Backyard 460 BBC build - Page 2 - Chevelle Tech
 49Likes
post #16 of 51 (permalink) Old Apr 23rd, 20, 12:39 AM Thread Starter
Marcus
Re: Backyard 460 BBC build
Originally Posted by rp930 View Post
Not sure why youre having trouble with the Torrington bearing and clearance. Mine bolted right up. Maybe someone else has some input.
The center hole in the lockplate is little small.
If you look at my pictures you can see what I mean, the plate rides on the three tabs instead of the bearing. Heard its not uncommon that you need to correct this sometimes.
rp930 and Harms_Way like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #17 of 51 (permalink) Old Apr 23rd, 20, 12:41 AM Thread Starter
Marcus
Originally Posted by -SS454- View Post
Looks like you are doing an excellent job and a very clean area.
Thanks! Yes try to keep it clean when I put something like this together.
post #18 of 51 (permalink) Old Apr 23rd, 20, 12:49 AM Thread Starter
Marcus
Originally Posted by 65cayne View Post
What are you setting your CR at and do you plan to dyno it?
Great combo. Looking forward to following along!
Think I will end up at 10:1 exact, want it to safely run on 91 octane since you never know how long 93 octane will be avaible........
Not sure it will be dynoed, have thought about it though.
post #19 of 51 (permalink) Old Apr 23rd, 20, 12:50 AM Thread Starter
Marcus
Originally Posted by bracketchev1221 View Post
I'm sure it will be a good running engine. Good Luck.
Thanks!
post #20 of 51 (permalink) Old Apr 23rd, 20, 1:47 AM
Jesse
Are you going to drill the deck for the extra cooling holes? Should be a fun engine.
Malibu ss 64 and rp930 like this.
Jesse
6426yy is offline
post #21 of 51 (permalink) Old Apr 23rd, 20, 3:15 AM Thread Starter
Marcus
Nope, thought about it but have never drilled them before when they are missing and never noticed any problems with correct head gaskets. Maybe stupid not doing it but will try my luck again. Going with 1027 felpro gaskets.
Rmchevelle and shovelrick like this.
post #22 of 51 (permalink) Old Apr 23rd, 20, 8:01 AM
rick
That sounds like a very nice build Marcus, I also used the felpro 1027 gaskets for my race rites, did you look in to Autotec/Racetec pistons?
Malibu ss 64 likes this.
shovelrick is offline
post #23 of 51 (permalink) Old Apr 23rd, 20, 8:49 AM Thread Starter
Marcus
I think I looked into every non custom brand avaible, bought this set local for a price I couldnt resist or come close to buying from Us.
shovelrick likes this.
post #24 of 51 (permalink) Old Apr 23rd, 20, 1:55 PM
Rod
Love that bare, natural cast iron, freshly machined block. Plenty of us are using SRP pistons just fine.
Rmchevelle is offline
post #25 of 51 (permalink) Old Apr 23rd, 20, 3:09 PM
Gary
Sounds like a really good combination I don't know that I would change anything
gnicholson is online now
post #26 of 51 (permalink) Old Apr 23rd, 20, 4:52 PM
I drilled mine. I think it helped cooling. Its easy to do and I dont think theres a downside.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.10 12 bolt posi
rp930 is offline
post #27 of 51 (permalink) Old Apr 24th, 20, 8:34 AM Thread Starter
Marcus
Started to mock some parts up.
Oil pump to pan 1/4 without gasket going to clay it later and have two spots of tig weld added.
Deburred oil holes in rods and removed all sharp edges on piston valve reliefs and domes.
Washed with water and soap.
Mounted pistons to rods.
ID:	624188   Click image for larger version
ID:	624190   Click image for larger version
ID:	624192   Click image for larger version
post #28 of 51 (permalink) Old Apr 24th, 20, 8:37 AM Thread Starter
Marcus
All pistons mounted to the rods.
Test fitted the cam.
ID:	624198   Click image for larger version
ID:	624200   Click image for larger version
ID:	624202   Click image for larger version
post #29 of 51 (permalink) Old Apr 24th, 20, 8:47 AM Thread Starter
Marcus
Cam is in and spins nice.
Mounted the cvr oil filter adapter.
Took my dremel and made a chamfer in the cam thrust plate so it cleares the tabs in the torrington bearing, will check so the thrust centers and still cleares the tabs when I degrees tha cam.
Next step is to check main clearances and crank endplay.
Hope I have time tomorrow to continue.
ID:	624210   Click image for larger version
ID:	624212   Click image for larger version
ID:	624216   Click image for larger version
Wolfplace likes this.
post #30 of 51 (permalink) Old Apr 24th, 20, 8:59 AM
Rob
Looks like a nice combo in the works. A little off topic, but I'm curious what a gallon (liter) of premium gas cost over there in Sweden?
66rat is offline
