What do you guys think? - Chevelle Tech
 4Likes
post #1 of 21 (permalink) Old Mar 30th, 20, 4:19 PM Thread Starter
Gerry
Pulled intake off of the 489. Pics attached of what I found on the walls of some the intake ports. Gaskets are Fel-Pro Printoseal with a thin smear of black RTV around the water ports on head side of gasket. Nothing used anywhere else.
Intake torqued to 30 lbs.
I have my thoughts - but asking for what do guys think this could be?
ID:	621260   Click image for larger version
67 SS BBC
4.11's
bradley67 is offline
post #2 of 21 (permalink) Old Mar 30th, 20, 4:43 PM
Re: What do you guys think?
Looks like intake surface either not sealing properly do to different angles or possibly pcv valve.
bradley67 likes this.
WHT/73 is offline
post #3 of 21 (permalink) Old Mar 30th, 20, 6:29 PM
Gary
Do you run E-85 ?
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is offline
post #4 of 21 (permalink) Old Mar 30th, 20, 6:35 PM Thread Starter
Gerry
Originally Posted by TAG55 View Post
Do you run E-85 ?
No on the E-85. Run a mix of 110 leaded with 10% ethanol 93 pump swirl at the track. 10.75 compression. 6,900 max rpm on a limiter.
Single plane Team G intake.
No PVC - two big breathers.
67 SS BBC
4.11's
post #5 of 21 (permalink) Old Mar 30th, 20, 6:43 PM
Hank
The thing that I would be curious of is in the second picture the connector between the two lifters looks like it's cracked at the top.
HKalin is offline
post #6 of 21 (permalink) Old Mar 30th, 20, 7:17 PM
I agree on the connector. I would use a different gasket.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #7 of 21 (permalink) Old Mar 30th, 20, 7:18 PM
rick
X2 what Hank said, just noticed that on secound look, I think oil getting in from int gasket, did it smoke? btw what are you useing for screen and glue for oil return in the valley? Im building my first roller BBC and would like to protect my bottom from any roller pin problems,TIA
shovelrick is offline
post #8 of 21 (permalink) Old Mar 30th, 20, 7:27 PM Thread Starter
Gerry
Itís an optical dilution. Thatís a drop of water on the lifter bar. I agree though it does look cracked.
67 SS BBC
4.11's
post #9 of 21 (permalink) Old Mar 30th, 20, 7:45 PM Thread Starter
Gerry
Engine doesnít smoke at all.
I had the valley oil returns machined about .050Ē deep and flat so the screens would sit flush. The screens are stainless steel. I think I bought 60 mesh. I epoxied in the screens and also a few magnets by the oil returns from the heads just in case.
shovelrick likes this.
67 SS BBC
4.11's
post #10 of 21 (permalink) Old Mar 30th, 20, 7:46 PM Thread Starter
Gerry
What do you like for intake gaskets?
67 SS BBC
4.11's
post #11 of 21 (permalink) Old Mar 30th, 20, 8:04 PM
rick
What heads do you have? my Brodix RR-R called for Felpro FR 1211
post #12 of 21 (permalink) Old Mar 30th, 20, 8:10 PM Thread Starter
Gerry
This engine has BB2-Plus heads on it. Calls for a Fel-Pro 1252-3 if I remember right. Not so impressed with this gasket. It did fit really nice though. I only had to open up in between the intake runners a little. Rick, Did you use any gasket sealer?
67 SS BBC
4.11's
post #13 of 21 (permalink) Old Mar 30th, 20, 9:47 PM
Looks like fuel drop out to me. Rough the ports up and that should go away.
68Chevele is offline
post #14 of 21 (permalink) Old Mar 31st, 20, 6:55 AM
Mr Bill
Not sure what you see that you think is a problem ? I see some pretty normal fuel deposits on the port walls, probably an area of lousy flow like 68 said in the post above. Put it back together and stop worrying
427L88 likes this.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #15 of 21 (permalink) Old Mar 31st, 20, 7:27 AM
rick
Gerry I haven't put my intake on yet, still have to put #1 valve springs back on and adjust lifters, thinking of using High Tack on the int. side & Right Stuff on the china walls and a little on the gasket between heads & manifold, I already have the high tack but never used it before, guess I'm too late on the screen since mine's almost complete
