High RPM Spread bore dual plane Vortec intake. - Chevelle Tech
post #1 of 23 (permalink) Old Mar 31st, 20, 10:58 AM Thread Starter
Would anyone have a recommendation? With a quick search I've found the Edelbrock RPM Marine but it's pretty expensive and I don't need the anti-corrosion properties built into that manifold. Thanks for any help.
M.Maner is offline
post #2 of 23 (permalink) Old Mar 31st, 20, 11:43 AM
Re: High RPM Spread bore dual plane Vortec intake.
First most Rochester Marine carbs are pretty much the same except they have a higher flow needle and seat and the body is painted. Holley based marines do have J vent tubes to control splash. You have a couple choices but need more info for you to pick the correct one. First you have to determine how many CFM's you need, the type of choke, auto or manual linkage etc. Depending on the size and HP capability of your engine you will need to get one with the correct jets, metering rods and power valve so you need to know your idle vacuum. And finally your application for the car. Personally I like a well tuned Rochester for best all around driveability and power but you can also go with a spread bore holley too. I have always rebuilt my own carburetors, many marine. Most performance rebuild places will use the bigger needle and seat which I recommend for any Rochester. Don't forget there are many different versions of this carburetor based on the years design. Stay away from anything after 1980.
Billdini is offline
post #3 of 23 (permalink) Old Mar 31st, 20, 12:11 PM
I think you missed that he asking for input on an intake manifold, not a carburetor. He wants a high RPM spread bore dual plane intake for Vortec heads (if I am reading it correctly).
The only one that I am seeing is the Edelbrock 7516, which is over $450 everywhere for some reason. I tried to find one from Weiand, Holley, Dart, Professional Products, AFR, and Speedmaster - it does not look like anyone makes a high RPM spread bore intake for Vortec heads. You may have to use a square bore intake with an adapter. Perhaps one of the engine builders will chime in, since they have more knowledge and access to stuff like that.
My Chevelle w/ open headers:
1971-Chevelle is offline
post #4 of 23 (permalink) Old Mar 31st, 20, 12:23 PM
Professional Products 52007 is likely to be the closest to what you are looking for that you will be able to find.
Steve R
Steve R is offline
post #5 of 23 (permalink) Old Mar 31st, 20, 12:27 PM
Yup sure did. Thanks for the clarification
Billdini is offline
post #6 of 23 (permalink) Old Mar 31st, 20, 12:43 PM
Here is one good to 6500 RPM
https://www.summitracing.com/parts/pfs-52028
Billdini is offline
post #7 of 23 (permalink) Old Mar 31st, 20, 12:49 PM
Mr Bill
What are you considering "high rpm" and for what size engine ? I have drilled and tapped a set of Vortec heads to use the old style intake manifolds. The casting is pretty thin in the center section so what I did was tap it 3/8 fine thread and then used studs instead of bolts. That worked perfect for a couple of dirt track customers of mine.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #8 of 23 (permalink) Old Mar 31st, 20, 1:12 PM
Mr Bill
That one is not for a spread bore carb
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #9 of 23 (permalink) Old Mar 31st, 20, 3:30 PM
Steve R
That one is only good to 5,500 (as are all of the others for the Vortec heads, with the exception of the Edelbrock 2516 - I got the model number wrong in my earlier post). I have a feeling he is wanting something that will perform beyond 6,000 RPM.
post #10 of 23 (permalink) Old Mar 31st, 20, 5:02 PM
Wow, two mistakes on one post. I think I will not post anything else today. Oh come on guys I can hear the applause all the way up to Boston
Billdini is offline
post #11 of 23 (permalink) Old Mar 31st, 20, 6:14 PM
Did you try Ebay?
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #12 of 23 (permalink) Old Mar 31st, 20, 6:29 PM
I have a spread bore dual plane Vortec intake at my shop. I think it's Edelbrock. I paid $50 for it and would sell it for that much. I can get a pic tomorrow and model number if it helps.
427L88 likes this.
Gary Adrian
Busted Knuckles is offline
post #13 of 23 (permalink) Old Mar 31st, 20, 8:46 PM
Any chance cutting down the center divider 3/4" on a regular Performer manifold would help?
nitrofox is offline
post #14 of 23 (permalink) Old Mar 31st, 20, 9:39 PM
I have used the Vortec RPM Air Gap and it works good but the low end torque was not as good as the GM Vortec Bowtie RPM intake I have now. The Super Victor works very well also.
68Chevele is offline
post #15 of 23 (permalink) Old Mar 31st, 20, 10:45 PM
jeff
This is not a spread bore but look anyway just for the RPM specs and the price.
https://www.jegs.com/i/JEGS/555/513002/10002/-1
Now the story with it ..I got one for my Home ported 906 vortec heads.
I did cut the divider down about 1/2" that was it.
357" SBC flat top engine .005 piston down the hole 5.5cc reliefs .039" head gasket.
Cam is a Hydraulic Roller [email protected] .50 and .492" lift, 110 LSA 1.5 stainless roller rockers 7/16 studs.
Beehive springs, 313 rate, 130 seat pressure.
It revs quick to 7000 rpm.
I ran a much modified 4779 on it and stock late 70's HEI distributor.
I do not like a flat floor in an intake manifold..I want it to have ribs "waffled" floor.
Find one in a spread bore and cut the divider a bit and never mind that the RPM rating is 5500.
Or run an adapter plate if you have clearance.
I assume you do not have the clearance.
I tested a ported Q jet intake against the Edelbrock Performer RPM intake. The GM q jet intake made 10 HP less than the RPM at the wheels.
It made best HP with a Q jet carb..I also tested my Modified 4779 Which made 10 HP less ..And I tried the Q jet on the RPM intake and on it vs the 4779 the Q jet now made 10 HP less.
I also tried a marine Q jet intake and it made 30 HP less than the RPM intake.
The plenum ported Q jet intake was worth 20 HP over the marine.
All of them would pull all the way to 6500 rpm without nosing over.
jeff swisher is offline
