A/F gauge reading incorrectly? - Chevelle Tech
 11Likes
post #1 of 57 (permalink) Old Apr 6th, 20, 3:05 PM Thread Starter
Hey All,
I have the basic VortecPro 467 in my 68 El Camino. Holley SA 770 carburetor. TH400 and 3.00 rear gears.
I added an Innovate Technologies AF gauge and a vacuum gauge to assist with carburetor tuning. I know that different engine combinations want different AF ratios, but after lots of tuning I think my AF gauge is reading incorrectly. Cruise is constantly reading in the mid-12s and occasionally in the mid-11s. My timing is good with about 18 initial and 35 total. Ive played with vacuum advance and have run as much as 10 in addition to the mechanical.
My spark plugs look good. I tried re-jetting the carburetor fo bring my AF reading up to at least the mid-13s but the car ran poorly. I finally took a half day to swap jets for best cruise vacuum. I ended up with the best readings with the stock jetting. My best overall performance is with the carburetor being at stock jetting but with a slightly larger accelerator pump squirter.
So with all of that, the car runs great with no smoke or the slightest amount of exhaust discoloration, but reads mid-11s to mid-12s on the gauge. Does this sound odd to the rest of you?
Thanks for any help,
Tom.
any4xx is offline
post #2 of 57 (permalink) Old Apr 6th, 20, 3:24 PM
OLIVER
Re: A/F gauge reading incorrectly?
I had a AF gauge go funny all of a sudden , I knew my tune was on point , then I found that the Bosch sensor went bad , changed the sensor and all good again.
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is online now
post #3 of 57 (permalink) Old Apr 6th, 20, 3:42 PM Thread Starter
Makes me wonder even more. This does use the Bosch wideband sensor. It has read in this same range ever since I installed it. Do these readings also seem off to you? Id think that if I were truly running that rich Id have symptoms.
any4xx is offline
post #4 of 57 (permalink) Old Apr 6th, 20, 3:53 PM
My innovate required a "free air calibration" before use. Did you perform any required calibration before installing it? If not, start there. Grounding is very important, make sure you followed the recommended grounding scheme.
Scott65 is offline
post #5 of 57 (permalink) Old Apr 6th, 20, 7:40 PM
Not hi tech But pull Sensor out to see what it looks like cruise at 11-12 is way rich See if sensor is real sooty after a long cruise
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #6 of 57 (permalink) Old Apr 6th, 20, 7:46 PM
if you have ran any race fuel with lead in it they dont like that either.
Mike 70SS is offline
post #7 of 57 (permalink) Old Apr 6th, 20, 8:50 PM
There's calibration you can try.
https://www.innovatemotorsports.com/...rint%201.2.pdf
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #8 of 57 (permalink) Old Apr 7th, 20, 11:30 AM Thread Starter
Ive done it twice. Once upon initial install and again after a few months of use. No change in the average readings.
What does your gauge tell you when youre cruising down the road?
any4xx is offline
post #9 of 57 (permalink) Old Apr 7th, 20, 11:31 AM Thread Starter
Thats the thing: No soot or smoke anywhere. Tailpipes and spark plugs are clean.
any4xx is offline
post #10 of 57 (permalink) Old Apr 7th, 20, 11:32 AM Thread Starter
Nope. Just 91 octane pump gas since I got the car.
any4xx is offline
post #11 of 57 (permalink) Old Apr 7th, 20, 11:37 AM Thread Starter
Originally Posted by 77 cruiser View Post
Yeah... Ive calibrated twice. My gut feeling is that the gauge is not, and has never been reading correctly. Its hard to imagine cruising around 12:1 without rich symptoms. Occasionally on a cold start with no choke it will read in the 15 range. That often gives me hope that it is reading correctly, but it quickly settles into that mid-12 range soon enough.
And just to clarify, my exhaust system is tight. The sensor is mounted about 15 up from horizontal about 6 past the header collector.
any4xx is offline
post #12 of 57 (permalink) Old Apr 7th, 20, 11:49 AM
I thought I'd throw it out there just in case you hadn't.
77 Monte
post #13 of 57 (permalink) Old Apr 7th, 20, 12:05 PM Thread Starter
Believe me; I appreciate ANY suggestions. I wish there was a way to double-check these things. I think my only hope is to suck it up and buy another one, probably from a different manufacturer, and replace it to see how it reads. Or just remove it and be happy with my old-school tuning methods. It drives me crazy that this car seems to be running great but the fancy electronic gizmo is telling me something else.
any4xx is offline
post #14 of 57 (permalink) Old Apr 7th, 20, 12:26 PM
OLIVER
does it move around, when you step on the gas ? or let off the gas ?
if it keeps reading rich all the time no matter what I would think the sensor went bad , this is what happened to me ... just kept reading rich all the time regardless
you can replace the sensor ,I believe 50 $ or so
Oliver
Milano , ITALY
M20 4 speed - 3.31
Prosystems 1000
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
post #15 of 57 (permalink) Old Apr 7th, 20, 12:29 PM
Oliver, good to hear from you.
oliver69 likes this.
mrpaticular is offline
