Oil Centistoke Chart - Chevelle Tech
 5Likes
  • 1 Post By pockets
  • 2 Post By pockets
  • 2 Post By cstraub
post #1 of 14 (permalink) Old Apr 5th, 20, 1:22 AM Thread Starter
Kerry
I have been trying to find the oil centistoke chart Chris posted a while back. I cannot.
Did anyone save it as a PDF?
427L88 likes this.
pockets is offline
post #2 of 14 (permalink) Old Apr 5th, 20, 8:15 AM
Re: Oil Centistoke Chart
No but our roller lifters might enjoy it. I do recall the VR-1 dino I am running now isn't ideal, but OK. May switch to synth after engine has run on dino for one change. The chart would be helpful.
post #3 of 14 (permalink) Old Apr 5th, 20, 9:39 PM
Ive got it in a pdf format
BTW Gene the VR1 centistroke for 10/30 is same for syn / dino 11.5
Mobil 1 syn 10/30 has the lowest centistroke 10.2
Tremec by Liberty[/FONT]
Foxwell 475 BBC 688hp /610 tq
Crusin / Track video
CDN SS is offline
post #4 of 14 (permalink) Old Apr 5th, 20, 9:41 PM
Ooops sori not in PDF in an XL spreadsheet I can text or email
CDN SS is offline
post #5 of 14 (permalink) Old Apr 6th, 20, 2:01 AM Thread Starter
Kerry
Email please. I’ll PM you.
pockets is offline
post #6 of 14 (permalink) Old Apr 6th, 20, 9:24 AM
Kerry , could you convert the .xml to a .jpeg and post it?
post #7 of 14 (permalink) Old Apr 7th, 20, 5:09 PM Thread Starter
Kerry
Here it is as a PDF.
shovelrick and bradley67 like this.
pockets is offline
post #8 of 14 (permalink) Old Apr 8th, 20, 12:02 PM
Andy
Can someone help educate me?
What is centistoke, and what is good/Bad?
Andy
1969 GTO 433" BBC 990 Rec Heads, Richmond 5spd, 12 Bolt Moser, Straub Hyd Roller - 440 HP at the wheels
1976 Vega 8/71 408" BBC 675HP , TCI 350 9 inch - Comp Cams Hyd Roller, 14 Pt cage, Fiberglass Frnt end
Ialone is offline
post #9 of 14 (permalink) Old Apr 8th, 20, 12:40 PM
Inch = measurement of length
Centistoke = measurement of flow at temp
All hyd roller lifter function best with an oil that is lower than 15 at 100C in temp.
427L88 and Ialone like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #10 of 14 (permalink) Old Apr 8th, 20, 12:52 PM
Andy
Thank you Chris- Good info. I use Mobile 1 Syn 5-30 looks like i'd be ok with 10-30 as well?
Andy
Ialone is offline
post #11 of 14 (permalink) Old Apr 8th, 20, 1:12 PM Thread Starter
Kerry
Chris, do you have that chart? I thought it had more oils than this listed.
pockets is offline
post #12 of 14 (permalink) Old Apr 8th, 20, 1:46 PM
It does, not sure you did not see it
there was Motul and Castrol on it. Its Chris’s list unless he has a new one Id like to see Driven DT 40 centistroke numbers
CDN SS is offline
post #13 of 14 (permalink) Old Apr 8th, 20, 2:23 PM
THNX Kerry, its a start! Still thinking on the MOB1 10-30 synth after the MJ bullet gets a thousand or so miles on it.
post #14 of 14 (permalink) Old Apr 8th, 20, 2:48 PM
Hey Gene did you Read my message to you on Facebook MessenGer ??
BTW “ If” You have noisy hyd lifters those who chose to use Mobil 1 syn 10/30 it seems to quiet them the most especially if you have the pro morels that have tight internal clearances im using Driven DT 40. 10/40 Its good but gonna try VR1 syn 10/30 next to see if its gets quieter
CDN SS is offline
