Pulled the trigger today ... - Chevelle Tech
 74Likes
post #1 of 28 (permalink) Old Mar 23rd, 20, 4:27 PM Thread Starter
Guy
On a new set of the latest design EZ-Roll Helix bushed solid roller lifters from Isky Cams;
http://www.iskycams.com/downloads/IS...ixFlyer119.pdf
With the assistance of our very own Mike "Wolfplace" Lewis,big Thank You going out to Mike
I thought that I'd better get'r' done before the border completely shuts down,which I can't see happening,but who knows in these trying times.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZ-Roll "Helix" Solid Roller Lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #2 of 28 (permalink) Old Mar 23rd, 20, 6:49 PM
Greg.
Re: Pulled the trigger today ...
Guy my last Rebuild 2017 of the 468ci I went Roller Cam etc. all the way
and the Engine runs so smooth & quiet
GuysMonteSS and Kopfjaeger like this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is online now
post #3 of 28 (permalink) Old Mar 23rd, 20, 7:09 PM
The Isky EZ helix rollers are only available in solid roller right?
off topic, but have you ever dyno'd your engine?
GuysMonteSS likes this.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #4 of 28 (permalink) Old Mar 23rd, 20, 7:31 PM
Nice, Iím putting the Isky HPX bushed hydraulic lifters in mine.
71350SS likes this.
1967 SS 396 Chevelle
Formerly Bolero Red
Soon to be a 427 equipped Tahoe Turquoise head turner!
Kopfjaeger is offline
post #5 of 28 (permalink) Old Mar 23rd, 20, 10:04 PM
Durand
They're nice units, but they sure do implode the wallet. (least mine did)
LaVelle is offline
post #6 of 28 (permalink) Old Mar 23rd, 20, 10:06 PM Thread Starter
Guy
Greg,I'm on my fourth solid roller cam in this engine,and it runs smooth.
This will be my third set of Isky bushed lifters.
The first set I let go too long,probably well over 25,000 miles.
One wheel "De-laminated" and took out the # 5 exhaust cam lobe.
The current set has approximately 20,000 miles on them and I want to switch them out before anything happens to them.
Now I will have a set that I can send to Isky and have rebuilt and upgraded with the Helix option in the next year or two.
Guy
427L88 and Kirk's67SS like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #7 of 28 (permalink) Old Mar 23rd, 20, 10:15 PM Thread Starter
Guy
I cant answer your first question.I've never used or been interested in hydraulic lifters.
And yes I did dyno this engine.
655 HP @ 6100 RPM
628 ft.lbs of torque @ 5000 RPM
Guy
Name:	DSC_0311 (2016_04_18 13_36_38 UTC).jpg
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #8 of 28 (permalink) Old Mar 23rd, 20, 10:19 PM Thread Starter
Guy
Yep.
Very nice pieces.
Try living in Canada.This morning our dollar was only worth 0.66 cents against the US buck.
I dont want to even think about how much they ended up actually costing me in Canadian dollars.
Guy
-SS454- and Kirk's67SS like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #9 of 28 (permalink) Old Mar 24th, 20, 1:29 AM
Thank you for choosing us to help you Guy it is appreciated & always a pleasure
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #10 of 28 (permalink) Old Mar 24th, 20, 10:26 AM
Durand
Originally Posted by GuysMonteSS View Post
Yep.
Very nice pieces.
Guy
That exchange rate sucks.
I bought a set from Mike awhile back, so you might want to add that receipt to the pile without looking at it.
GuysMonteSS and Kirk's67SS like this.
LaVelle is offline
post #11 of 28 (permalink) Old Mar 24th, 20, 12:12 PM
Yes, Helix are solid roller only. The HPX are hydraulic. Expensive? Yes, quite a bit more than the Morels I was looking at, quite a bit..... but itís one thing less to worry about. Unfortunately Iíve read far too many needle bearing failures to warrant putting them in my build. My oil will never get really dirty so thatís not going to be an issue.
Formerly Bolero Red
post #12 of 28 (permalink) Old Mar 24th, 20, 12:58 PM Thread Starter
Guy
You are welcome Mike,and thanks for all your help !!
Guy
Wolfplace and Jebchevelle like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #13 of 28 (permalink) Old Mar 24th, 20, 6:08 PM Thread Starter
Guy
I emailed Richard Iskenderian about the benefits and longevity of the Helix optioned lifters and here is his reply;
"Hello Guy;
Thanks for being a loyal Isky Customer !
The Helix Bushing is designed for Supercharged, Turbocharged and/or High Spring Load Normally Aspirated Applications & Street Applications with a good amount of idling, to allow you to get extra oil to the bushing.
We have discontinued the EZX Bushing and only use the EZMAX and EZHELIX options now.
Unless your loads are extreme on the street ( over 900 lbs open ) , normally the EZMAX works just fine. There is nothing negative about using Helix on the street , especially if you want additional insurance. It may not be
totally necessary .
You should see some extra life on the street but it will depend on your open spring loads. I wouldn't say you
could double the life but expect somewhere between 25-50% more life on the street with the Helix.
Hope this information helps.
Regards;
Richard Iskenderian
Isky Cams"
So they are probably overkill for my application as my open spring load is under 700 lbs.
But,for me,the added insurance is just peace of mind for me.
The extra cost is pretty small when looking at the big picture.
If I can get up to 50 % more life from these lifters it is well worth it to me.
And at a later date I can send my current lifters for an upgrade to the Helix option.
Two sets should last me a very long time
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #14 of 28 (permalink) Old Apr 1st, 20, 8:55 AM Thread Starter
Guy
Got an email from Mike yesterday.
My new lifters are on the way 👍
Guy
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
post #15 of 28 (permalink) Old Apr 6th, 20, 10:59 AM Thread Starter
Guy
Guess what arrived just now !!
Yep,my new lifters,Yippeeee
Guy
ID:	622102   Click image for larger version
ID:	622104   Click image for larger version
ID:	622106   Click image for larger version
71350SS, Wolfplace, WHT/73 and 1 others like this.
'86 Monte SS,
513 Stroker,
9 inch rearend,
TC Member # 4921
