Mark 4 454 with roller cam,what front cover ? - Chevelle Tech
 9Likes
post #1 of 17 (permalink) Old Feb 25th, 20, 5:10 PM Thread Starter
Planning on going roller in my El Camino. What front cover did you guys use ? Button ,Thrust plate and what else might be needed.
Slick87gn is offline
post #2 of 17 (permalink) Old Feb 25th, 20, 5:18 PM
Re: Mark 4 454 with roller cam,what front cover ?
I used a Gen V cam and a thrust plate. No brainer. Stock timing cover.
William Hennke likes this.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 17 (permalink) Old Feb 25th, 20, 6:34 PM Thread Starter
That sounds simple enough. Thanks
post #4 of 17 (permalink) Old Feb 25th, 20, 6:38 PM
Use a Gen V timing chain. I used a Summit one. I think I got the thrust plate there also.
rp930 is offline
post #5 of 17 (permalink) Old Feb 25th, 20, 7:23 PM Thread Starter
I use a mechanical fuel pump.Don't you guys mean Gen VI ?
post #6 of 17 (permalink) Old Feb 25th, 20, 7:35 PM
I use a mechanical fuel pump also.
rp930 is offline
post #7 of 17 (permalink) Old Feb 25th, 20, 7:49 PM
rick
I used a step nose cam & retainer plate I think it said for gen VI and I used a rollmaster gear &chain set from Straub has a torrington bearing, mines in a MK IV block and you can use a stock cover, I used an alum though
shovelrick is offline
post #8 of 17 (permalink) Old Feb 25th, 20, 9:05 PM
I used a nylon button and a stock cover.
Ray
bracketchev1221 is offline
post #9 of 17 (permalink) Old Feb 25th, 20, 10:19 PM
Beth
The retainer plate is here:
https://www.summitracing.com/parts/nal-10168501
Use a Gen VI cam which has a step-nose and a timing chain like Rick mentioned.
I really like the ZZ502 Gen VI cam for the street :
https://www.summitracing.com/parts/nal-12366543
shovelrick likes this.
nashville beth is online now
post #10 of 17 (permalink) Old Feb 25th, 20, 11:23 PM
I didnt like that cam at all,lol.Removed it from my gen6 ho motor and reinstalled the original one it came with.
'67 Malibu,468 w/TH400
Project-
72LS3Z27 is offline
post #11 of 17 (permalink) Old Feb 26th, 20, 9:10 AM
I also run the step nose cam with plate. One thing I want to point out is to be sure to check your end play. When I first checked mine it actually had preload (no end play). I had to surface grind about .005 off the plate to get a couple thousands end play. I don't imagine the needle bearing thrust would last long with preload on it.
540 BB
10 to 4 comp.
Brodix Race Rite BB-2 Plus heads
Edelbrock RPM Air Gap
Quick Fuel 950 CFM Carb
Lunati Voodoo HR 231/239 @ .050, 600/600, 110 LSA
Johnson 2116 BBR lifters
Hooker Super Comp 2" primary headers
Tremec TKO 600 .82 overdrive
3.73 Posi
William Hennke is offline
post #12 of 17 (permalink) Old Feb 26th, 20, 9:48 AM
rick
I could feel a little play but didn't measure, guess I should have though, still could I guess since the int is still off
William Hennke and rp930 like this.
post #13 of 17 (permalink) Old Feb 26th, 20, 10:44 AM
Marcus
Used oem, chrome and alu with nylon button.
Oem and alu with gen VI step nose.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #14 of 17 (permalink) Old Feb 26th, 20, 3:07 PM
Greg
Used a 2pc Cloyes with an adjustable button. Kinda hated it at first, but now I like it. No way I’d pay what they cost new though, mine was in some parts I horsetraded for.
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #15 of 17 (permalink) Old Mar 1st, 20, 3:28 PM
What didn't you like about it?
1972 SS 454 Chevelle - 468/M21/3.73
1969 Malibu L48/M20/3.31 -> L72 swap
1968 Malibu 307/PG -> LQ9/80E swap
Originally Posted by 69-CHVL View Post
How do you retire from something you rarely do?
Its like a welfare reciepiant saying there done working...
carpoor is offline
