505 returns to the dyno - Chevelle Tech
 12Likes
  • 1 Post By 77sonic
  • 9 Post By 77sonic
  • 1 Post By bracketchev1221
  • 1 Post By 77sonic
post #1 of 14 (permalink) Old Feb 24th, 20, 6:11 PM Thread Starter
Daryl
About 16 monthes ago I had my 505 on the dyno. Had a bit of a circus by the time we got some solid numbers.
https://www.chevelles.com/forums/18-...other-one.html
Heading back tomorrow for round 2. This all started with a rear main leak. Had to pull the engine to address that. Soooooooo ....... while it was out I thought it would be a good idea to upgrade the FI as I felt it was running out of air with the Fitech Meanstreet. Soooooo ...... as long as the intake was off and the pan was off it seemed to me that it would make sense to change the cam too.
Now it is back together with a new newfangled Straub cam, Edelbrock Pro Flo 4, and hopefully repaired rear main leak.
Thinking tomorrow will be interesting!!
1970 Chevelle
505 Promaxx 317 Heads
Straub Custom HR
Proform 1050
670hp/610tq
700R4 2.84 Gearset FTI Converter
Moser 12 bolt 33 Spline Axles 4.10 Gears Truetrac
77sonic is online now
post #2 of 14 (permalink) Old Feb 24th, 20, 6:51 PM
Re: 505 returns to the dyno
Be sure and post up. Cant believe those howards springs that is real bad...should never happen!
cuisinartvette is online now
post #3 of 14 (permalink) Old Feb 24th, 20, 7:35 PM Thread Starter
Daryl
[QUOTE. Cant believe those howards springs that is real bad...should never happen![/QUOTE]
For sure!! Very fortunate that it didn't drop a valve.
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
post #4 of 14 (permalink) Old Feb 24th, 20, 11:03 PM Thread Starter
Daryl
Little sound byte of it idling.
https://youtu.be/IiTPWB2wfpw
shovelrick likes this.
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
post #5 of 14 (permalink) Old Feb 25th, 20, 1:15 AM
How much difference between the first cam and the one in the engine now?
sleeper is offline
post #6 of 14 (permalink) Old Feb 25th, 20, 8:09 AM Thread Starter
Daryl
Howards cam - 243/249 @.050
Straub cam - 250/260 @ .050
Both cams mid .6xx lift
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
post #7 of 14 (permalink) Old Feb 25th, 20, 8:15 AM
Jarad
The rebuild sounds rowdy! Looking forward to the results.
I've had to put springs in mine after the build. Nothing as bad as your issue. Car picked up everywhere after the upgrade...
JBoggs is online now
post #8 of 14 (permalink) Old Feb 25th, 20, 7:03 PM Thread Starter
Daryl
Had a successful session on the dyno. The Pro Flo 4 is working awesome. Able to hold rock steady AFR's from 2800 RPM all the way to 6500 RPM. Timing adjustments were easy, quick, and spot on. Being able to make adjustments while the operator is doing his thing really speeds up and clarifies testing. Arrived at the facility at 9 AM, hooked up, fired up, tested, tuned, and loaded up by 1 PM.
I showed up with 36 total advance, 12.8:1 AFR. We went to 38, lost ground, went 34 and gained over 36. Then tried going to 12.4:1 AFR, it didn't like that either. By looking at the plugs we didn't feel going leaner was in the cards. So I left with 34 timing and 12.8:1 AFR making [email protected] 6400 and 603 lb ft torque @ 4900 RPM. All testing on 91 octane fuel.
Was I expecting more, well, yes, but it is easy to get caught up in the internet numbers and expect the stars as well as the moon.
Will this thing be a hoot in my car, I have to think it will be! Now to wedge this thing back in the Chevelle
Oh, and by the way, I seem to have fixed the oil leak!!
RR24, 77 cruiser, StevenS and 6 others like this.
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
post #9 of 14 (permalink) Old Feb 26th, 20, 2:45 PM
What headers did you test with?
A few years back I was able to compare 1 7/8 to 2 1/8. The larger primary tubes were good for 20+ hp everywhere it mattered.
1972 Nova
496 AFR315
Straub Custom HR 258/260 108 lsa
MT 255x60x15 drag radials, Fitech 30012 power adder
1/4 10.067 10/24/2018
1/4 138 MPH **NEW** 11/24/2019 (100 shot)
60' 1.446 10/24/2018
Best 1/8 - 6.404 10/24/2018
Best 1/8 110.11 MPH **NEW** 11/24/2018
Dragweek 2015,2017,2018 SME
2016,2017 RMRW 11.0 index
Supernova72 is offline
post #10 of 14 (permalink) Old Feb 26th, 20, 3:17 PM Thread Starter
Daryl
2 inch with 34" primaries into a 3 1/2 collector
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
post #11 of 14 (permalink) Old Feb 26th, 20, 3:50 PM
Plenty of power to go quicker than 10.50.
427L88 likes this.
Ray
bracketchev1221 is offline
post #12 of 14 (permalink) Old Feb 26th, 20, 4:26 PM
Gerry
Very nice numbers!
How much hp difference was there between 34 degrees and 36 degrees of timing?
67 SS BBC
4.11's
bradley67 is offline
post #13 of 14 (permalink) Old Feb 27th, 20, 9:35 AM
Sorry about the bad luck with the springs. I'm concerned as I just bought a
set of howards 98885 for an upcoming project. Did howards say anything? Give
you a refund? Be nice to know what kind of a company we are dealing with when people have problems. I have a 427 l88 bottom end with oval port top end that makes some nice power at 580 with stock ported heads and flat tappet cam. I follow the 427 stuff and noticed that you cam guy had asimilar l88 427 with afr heads that made 671horsepower. Just wondering why your down to a 427 and seems the howards made more tq and hp then the new bigger cam. You old thread posted you made 620 horsepower at 5500 RPM and 620 Lb. ft. torque at 4700 RPM with no tuning. But on you chart with tuning, you peak lb ft is 602. And at the 5500 around 610 horsepower. So seems
something is costing you power on the new motor. I would think this would
have been 700 plus horsepower and 650 plus torque all day long.
RickyHill is offline
post #14 of 14 (permalink) Old Mar 2nd, 20, 1:38 PM Thread Starter
Daryl
[QUOTE
How much hp difference was there between 34 degrees and 36 degrees of timing?[/QUOTE]
12 hp peak. But torque at 2800 was up 22 lb. ft. with less timing
bradley67 likes this.
1970 Chevelle
Straub Custom HR
Proform 1050
670hp/610tq
