My attempt at following Vortec Pro head porting - Chevelle Tech
 53Likes
post #1 of 80 (permalink) Old Apr 3rd, 20, 9:31 PM Thread Starter
Send a message via AIM to dragginwagon406 Send a message via MSN to dragginwagon406 Send a message via Yahoo to dragginwagon406
Mark is a pretty good teacher...I just need to be a better student.
A little more work around the guides, open up the long good port, add the 30 degree back cut on the valves, and one more test and I think I’ll be there. 300+
My numbers are deceiving due to 4.5” bore, but my machinist doesn’t have a 4.310” bore which is notched for the valves. With my chamber deshrouding, a small fixture doesn’t work well.
Anyhow, a few photos.
ID:	621662   Click image for larger version
ID:	621664   Click image for larger version
ID:	621666   Click image for larger version
ID:	621670   Click image for larger version
ID:	621672   Click image for larger version
1981 Malibu wagon
406/350/4.10
Best ET NA 12.20 @ 110
Best ET w/N2O 11.47 @ 117
dragginwagon406 is online now
post #2 of 80 (permalink) Old Apr 3rd, 20, 9:46 PM
Rod
Re: My attempt at following Vortec Pro head porting
Nice job. Can you show pics of tools you're using?
Rmchevelle is offline
post #3 of 80 (permalink) Old Apr 3rd, 20, 10:54 PM Thread Starter
Five things really,
Harbor Freight electric die grinder with 6” double cut burr (the burr is not from HF)
Magnetic LED light (very, very important to see)
6” spring inside caliper, also HF, used more for comparing than actually transferring measurements
Straight edge for the chamber mod
iPhone, Mark’ videos, and a Google Sheet and slide instruction I made from his videos.
As well, I’d say half the battle was finding a machinist who would take care of the guides correctly, de shroud the valves in the chamber, and cut the valve angles and widths Mark instructed. 30, 45, 60, 75. The width of the 60 is important, and then only open up to 86-87%. Some open theirs up more, but you can’t put metal back in.
On the exhaust, the width of the 45 is important.
Another video which is very helpful is the one from David Vizzard when he was much younger and talking about mini cylinder head valve angles and porting.
Bob Tiley and Rmchevelle like this.
1981 Malibu wagon
406/350/4.10
post #4 of 80 (permalink) Old Apr 4th, 20, 3:55 AM
Nice work..
_
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming: "WOW! WHAT A RIDE!!"
Redmanf1 is offline
post #5 of 80 (permalink) Old Apr 4th, 20, 4:51 AM
very good. For the slow learners among u, what are abbreviations referred to? VTP, MR?
post #6 of 80 (permalink) Old Apr 4th, 20, 7:50 AM Thread Starter
VTP - Vortec Pro (Stock and ported) flow from his 620 hp videos
MR - my initials (big valves cut in, no clean up and lastly first attempt, ported) red and yellow
1981 Malibu wagon
406/350/4.10
post #7 of 80 (permalink) Old Apr 4th, 20, 8:16 AM
Lew
Pretty good there.
dragginwagon406 likes this.
Lew540 is offline
post #8 of 80 (permalink) Old Apr 4th, 20, 9:02 AM Thread Starter
I should mention, this is without gasket matching whatsoever.
Going to work on the first head a little more today, gasket match, attempt to enlarge the long good port a little more the entire length and open on the sides of the guides further (I didn’t get near 0.075”/0.070” per side on the first attempt).
On the bad port, I’ll gasket match, try to straighten the curve a little more, open up near the guide a little further, and widen and flatten the short turn further.
I’m thinking I left a little too much in the venturi humps in the bowl as well, so I’ll look to take just a bit out of them too.
On the exhaust, round the ledges better and clean up more.
All very minor changes.
Rmchevelle likes this.
1981 Malibu wagon
406/350/4.10
post #9 of 80 (permalink) Old Apr 4th, 20, 4:56 PM Thread Starter
The exhaust
ID:	621720   Click image for larger version
ID:	621722   Click image for larger version
ID:	621724   Click image for larger version
1981 Malibu wagon
406/350/4.10
post #10 of 80 (permalink) Old Apr 4th, 20, 11:26 PM Thread Starter
After roughing in the gasket match for the intake ports, I believe I found the choke points for both ports. Using the 6” spring inside caliper, I started from the intake face and checked the “fit and taper” from the intake port to the valve seat. It becomes readily apparent that the pushrod pinch is a bad choke point, in the good port worse than the bad port.
After reducing this pinch as much as I thought safe, I moved down toward the valve seat. The short port, opens up naturally like a cave, in other words it’s too big already.
The long good port tapers vertically on the way toward the valve seat, but opens up slightly horizontally after the pushrod pinch. In the end, it seemed obvious the verticals needed opened up a little further to move the “pinch” toward valve seat.
I think I’m ready for the next test, hopefully I’ll see more than 300 next time and pickup the low and mid lift flows.
A couple photos of the short turn on the bad hook port.
ID:	621766   Click image for larger version
1981 Malibu wagon
406/350/4.10
post #11 of 80 (permalink) Old Apr 5th, 20, 4:55 AM
Thanks for posting this Mike. Very interesting (graphs and photos) and significant improvment with what you've done so far! Do you have access to a flow bench (i.e. "free") or are you paying each time? Curious what typical cost might be for that service.
-Kevin
1965 Chevy Biscayne
<removed> 454cid, "peanut ports", Voodoo 60201
<coming soon> 460cid, Brodix RRO 270, 229/241 Hydraulic Roller
TH400, 3.36 Stock Rearend
65cayne is offline
post #12 of 80 (permalink) Old Apr 5th, 20, 6:04 AM Thread Starter
Kevin,
In general, you’re looking at about 30-45 minutes a session to test three ports; good, bad, and an exhaust.
My machinist is a gear head too, he’s reasonable, and works with me. I’m certainly paying but probably less than you’d expect.
Hopefully I’ll have this engine on his Dyno soon. The progress is exciting. Hoping it’s still reliable. Need to get my cam, lifters, and valve train ordered, but I was waiting to see what pans out of my head testing.
shovelrick likes this.
1981 Malibu wagon
406/350/4.10
post #13 of 80 (permalink) Old Apr 5th, 20, 6:10 AM Thread Starter
By the way, Mark’s videos are great and certainly my go to for this project.
There’s another video I would consider a must watch for my gear head buddies. The entire video is chocked full of good information but the things that catch my interest is about the 30 degree valve seats instead of 45. Full radius in the valve job or 15 degree steps is the best choice, and the goal from a pocket porting.
https://youtu.be/ow5cGV7bXCw
Rmchevelle, RR24 and Janih like this.
1981 Malibu wagon
406/350/4.10
post #14 of 80 (permalink) Old Apr 5th, 20, 7:40 PM Thread Starter
The choke point with an explanation. I’m working under the assumption if the middle of the port is bigger than the port entry, the port entry is a choke point and should be corrected. Repeat the process for the upper sides of the port walls.
https://youtu.be/Wz2iCWhi148
1981 Malibu wagon
406/350/4.10
post #15 of 80 (permalink) Old Apr 5th, 20, 8:09 PM Thread Starter
Choke near port entry eliminated.
https://youtu.be/47uscU68M6E
https://youtu.be/2ZkLVmhTrws
1981 Malibu wagon
406/350/4.10
