BBC Production Block/Heads Dyno Test - Chevelle Tech
 49Likes
post #1 of 27 (permalink) Old May 21st, 20, 10:12 PM Thread Starter
MARK
A while back I built a 4.310 X 4.250 496 for a customers street driver/race in his 70 Camaro. 10.15 compression, I was looking for 10.4 but didn't want to cut the 781 heads any more than to surface and set the CCs. A Edelbrock Perfprmer RPM was used with a 850 Holley and a 1 inch open spacer. My cam was a .650 lift solid roller, 255 @ .050, 110 LS. I used a 445 4 bolt block, with the customer ordered Molnar crank and "power adder rods" bob weight was 2128. We did quite a bit of work to the crank. I used a Moroso oil pan with modifications. Other parts included: Mahle pistons, M77 oil pump, Scorpion rockers, .083 wall moly pushrods, Ferrea valves, Comp cams springs, Comp retainers, Comp inside locators, Comp roto coil eliminators, blue viton valve seals, Rollmaster timing chain, FelPro 1037 tight head gaskets, Mr gasket 5827 intake gaskets, Morel lifters. I tested it on 91 octane pump gas and 10/30 conventional Maxima oil. I wish I would have had some Q16 and LAT oil, probably worth 25 HP more.
Some pictures
ID:	627564   Click image for larger version
ID:	627566   Click image for larger version
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #2 of 27 (permalink) Old May 22nd, 20, 12:29 AM
Re: BBC Production Block/Heads Dyno Test
Go ahead, keep us in suspense. Lol
66rat likes this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is offline
post #3 of 27 (permalink) Old May 22nd, 20, 2:40 AM
mmmm..... I'm gonna say 700hp/675tq
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is online now
post #4 of 27 (permalink) Old May 22nd, 20, 3:21 AM
Marcus
I think 735hp/705tq.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #5 of 27 (permalink) Old May 22nd, 20, 9:02 AM Thread Starter
MARK
Marcus
I appreciate your confidence but lets not get unrealistic, numbers actually mean something. Heres the data:
Red Line Camshaft
post #6 of 27 (permalink) Old May 22nd, 20, 9:46 AM
679 lb.ft. @ 4800 and it's already on the downside of peak tq.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Check out
on Facebook
Vintage Musclecar is offline
post #7 of 27 (permalink) Old May 22nd, 20, 10:33 AM
Very nice Mark!!!
Chris Straub
Mfg Performance Parts
cstraub is offline
post #8 of 27 (permalink) Old May 22nd, 20, 10:33 AM
Marcus
Originally Posted by VORTECPRO View Post
Marcus
Kevins guess was spot on!
Anyway outstanding nrs
post #9 of 27 (permalink) Old May 22nd, 20, 10:43 AM
Very impressive, Mark....yet again.
And thanks for sharing. Just in time for a bizarre holiday weekend.
Stay safe everyone....and enjoy Mark's build.
blue_69_malibu is offline
post #10 of 27 (permalink) Old May 22nd, 20, 11:57 AM
single pattern cam?
sleeper is offline
post #11 of 27 (permalink) Old May 22nd, 20, 12:20 PM
Originally Posted by 65cayne View Post
[IMG class=inlineimg]/forums/images/Chevelles_2016/smilies/tango_face_glasses.png[/IMG] mmmm..... I'm gonna say 700hp/675tq
Marcus
I appreciate your confidence<img src="https://www.chevelles.com/forums/images/smilies/thumbsup.gif" border="0" alt="" title="Thumbsup" class="inlineimg" /> but lets not get unrealistic, numbers actually mean something. Heres the data:
I was so close! Very nice build!
-Kevin
1965 Chevy Biscayne
post #12 of 27 (permalink) Old May 22nd, 20, 12:50 PM
Nice! How much are the collectors you have on there worth over the mufflers I usually see?
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #13 of 27 (permalink) Old May 22nd, 20, 12:53 PM
I'm surprised by the torque of that thing. It is incredible for a 10.2 to 1 small cam'd engine. Excellent work.
Pat_McNeil and blue_69_malibu like this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
post #14 of 27 (permalink) Old May 22nd, 20, 1:00 PM
Needs a tunnel ram dammit!!!
68 malibu 402 cid w/iron ret ports
[email protected] 1.47 60ft so far
[email protected] 1.452 60ft more to come!
Support our Troops!!!
1968 hot rod is offline
post #15 of 27 (permalink) Old May 22nd, 20, 1:08 PM
Kerry
Awesome job Mark!
pockets is offline
