Rocker geometry...my turn - Page 4 - Chevelle Tech
 40Likes
post #46 of 64 (permalink) Old Mar 27th, 20, 3:02 AM
Re: Rocker geometry...my turn
Originally Posted by steelcomp View Post
AFR's valves and rocker studs aren't in the stock location. You can not use a factory BB Chev stud girdle on AFR's and you can't use an early "S" version AFR stud girdle on a V2.
Well I guess I'm behind the times cocerning AFR heads, because last time I purchased a pair, I don't even remember seeing the term "V2" on their site, so you got me on that one Scott. I'm going to take another look to get a better grasp on what you've pointed out here. Thank you.
BillyGman is offline
post #47 of 64 (permalink) Old Mar 27th, 20, 8:45 AM
Excellent point!
Sent from my SM-G950U using Tapatalk
chasmalo is offline
post #48 of 64 (permalink) Old Mar 27th, 20, 1:40 PM
Kim
AFR has moved their rocker studs and valves several times. This is why we're on V2 of their heads. AFR is not going to make their heads based on available rocker arms. That's just silly. There are a lot of factors that go into where a rocker stud goes, especially with canted valves. It's not just arbitrary. One major problem is the pushrod side of the rocker and it's proximity to the valve cover. Not very much wiggle room there at all so you can't just decide to move the rocker away from the valve without causing other problems. The easiest solution is what I did and that's to come up with a rocker that fits the application. When you're trying to do things with a cylinder head that it was never designed to do, you run into these things.
Quoted for truth. Could not get proper geometry on my old AFR heads without a custom rocker and adjustable guideplates.
kimosabi is offline
post #49 of 64 (permalink) Old Mar 27th, 20, 2:32 PM Thread Starter
Mark
It seems as though the new intake rockers form Chris works out well. It is pretty well centered and fairly narrow on the sweep, and I am even able to use my old(er) pushrod.
The exhaust is different though. It appears as though the new intake rocker, when set up on the exhaust, is closer to the center, but it is on the intake side. My Scorpion rocker is a little long towards the exhaust side. Both rockers leave a narrow sweep though.
Question: Is the Straub/Foxwell exhaust rocker slightly longer from trunion to valve tip roller than the Straub/Foxwell intake rocker?
FYI: I have the AFR "S" version, if that makes a difference.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #50 of 64 (permalink) Old Mar 27th, 20, 2:47 PM
Mark,
I wont speak for Chris or Scott but the rockers for the exhaust I think are no different that your Scorpions (standard 1.7 ), I saw the same thing with my motor and ended up using the set back(Intakes) on both sides, hopefully if i`m talking out my ear Chris will chime in
66 chevelle
New Combo
555
10.2 comp
Straub ProMaxx heads
Straub solid roller
TH400/373
3815lbs
1.31 60'
[email protected]
[email protected]
B433 is offline
post #51 of 64 (permalink) Old Mar 27th, 20, 3:01 PM
Scott Foxwell
Yes. The ex rocker is considerably longer than the intake. I think by about .060". That head will be a little different than the V2.
FOXWELL MOTORSPORTS
steelcomp is offline
post #52 of 64 (permalink) Old Mar 27th, 20, 3:05 PM
Scott Foxwell
Something to note; The rockers I designed for the AFR V2 heads are based on a net lift of .700". If you have a different lift either side of that, your geometry will be different. If you have less lift, your rocker will sit higher on the rocker stud by half the difference in lift. If you have over .700, your rocker will sit lower on the rocker stud by half the difference in lift.
Everything in an engine is a compromise.
BillyGman likes this.
FOXWELL MOTORSPORTS
post #53 of 64 (permalink) Old Mar 27th, 20, 3:51 PM Thread Starter
Mark
Plus, the 5470 lifters that are in there now are .098" taller than the 4503's that were in there.
Why did I do this to myself!!!!
At .680 lift on the intake and .650 on the exhaust, how long will my pushrods be?
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #54 of 64 (permalink) Old Mar 27th, 20, 4:57 PM Thread Starter
Mark
Sorry, 4603's
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #55 of 64 (permalink) Old Mar 27th, 20, 7:05 PM
Scott Foxwell
The shorter the better.
FOXWELL MOTORSPORTS
post #56 of 64 (permalink) Old Apr 15th, 20, 12:29 AM Thread Starter
Mark
Do you need to use the cam bolt lock plate. I forgot it and have the cover on, but is it better to have it? The old one must have gotten left at the engine guy's place. I can get another one if necessary.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #57 of 64 (permalink) Old Apr 15th, 20, 12:46 AM
If the bolts are torqued you are fine
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #58 of 64 (permalink) Old Apr 15th, 20, 12:57 AM Thread Starter
Mark
My elbow popped when I tightened them. Does that count?
I had never saw them, or remembered seeing them used, before my ZZ502, but I thought that it might be important.
Thanks Mike
Wolfplace likes this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is online now
post #59 of 64 (permalink) Old Apr 15th, 20, 8:00 AM
That is the best way I've ever heard engine building and design summed up. I'm learning that more and more. There are so many trade-offs. And the more I learn, the more I realize how much I fall short in knowledge.
MarkP, shovelrick and bradley67 like this.
post #60 of 64 (permalink) Old Apr 15th, 20, 10:30 AM
Gerry
Billy,
When I was in my 40s managing a Urethane Processing company I thought I knew everything. As time went on and I sat in meetings with smarter and smarter people I realized something. The more I learned the less I knew. This is very powerful when that realization hits. Remember to ďrealizeĒ is to make it real. It was always there but you just became aware of it!
When you know everything it shuts the mind down to accept and learn new concepts and information.
There are not that many humble people in this world. I get a kick out of it most times. Thinking of politics.
For me it has been very emancipating being humble and able to open my mind and really listen and learn something new every day. My problem is Iíve forgotten more than I know now. Taking notes and documenting helps.
67 SS BBC
4.11's
bradley67 is offline
