467 Oval Port Build - Chevelle Tech
 182Likes
post #1 of 96 (permalink) Old Apr 12th, 20, 12:56 PM Thread Starter
MARK
467 Oval Port Build
I built this 467 4.310 X 4.00, 959 production block, I used a 28 cc Mahle piston, we had to cut the dome down to get to 9.8-9.9 compression, I ended up setting the 781 heads to 116 CC, unusually small, the heads were ported and 2.190/1.880 valves were installed. I used a RPM air gap with some work, along with a 850 DP with a 1 inch open spacer. The cam was a hyd roller 228/238/.553/.578/111/107, rockers were Scorpion, along with .083 wall moly pushrods/comp 3/8 guide plates. Arp rocker studs. A M77 oil pump with Maxima 10/40 conventional oil, factory type Chevelle oil pan with modification were done. Hopefully this will have good vacuum with a nice power curve. Dyno testing in the near future. BTW RS the bob weight was 2300 grams.
Machined GM production heads
Oil pan modifications
Red Line Camshaft
VORTECPRO is offline
post #2 of 96 (permalink) Old Apr 12th, 20, 1:02 PM
Re: 467 Oval Port Build
Can't wait to see what this puts out.
rjt427 is offline
post #3 of 96 (permalink) Old Apr 12th, 20, 1:18 PM
Vince
How come no dart block
*69 SS 502 EFI /224-228* HR/9.8:1/T56/3.90/ 4000lbs RW 11.5/124mph -with a "top fuel" timing curve
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
*2019 Honda XR650 Dual sport
69-CHVL is offline
post #4 of 96 (permalink) Old Apr 12th, 20, 1:36 PM
Jesse
How's your son's 302 coming?
Jesse
6426yy is offline
post #5 of 96 (permalink) Old Apr 12th, 20, 4:06 PM
Send a message via AIM to dragginwagon406 Send a message via MSN to dragginwagon406 Send a message via Yahoo to dragginwagon406
Eager to see how this cam does in this engine. The cam is much “smaller” than your Isky solid FT cam.
1981 Malibu wagon
406/350/4.10
Best ET NA 12.20 @ 110
Best ET w/N2O 11.47 @ 117
dragginwagon406 is online now
post #6 of 96 (permalink) Old Apr 12th, 20, 9:06 PM Thread Starter
MARK
He's has the short block done, and he's working on the heads.
ID:	622754   Click image for larger version
ACES1, 77 cruiser, 66rat and 12 others like this.
Red Line Camshaft
post #7 of 96 (permalink) Old Apr 12th, 20, 9:15 PM Thread Starter
MARK
Some pictures of the 467
ID:	622758   Click image for larger version
ACES1, Pat_McNeil, rjt427 and 2 others like this.
Red Line Camshaft
post #8 of 96 (permalink) Old Apr 12th, 20, 9:47 PM
He'll be teaching auto shop by the time he graduates high school.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is online now
post #9 of 96 (permalink) Old Apr 12th, 20, 11:29 PM
I trust he realizes how incredibly lucky he is to have such a wealth of knowledge at his fingertips?
I had the pleasure of working with my Dad for a couple years outside of high school, those years were very important for teaching work ethic and respect. It’s good to have a good mentor.
DUKE 69, ACES1, Pat_McNeil and 4 others like this.
1981 Malibu wagon
406/350/4.10
post #10 of 96 (permalink) Old Apr 13th, 20, 12:19 AM
Sorry, but I don't get it. Isn't this the same engine posted in the past, multiple times? ie: ported heads, 228/238 cam, Mahle pistons, RPM intake. What's different?
beatnik is offline
post #11 of 96 (permalink) Old Apr 13th, 20, 12:31 AM
If this doesn't interest you or entertain you, please move on. There's nothing left for you to see.
Yes - we have an idea as to what range the dyno numbers will come in around...for the most part.
But that doesn't make it any less fun or interesting to follow along, IMHO.
We have a top-notch engine builder and machinist taking us along on a ride.
I'm on board.
blue_69_malibu is offline
post #12 of 96 (permalink) Old Apr 13th, 20, 1:37 AM
You don't like my question then YOU move on! I asked a simple, legit question of the op, NOT YOU!!!
The op likes to experiment. What's different?
beatnik is offline
post #13 of 96 (permalink) Old Apr 13th, 20, 7:00 AM
I'm on board.
Fair question IMO. I didn't take anything negative at all from it and am genuinely curioue myself. It is all part of "following along" no? On that note, was curious about the significance of the bob weight not knowing what constitutes light/heavy in that regard.
-Kevin
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is offline
post #14 of 96 (permalink) Old Apr 13th, 20, 8:11 AM Thread Starter
MARK
Yes.....your right, really is the same, except it has a flywheel this time during testing, but Gene's did too. Maybe the only thing here to see is how close the power the power will be to the others?
rjt427, bradley67 and TTA1326 like this.
Red Line Camshaft
post #15 of 96 (permalink) Old Apr 13th, 20, 8:22 AM Thread Starter
MARK
-Kevin
I used late 80s rods in this build which are a few grams heavier than the old thumb rods, but the newer rods are much more consistent, so I like use them when possible. So the bob weight is maybe 12 grams heavier than it could be, but close to average for this combination.
427L88, rjt427 and Kirk's67SS like this.
Red Line Camshaft
