Bbc assembly - Chevelle Tech
 12Likes
  • 5 Post By 427L88
  • 1 Post By Rosinbluth
  • 1 Post By mrpaticular
  • 2 Post By paul bell
  • 2 Post By Malibu ss 64
  • 1 Post By jackie schmidt
post #1 of 14 (permalink) Old Jan 23rd, 20, 2:58 PM Thread Starter
Bbc assembly
Can anyone recommend some good books for engine assembly tips and tricks? Specifically 454 and 496 engines.
Poorfairlane is offline
post #2 of 14 (permalink) Old Jan 23rd, 20, 3:11 PM
Re: Bbc assembly
"How To Hot Rod Big Block Chevy's" is sort of the Bible, but I wouldn't consider it an assembly blueprint. A great read if you haven't though.
post #3 of 14 (permalink) Old Jan 23rd, 20, 3:18 PM
Re: Bbc assembly
A little pricey...
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is online now
post #4 of 14 (permalink) Old Jan 23rd, 20, 3:48 PM
Originally Posted by aukai View Post
A little pricey...
Reher-Morrison,
Not your average keyboard kommander !
Reelysalty is offline
post #5 of 14 (permalink) Old Jan 23rd, 20, 5:32 PM
Guy
Re: Bbc assembly
Here is a rebuild book;
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #6 of 14 (permalink) Old Jan 24th, 20, 11:18 AM
Re: Bbc assembly
I got the David Vizard book. It was a good read and all, gave me some ideas. After I read the book, I then searched those same topics on this site. Some ideas were maybe not necessary or not as good as the book says. So reading a book is good, but the guys on this site are the BBC masters. Use the search key, and you'll find everything you've ever wanted to know. Another good option is VortecPro and his youtube videos. He goes into some pretty good detail about doing things right. I can watch them over and over and seems I still learn something new each time. Good luck on your build.
https://www.youtube.com/channel/UC1W...HYwfa2w/videos
shovelrick likes this.
Rosinbluth is online now
post #7 of 14 (permalink) Old Jan 24th, 20, 1:28 PM Thread Starter
This site has been a wealth of knowledge but I'll be the first to admit I don't know everything. I'm always trying to do better and its hard to search a topic you didn't realize was an issue.
Thanks for all the suggestions
post #8 of 14 (permalink) Old Jan 24th, 20, 7:35 PM
Re: Bbc assembly
This site !!!!!!!!!!!!!!!!!!
fr8dog likes this.
mrpaticular is offline
post #9 of 14 (permalink) Old Jan 24th, 20, 8:26 PM
Re: Bbc assembly
I don't know how recently (if at all) the Vizard rebuild books have been updated, and it may not have all the latest trick ideas, but I have an older copy and if you are rebuilding a Mark IV and do what it says, at least you know it will run and not blow up. After almost forty years of doing it, I still have my copies handy for reference when I assemble an engine.
Droptop72 is online now
post #10 of 14 (permalink) Old Jan 24th, 20, 8:44 PM
Re: Bbc assembly
My favorite. It's a good balance between mild to wild builds. Well written, great pics, excellent explanations and how to's.
Wolfplace and Malibu ss 64 like this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #11 of 14 (permalink) Old Jan 25th, 20, 4:28 AM
Marcus
Re: Bbc assembly
I have this three books. They cover the most for me.
Wolfplace and shovelrick like this.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #12 of 14 (permalink) Old Jan 25th, 20, 3:03 PM
Do you find these books have mostly the same info, or does each book have some of its own value? Maybe I need a couple books besides the Vizard books.
post #13 of 14 (permalink) Old Jan 25th, 20, 6:07 PM
Marcus
Re: Bbc assembly
The info is different all have their purpose, but today if you have internet its enough imho.
post #14 of 14 (permalink) Old Jan 26th, 20, 12:54 PM
jackie
Re: Bbc assembly
Big block chevys are brutally simple in their design. Chevy designed the oiling system to be first class.
Where you run into problems is when you start reading about everything that is wrong with them. Your typical internet Forum will, sooner or later, give you so many things that you have to fix that you wonder how the darned things ever got down the road without self destructing.
Just about any rebuild book will give you the basic bearing clearances and torque values. Adhere to these using quality parts, and you wont go wrong.
Exactly what are your concerns?
66rat likes this.
jackie schmidt is offline
