at cruise rpm is usually the best.
pockets is offline
post #7 of 15 (permalink) Old May 27th, 20, 8:19 AM Thread Starter
Jason
Thanks for the reply. Is there such thing as a quick opening power valve or do you mean the 10.5 will open much sooner than the current 6.5?
427L88 likes this.
post #8 of 15 (permalink) Old May 27th, 20, 8:22 AM
Sounds like you need more initial advance...
hydro462 is offline
post #9 of 15 (permalink) Old May 27th, 20, 9:13 AM
Jason, the PV numbers equate to their opening vacuum, so a 105 opens at 10.5" Hg, a 095 at 9.5" etc. I run a 095 only because in a 4 gear a 105 MAY dump every time you shift. The 427 required a 085 for this reason, the 600 ft lbs 467 can use more.
i witnessed this as I left my vacuum gauge permanently mounted in the car. Helps for carb tuning. ( and told me when my valves were out of adjustment - much more reliable than my ears)
boyd66k20 likes this.
post #10 of 15 (permalink) Old May 27th, 20, 10:05 AM
When cruising at high vacuum your pbly on the idle / transition circuit a 750 dp usually has a rich circuit
so it may just need a little tuning
but with guage in car when cruising just slowly accelerate when you hit that lean stumble note vacuum go up one pv number til stumble goes away if you have 18 cruise vacuum then as others have said 6.5 might be too low but typically its fine for performance engine. do you a tall rear gear
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #11 of 15 (permalink) Old Jun 6th, 20, 8:33 AM Thread Starter
Jason
Switching out the power valve did make a difference, my local speed shop only had an 8.5" in stock so I went from the 6.5" to the 8.5". The lean spike while at cruise 2500 rpm went from an afr of 18.3 to an afr of 15.9, so I'm heading in the right direction and I can actually feel the difference in the car. I think I will order a 9.5" or a 10.5" and see what difference it makes but I'm glad I'm getting somewhere. I also need to jet the car up a little as she's cruising a little leaner than I like, then I will reconnect the secondaries and tune from there.
ID:	629130   Click image for larger version
post #12 of 15 (permalink) Old Jun 6th, 20, 8:58 AM
Vince
What does your timing set up look like - specifically?
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
*2019 Honda XR650 Dual sport
69-CHVL is online now
post #13 of 15 (permalink) Old Jun 6th, 20, 10:48 AM Thread Starter
Jason
Initial is set to 26-degrees, with a 10-degree bushing my total is 36. Vacuum canister is restricted 10 degrees, so at idle I'm at 36 degrees, initial plus vacuum. I'm all in at 2800-3000 rpm.
post #14 of 15 (permalink) Old Jun 6th, 20, 2:10 PM
Vince
Sounds like you have Plenty of timing which is good. I would suggest bumping up the jetting two sizes front and rear and see what you got.
A note regarding those AFR meters. They are a good tools, but you just have give the engine what it wants and ignore the AFR readings for the time being. You will chase your tail to no end with those things. I should know, I ended up installing EFI because of it LOL!
rp930 and hydro462 like this.
post #15 of 15 (permalink) Old Jun 6th, 20, 6:20 PM
Stewart Warner Motor Minder
Like Gene said a vac gauge inside is a plus.
https://www.summitracing.com/parts/sww-82175
USN-SSBN 645-G
boyd66k20 is offline
