Your biggest weight savings? - Chevelle Tech
 31Likes
post #1 of 70 (permalink) Old Jan 20th, 20, 11:22 PM Thread Starter
I am curious where you guys have found the biggest weight savings. Hopefully documented. I imagine most will say cylinder heads, but that data is for sure valid.
For me;
Front street tires/rims (235/60R15 on 15x7 Keystones) to my front skinnies (26x6-15 on 15x4 Weld wheel) = 43.4 reduction
Stock buckets to Scat Procar rally seats = 39.8 lbs reduced.
jeff swisher and mrpaticular like this.
Youtube Channel.
Instagram:
Twitter:
-SS454- is online now
post #2 of 70 (permalink) Old Jan 20th, 20, 11:52 PM
Rhys
Wife. Loud pipes, no stereo and no AC took care of that.
vortec710 likes this.
Not smart enough to think of something funny.
Monkey is offline
post #3 of 70 (permalink) Old Jan 21st, 20, 12:02 AM Thread Starter
Re: Your biggest weight savings?
hahahaha.
Removing my aftermarket stereo (2 door speakers, 2 rear 6x9s, head unit, and wires) was only worth about 15 lbs.
Youtube Channel.
Instagram:
Twitter:
post #4 of 70 (permalink) Old Jan 21st, 20, 3:24 AM
Doors, and hood....
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #5 of 70 (permalink) Old Jan 21st, 20, 6:22 AM
OLIVER
Front drag disc brake were 35lbs less compared to stock disc
Inviato dal mio iPhone utilizzando Tapatalk
Oliver
Milano , ITALY
468 Vortecpro 585 HP back to street cruiser
M20 4 speed - 3.31
Prosystems 1000
BEST ET 11.62 (with 4.10)
BEST MPH 121
BEST 60 FT 1.64
4000 lbs street car
1969 El Camino Street Strip
467 Vortecpro Tunnel ram 730+ hp TH400
BEST ET 10.67 @ 127 1.56 60FT
oliver69 is offline
post #6 of 70 (permalink) Old Jan 21st, 20, 7:16 AM
jeff
1978 Nova I removed all the GM Steering and installed a rack from a 1982 Mustang. Lost 45 lbs.
1957 Chevy I built my own fiberglass front bumper it weighs 5 lbs with the aluminum brackets to mount it.
Stock one was a tick over 50 lbs.
71350SS and 68Chevele like this.
jeff swisher is offline
post #7 of 70 (permalink) Old Jan 21st, 20, 8:40 AM
Backhalf on the car saved 250 lbs.
jeff swisher likes this.
bracketchev1221 is offline
post #8 of 70 (permalink) Old Jan 21st, 20, 11:55 AM
Jay
no longer stock style suspension?
'66 300 Deluxe 582ci F2
1148ft lbs 1100hp at the tire
5.55 124 1.24 60ft
Offroadr is offline
post #9 of 70 (permalink) Old Jan 21st, 20, 11:58 AM
Jay
The faster you go the more weight you add as well. Once you get all the major things done its tough to pull weight.
Heads, radiator, brakes, master cylinder, front steering to rack, control arms, seats, hood all help.
Once you go fast and make power you have to add weight - better transmission, better block, cage, etc
Never ending battle lol
bradley67 likes this.
5.55 124 1.24 60ft
Offroadr is offline
post #10 of 70 (permalink) Old Jan 21st, 20, 12:11 PM
No. One of the weight savings was cutting the factory 12 bolt as short as possible and using the least amount of backspacing on the wheels. Made the housing and the axles as short as I could. My car used ladder bars and coil over shocks.
hydro462 likes this.
post #11 of 70 (permalink) Old Jan 21st, 20, 12:12 PM Thread Starter
Holy crap. Where does the weight savings come from?
Youtube Channel.
Instagram:
Twitter:
post #12 of 70 (permalink) Old Jan 21st, 20, 12:13 PM Thread Starter
That's what I am finding. Upgraded bellhousing and transmission was a big one for me.
Youtube Channel.
Instagram:
Twitter:
post #13 of 70 (permalink) Old Jan 21st, 20, 12:13 PM
This is true. I went from a Merlin head stock block 427 to Merlin II block 16 years ago with aluminum heads and the car weighed the same. I saved nothing with the Merlin block!!!!
Ray
post #14 of 70 (permalink) Old Jan 21st, 20, 12:18 PM
The stock floor and frame were cut out from behind the front seats back. Replaced with aluminum floor, 2X3 frame rails, any cage bars that did not need to be certified were done in chromoly in addition to the mild steel cage. Any brackets were made out of chromoly, and all extras in the car were removed. Went to a lightweight gel battery and an 8 gallon fuel cell. The battery cable and wires were the smallest gauge that would work. The tires were tubeless, and anything else we didn't need was gone. The car was still all steel except for the hood and the bumpers and the windows were all factory glass except for the side 1/4 windows because they would not clear the wheel tubs. The dash, carpet, door panels, and steering column all remained factory GM.
-SS454- and jeff swisher like this.
Ray
post #15 of 70 (permalink) Old Jan 21st, 20, 1:06 PM
ac and heat not sure how much??
Lost 92 lbs going from 8" ralleys to Weld Draglites 5" front 8 rear
Friendtold me this after he swapped found it hard to believe. Yep True!
It actually was a noticable difference
If you go to skinnes up front Id recommend a 5-6" rim and a normal tire. Those M/T wiht the extra stiff sidewall is awful hard.
Probably kept me alive though when I had the 8s found the car handled really well...love taking turns too much im that idiot taht may find the line too late.
cuisinartvette is offline
