Best closed chamber street head - Chevelle Tech
 5Likes
post #1 of 18 (permalink) Old Apr 6th, 20, 9:36 AM Thread Starter
Is there anything in the aftermarket other than Edelbrock offering a closed chamber aluminum head for stock stroke 454?
Tonys451 is offline
post #2 of 18 (permalink) Old Apr 6th, 20, 11:01 AM
Greg
Re: Best closed chamber street head
I don't know of anyone else- but, I do know that if you order Brodix from a good dealer they can get the chambers milled down a good bit. Don't remember how much or how small most of them will go, but it is significant.
I'm sure AFR and others can do it also- I'd call Wolfplace, Vortecpro, or someone very familiar with BBCs and check to see what they can get. I'd bet Straub could even fix you up with some Promaxx with a smaller chamber.
Greg C.
1969 Chevelle Malibu
New, mildy overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #3 of 18 (permalink) Old Apr 6th, 20, 11:06 AM Thread Starter
Thanks for the info
Tonys451 is offline
post #4 of 18 (permalink) Old Apr 6th, 20, 11:50 AM
Gary
Like said brodix can mill the chambers to 100 cc if I remember correctly. If it's a mild build the l29 chevy heads are a good choice
gnicholson is offline
post #5 of 18 (permalink) Old Apr 6th, 20, 12:05 PM
Marcus
Call Mike Lewis he can get You a set of brodix with 100cc Im sure or afr in the very low 100s
Personally I would go with brodix.
shovelrick likes this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #6 of 18 (permalink) Old Apr 6th, 20, 12:22 PM
I have a pair of edelbrock rovals on my 500 incher. They came in @ 108cc after work was done. They push my 10.7 to 1 turd down the 1/8th fairly well.
No head (or intake) out of the box would be optimal.
'66 SS Chevelle
91 octane special
first day out
[email protected]
Stokerboats is online now
post #7 of 18 (permalink) Old Apr 6th, 20, 12:58 PM
The ZZ502 heads with 110 cc chambers can be had cheap used if you are patient.I bought a ready to run pair for $900 for my next project.
mr 4 speed is offline
post #8 of 18 (permalink) Old Apr 6th, 20, 6:36 PM
BTW, the Edelbrocks aren't really a true "closed" chamber head. They like their own piston dome.
shovelrick and rp930 like this.
'66 SS Chevelle
91 octane special
first day out
[email protected]
post #9 of 18 (permalink) Old Apr 6th, 20, 6:41 PM
Do you think they would be an improvement over 840s with 2.25 intakes/1.88 exh?
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #10 of 18 (permalink) Old Apr 7th, 20, 8:02 AM
all depends on the flow numbers.
post #11 of 18 (permalink) Old Apr 7th, 20, 8:11 AM
Vince
For a street 454 the Eddy head works really well - very underrated head especially for the price.
badrad likes this.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is online now
post #12 of 18 (permalink) Old Apr 7th, 20, 8:33 AM Thread Starter
Thanks everyone. I already have a set of vortec heads with mild bowl work. They are brand new and got them ready to bolt on a .060 over 1970 block w speed pro flat tops. Probably more than enough for my intent, but it’s looking like this project is going to be on hold for a while.. so my mind is wandering . Good to know what options are out there. Still learning
Tonys451 is offline
post #13 of 18 (permalink) Old Apr 7th, 20, 10:46 AM
have you cc'd them?
post #14 of 18 (permalink) Old Apr 7th, 20, 11:05 AM
yes, the Eddy/GMPP oval port small chamber heads are great. As mentioned, they can be found used for under $1k.
blue_69_malibu likes this.
post #15 of 18 (permalink) Old Apr 7th, 20, 11:11 AM
rick
I'd check local speed (if you have any) shops that do machine work or other auto machine shops, sometimes people take them in for repairs and don't come back or upgrade and trade them in, place in Tampa had some used BBC alum heads, Speed World
shovelrick is offline
