Approx cost of glass flat hood and hinges (67) - Chevelle Tech
 2Likes
post #1 of 17 (permalink) Old Jan 21st, 20, 2:26 PM Thread Starter
Put this in tech as the topic is really about heat management
Low cost and interesting to me
Debating doing something subtle but effective to reduce underhood temps, incorporate a cold air setup but extract as much underhood heat as possible.
Not much experience with glass but seems simple from the little Ive done.
Some newer vettes have an interesting extractor behind the radiator, some guys space up the rear...any bright idears?
Love the sttel cowl one I have but get bored. Plus its heavy as hell.
Would you recommend using pins in addition to the latch, is it really needed?
cuisinartvette is online now
post #2 of 17 (permalink) Old Jan 22nd, 20, 10:28 PM
Beth
Re: Approx cost of glass flat hood and hinges (67)
For a 67 El Camino, why not install a cowl induction hood (2" rise) ?
That would give the hot air a way to escape. And cowl hoods for 67's are cheap !
nashville beth is offline
post #3 of 17 (permalink) Old Jan 23rd, 20, 11:35 AM Thread Starter
have a cowl induction now...when I removed my ac I took the opening for the suitcase welded a lip on it in case a yunick type box was done.
This would need fab work which Im not capable of doing. Once ran a camaro air cleaner (cowl induction) but that was with the old motor that looked more stockish
post #4 of 17 (permalink) Old Jan 24th, 20, 3:42 PM Thread Starter
The ZR1 corvette uses a neat hood that extracts hot air from the radiator...if the compartment builds pressure with hot air to boot..if that was removed, get cold air to the engine and looked good to boot..kind of a challenge without spending a ton .
MB uses a neat firewall that isolated the engine from electronics, brakes etc. Wouldnt be hard to do
post #5 of 17 (permalink) Old Jan 24th, 20, 4:34 PM
If not already done you could ceramic coat your headers or manifolds. Takes a ton of heat out of the engine compartment.
67
70 (SOLD)
Alwhite00 is offline
post #6 of 17 (permalink) Old Jan 24th, 20, 5:15 PM
The engine compartment and the hood design stock was to draw air in through the radiator and force it back and down against the firewall. Giving it a way to escape somewhere else may create more heat in the long run.
oldcutlass is offline
post #7 of 17 (permalink) Old Jan 25th, 20, 3:42 PM
I have a fiberglass hood and fenders from Glasstek on my 67. It's a considerable weight savings. But the fenders required inner braces to make them match and hold the contour of the door body lines, so some fabrication is required
dell72 likes this.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #8 of 17 (permalink) Old Jan 25th, 20, 4:02 PM
Lance
Other considerations...Something like aluminum heat shields over headers to reflect heat down, coated headers-inside and out, take a look at the "turkey roaster" air boxes on the the big block cobras with the idea of ducting your cowl induction hood into it for cooler intake temps (kind of a "take-off" on Smokey's plenum air cleaner), possibly adding sheet metal cover between the top front of the grill to top of radiator (like the ones they sell with a bowtie emblem, etc.) to direct more air thru the radiator, lower temp thermostat, if not already done, fans, water pump pulley changes. All sorts of options possible with a little research..some good ideas have been previously presented here..take a look /search.
vortec710 is offline
post #9 of 17 (permalink) Old Jan 26th, 20, 3:07 AM
What hinges are you considering?
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #10 of 17 (permalink) Old Jan 26th, 20, 8:26 AM
Post a picture of your ride and engine compartment, may help spur some ideas.
67
70 (SOLD)
post #11 of 17 (permalink) Old Jan 26th, 20, 1:17 PM
Jason
Rick,
Is your hood hinged or pin on? 99% of the time Iím at the track by myself and hood removal and install (Ď71) would be a PITA and risk scratching stuff up on a windy day. Been looking at making braces/brackets for glass fenders to support hood hinges. Could end up with the weight cancelling out though.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
post #12 of 17 (permalink) Old Jan 27th, 20, 11:57 AM Thread Starter
Cant get pics to post on here unfortunately
I do have coated headers....sure would be nice to figure something out to keep a few plug boots cooler. THey dont touch but still singe 1-2 here and there.
Running the inner fenders and rubber seals. Have considered either ditching those and fabbing up something light/that looks clean and give more room or glass.
Keep the idears coming....lighter I can get this the better. Not up for adding power but removing weight is just as good. If im creative doesnt have to cost that much. Came close but decided to get my 1500 back on the road
Hinges would be whatever came with the glass hood?
post #13 of 17 (permalink) Old Jan 27th, 20, 6:47 PM
Originally Posted by DragRacer View Post
Rick,
Pin on, but I bonded and fiberglassed inserts to the bottom side so I could bolt it to a set of lighten stock hinges. I got sick of constantly removing the hood. It has worked well for close to 2 years now.
DragRacer likes this.
8.02 at 171mph:
post #14 of 17 (permalink) Old Jan 27th, 20, 6:58 PM
Rick, how much weight did you save with the switch to fiberglass fenders and hood compared to the OEM parts?
dell72 is offline
post #15 of 17 (permalink) Old Jan 28th, 20, 3:19 PM
I really don't know. I never weighed anything, but i'd say 20 lbs per fender if a 67 fender is 25 lbs the glass fender is 5lbs.
I haven't had a steel hood on the car since 1998, so it's hard to guess that one. Probably at least 20lbs lighter.
8.02 at 171mph:
