Piston-to-head: what's ideal? What's safe? - Chevelle Tech
 16Likes
post #1 of 26 (permalink) Old Feb 23rd, 20, 11:25 PM Thread Starter
How much do you guys use with forged steel connecting rods? Let's be clear here. I'm not asking about piston-to-valve clearence. I'm asking about piston-to-head, (AKA "squish"). I've always considered .040" to be the ideal, but I recently read something that suggested that .040" isn't enough. And that .050" is better.
BillyGman is offline
post #2 of 26 (permalink) Old Feb 24th, 20, 8:55 AM
Scott Foxwell
re: Piston-to-head: what's ideal? What's safe?
Most NA apps you can get away with .035-.04. Has a lot to do with piston design and rock in the bore. Basically just enough so the piston doesn't hit the head. Power adders and boosted apps need a little more (or a lot more), depending. If you're trying to use a head that was designed for high compression with a small flat chamber in a low compression application, I've heard some guys say they made more power by increasing the quench distance than they did by using a dished or reverse dome piston but there are way too many variables there to come to any real conclusion.
JMO
BillyGman likes this.
FOXWELL MOTORSPORTS
steelcomp is online now
post #3 of 26 (permalink) Old Feb 24th, 20, 10:07 AM
I would tend to think Rod design, rod bolts, piston weight, and RPM play a big factor here. I know in my 540 build I will be 0.035. Light pistons, forged I-beam, arp2000 bolts, 5000rpm limit. most likely it would be good for over 5500rpm but I just don't need more rpm's for my build
GoFast Beaumont is offline
post #4 of 26 (permalink) Old Feb 24th, 20, 6:51 PM
rick
My 86 RV 454 with golf ball size dish about 2" X .050ish deep pistons that are .020 down with 98-99 cc 063 heads and .027 cometic mls head gaskets give me a .047 quench and roughly 9:1 comp. runs great on 89-90 oct. gas, next is 10.77:1 489 alum heads and pistons down .001 and .039 gasket for a .040 quench and I'm guessing going to need high test 92-93
427L88 and BillyGman like this.
shovelrick is offline
post #5 of 26 (permalink) Old Feb 24th, 20, 7:48 PM
I shoot for zero deck and a .039-.041 gasket. Aluminum rod could use more.
bracketchev1221 is online now
post #6 of 26 (permalink) Old Feb 24th, 20, 9:06 PM
The correct range is between .039 and .045.
Philip, BillyGman and shovelrick like this.
Dave Ray is offline
post #7 of 26 (permalink) Old Feb 25th, 20, 5:30 AM Thread Starter
Yeah, that's pretty much what I've always that, and that's where I should be at. I'll know for certain when I pull the heads off and check piston [email protected]
post #8 of 26 (permalink) Old Feb 25th, 20, 7:43 AM
Our buddy Jim Moore likes to run 'em a bit tighter, I'm surprised he hasn't added his .02 here.
It's not tight enough if your pistons aren't leaving witness marks on the heads at high RPM's. I think he showed a pic once where the dimpled part number on the top of a piston had been transferred to the deck on the head. That's close!!!
His claim is it keeps the rods from stretching
Works for me!
BTW, I shoot for .035 - .040.
Gary Adrian
Busted Knuckles is online now
post #9 of 26 (permalink) Old Feb 25th, 20, 8:20 AM Thread Starter
Works for me!
That's some funny shizzle right there^
post #10 of 26 (permalink) Old Feb 25th, 20, 9:35 AM
Dale
Speaking of Jim Moore; based on his experience with 4.25 stroke combo's, I chose to run my 540's quench @ .034" (.007" ITH + .027" MLS). My clearances are .0033-.0035 mains (little big but chasing a bearing issue), .0025 rods, Scat 6-weight crank, Scat H-beam rods and Mahle Power Pack 4032 pistons w/Line-to-Line coating. It runs 7500 rpm's thru the lights and has accidentally spun to 8000 (rev limiter) a few times. I think if it was going to touch, it'd happened by now. YRMV
66 Chevelle
1/8 mile
1/4 mile
Building more of a race car than driver but driving it more than I race. "simple old school shake, rattle & roll".
Monk is offline
post #11 of 26 (permalink) Old Feb 25th, 20, 9:50 AM Thread Starter
Not meaning to change the topic here, but with those 4032 alloy pistons you have in there, do you ever notice piston knock when the engine is cold? My Mahle coated pistons are the 2618 alloy, and I never had the 4032 stuff.
post #12 of 26 (permalink) Old Feb 25th, 20, 11:21 AM
Dale
The 4032 is the higher silicone/tighter fitting material. I'd think if you were going to hear anything, it would be with the 2618. Personally, if I could hear cold knocking, I wouldn't worry about it.
You've had a few engine questions lately, building a new engine?
66 Chevelle
1/8 mile
1/4 mile
Monk is offline
post #13 of 26 (permalink) Old Feb 25th, 20, 11:34 AM Thread Starter
I must be mistaking. Let me take another look. Perhaps it is the 4032 stuff my pistons are made out of. Maybe I'm getting the two alloys mixed up. I have the Mahle flat top BBC coated pistons with an 1.120" pin height for a 4.6" bore.
To answer your question, I'm getting ready to start digging into my current engine combo. There's things I'm not content with.
post #14 of 26 (permalink) Old Feb 25th, 20, 12:07 PM
rick
My 4032 Autotec pistons have .003 clearance built in, engine builder had to clean the bores up and finished at .005, he said it'll be fine, also asked if I was going to run .050 quench I shook my head no, he's a highly recommended race engine builder around here, maybe he was just fooling with me?
post #15 of 26 (permalink) Old Feb 25th, 20, 12:15 PM
Dale
Billy, if you don't mind me asking, what is it that you're not satisfied with about your 632?
66 Chevelle
1/8 mile
1/4 mile
Monk is offline
