What do you guys think? - Page 2 - Chevelle Tech
 4Likes
post #16 of 21 (permalink) Old Mar 31st, 20, 9:06 AM Thread Starter
Gerry
Re: What do you guys think?
Originally Posted by shovelrick View Post
Gerry I haven't put my intake on yet, still have to put #1 valve springs back on and adjust lifters, thinking of using High Tack on the int. side & Right Stuff on the china walls and a little on the gasket between heads & manifold, I already have the high tack but never used it before, guess I'm too late on the screen since mine's almost complete
Iím going to give Gasketcinch a try when I put it back together which is basically high tack.
67 SS BBC
4.11's
bradley67 is offline
post #17 of 21 (permalink) Old Mar 31st, 20, 9:32 AM
I'm putting my intake on today. I sprayed 2 coats of High Tack on the head side of the intake gaskets yesterday and let it set up about 5 minutes then stuck them on. then I set the intake on with no sealer and finger tightened the bolts. Today I'm going to remove the intake, put a skim coat of Right Stuff around the ports and water jackets then install manifold. For the china wall, clean the block and manifold with lacquer thinner, put a skim coat of Permatex Ultra Grey on both, then lay a bead of the Grey on the china wall and install the manifold. When the Ultra Grey is hard you can cut the excess that squeezed out with a razor blade for a clean finish that matches the intake.
nitrofox is offline
post #18 of 21 (permalink) Old Mar 31st, 20, 9:40 AM
I always used the spray high tack on steel shim head gaskets and never had a leak. 190-200 psi compression tests. Never anything on a composite gasket. An old trick on the header leak at head situation, cut the flange between the tubes where possible, bolt on, use that way for a while and if no leaks spot weld the cut line. I have use permatex copper on header collector flange gaskets. The newer ball type collector are no angle so no leak .
mrpaticular is offline
post #19 of 21 (permalink) Old Mar 31st, 20, 10:28 AM Thread Starter
Gerry
When I put intakes on Iím pretty much surgical clean on everything. I do same thing with finger tight overnight on manifold.
What intake gaskets are you going to use?
67 SS BBC
4.11's
post #20 of 21 (permalink) Old Mar 31st, 20, 10:44 AM Thread Starter
Gerry
Not sure what you see that you think is a problem ? I see some pretty normal fuel deposits on the port walls, probably an area of lousy flow like 68 said in the post above. Put it back together and stop worrying
Bill,
Question.. do you think my secondary power valve may be giving it too big of a hit? 50 pump shot with a backwards black pump cam gives a fast full pump shot. Thoughts?
67 SS BBC
4.11's
post #21 of 21 (permalink) Old Mar 31st, 20, 12:01 PM
Fel Pro 1205. This is a SB, but the same process.
bradley67 likes this.
nitrofox is offline
