Street use Dominator carb. - Chevelle Tech
 10Likes
post #1 of 26 (permalink) Old Feb 16th, 20, 10:07 AM Thread Starter
Durand
What is best for street use a 2 circuit or 3 circuit?
Research ( though somewhat out dated ) shows most people preferring a 2 circuit.
Does that still hold true?
Who makes a good 2 circuit Dominator carburetor 1250 cfm and/or bigger?
LaVelle is offline
post #2 of 26 (permalink) Old Feb 16th, 20, 10:21 AM
Re: Street use Dominator carb.
I'm running the 2 circuit 1050 on the street and track with no issues, but like most carbs I had to fine tune to my combo. Mine came from AED.
B433 is offline
post #3 of 26 (permalink) Old Feb 16th, 20, 11:14 AM
Gary
You can make either one work but the 2 circuit is the better of the 2 for what you're doing in my opinion
gnicholson is offline
post #4 of 26 (permalink) Old Feb 16th, 20, 5:34 PM
I was going to use a 8896 1050 I bought for a streeter and found out it was 3 circuit carb. I called Holley the tech guy said to just put a small lead ball in the hole for the intermediate tube and call it a day, it will run fine. Some say you should change the metering blocks and other stuff but the Holley tech says you don't need to do all that so I guess I will try it.
68Chevele is offline
post #5 of 26 (permalink) Old Feb 16th, 20, 8:21 PM
I ran a 3 circuit 1050 on my smallblock on the street for several years. Ran great. Idled fine, drove around town great and was nice and snappy.
'69 Camaro - 429 SBC Dart Iron Eagle 9.325" block, Crower crank, Crower 6" Billet rods, Ross pistons (10:1), Total Seal S/S rings, AFR 245 heads, T&D steel rockers, Cloyes Timing Set, 4-7 swap solid roller 274/286 @ .050", .704" lift, Dart single plane, Dominator EFI, Stef's #1705R pan, F2 Procharger on E85
Steve69SS396 is online now
post #6 of 26 (permalink) Old Feb 16th, 20, 8:25 PM
https://youtu.be/BI0v6pY2gzE
Nice video.
What intake is that Dominator on ?
Reelysalty is offline
post #7 of 26 (permalink) Old Feb 16th, 20, 8:28 PM
Jack
First Drive - YouTube
Car sounds great !!
Matthew 22: 37-39
R.I.P. Mike Romeo
DragRac69 is offline
post #8 of 26 (permalink) Old Feb 17th, 20, 7:28 AM
Greg
I use a BG king demon 1095 that started life as a 3 circuit methanol carb, now it’s a two circuit gas carb. It really doesn’t feel or act any different from a good 4150. Always heard dominators were finicky but this one acts just fine. I’ve got an old Holley book that explains why the third circuit was added, don’t remember the details but the gist was the third circuit was not necessary.
Greg C.
1969 Chevelle Malibu
New, waaaay overcammed 496 "The Dud"
[email protected]
Iforgot is offline
post #9 of 26 (permalink) Old Feb 17th, 20, 8:01 AM Thread Starter
Durand
I have a BG King Demon R/S that is 1050cfm but will be to small for the application. I need at least 1250cfm.
If sleeves were available I'd change it over to a 1250, but I they seem to be unobtainable.
So does anyone custom build Dominators to engine parameters?
LaVelle is offline
post #10 of 26 (permalink) Old Feb 17th, 20, 8:47 AM
ran one ( 2 circuit ) for a while and will use it again for next build. Only issue was idle circuit was pig rich and would foul plugs if left to idle for long time. these carb are set up for very little engine vacuum at idle so if you have a set up that gives good vacuum it will suck up a lot of fuel/ air through this circuit at idle. I installed larger bleeds to lean it out and it took care of this.
15 years in Craft Brewing/ Distilling Industry
Lead Maintenance Mechanic
Submarine Service SSN 575 / SSN 683
novass is offline
post #11 of 26 (permalink) Old Feb 17th, 20, 10:40 AM
Originally Posted by Reelysalty View Post
Nice video.
It has a Dart intake.
Originally Posted by DragRac69 View Post
Car sounds great !!
Thanks!
post #12 of 26 (permalink) Old Feb 17th, 20, 10:43 AM
Dale
Why run 1 when you can run 2?
jeffs68 and DragRac69 like this.
66 Chevelle
1/8 mile
1/4 mile
Building more of a race car than driver but driving it more than I race. "simple old school shake, rattle & roll".
Monk is offline
post #13 of 26 (permalink) Old Feb 17th, 20, 11:58 AM
[QUOTE=Steve69SS396;11234518]
Nice video.
Car sounds great !![/quote
Thanks!
Very nice sound and look !
post #14 of 26 (permalink) Old Feb 17th, 20, 12:01 PM
Originally Posted by Monk View Post
👍👍👍. This is just plain Bad Azz
Nuttin beats a pair of Holleys mounted sideways !
Monk likes this.
post #15 of 26 (permalink) Old Feb 17th, 20, 4:34 PM
Dale
I wouldn't buy another 3-circuit for the street again. My experience is by the time that intermediate circuit is restricted enough to make it stop burbling at cruising rpm, it is pointless to have it. I'm currently running 2 off the shelf 2-circuit 1050's and don't think throttle response could be better.
These new Gen 3 Holleys are hard to beat.
66 Chevelle
1/8 mile
1/4 mile
Monk is offline
