For those that read the post about the "Towing HotRod..did you note... - Chevelle Tech
 9Likes
  • 1 Post By jeff swisher
  • 1 Post By steelcomp
  • 1 Post By nitrofox
  • 2 Post By Roadknee
  • 2 Post By bradley67
post #1 of 12 (permalink) Old Jan 20th, 20, 12:59 PM Thread Starter
The cylinder pressure difference the "test" that go performed with the failing lobe.....No. 1 220 PSI, all other 7 170 PSI. Pump gas of 91 min was used for the entire trip. Truck has a Turbo 400 with 2 overdrive units on it. No sign of detonation on Number 1 or the other 7.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 12 (permalink) Old Jan 20th, 20, 10:51 PM
jeff
Re: For those that read the post about the "Towing HotRod..did you not
I did see that.. probably a conservative tune for the towing to be on the safe side.
I pulled 2 degrees from my 350 when i stuck my pontoon behind it . On a wheel dyno 3 degrees less was only 3 Hp difference.
Attention to detail when building really helps also. I do not care for sharp edges or stick ups in the combustion space and I like a rough intake runner with a good shape to promote good fuel atomization and you can get by with a lot of compression on pump fuel.
Another thought is the cranking pressure was much higher but due to the loss of lift that cylinder did not get filled as much as the others.
I have thought about that aspect with high flowing heads say 260-270 cfm @ .500" lift vs some heads that peak at 225 cfm at the same lift.
Would the cylinder fill more with the higher flowing head. would 9.5 compression on the high flow head want 35 total and 91 octane when the other low flowing head could tolerate 10.8 or more compression.
I have often thought about why I can get by with 11:1 with old school ported sbc heads and pump gas.
All the little massages or is it my intake runner just will not fill the cylinder like a modern head will.
Pat_McNeil likes this.
jeff swisher is online now
post #3 of 12 (permalink) Old Jan 21st, 20, 10:19 AM
Scott Foxwell
The cylinder pressure on the "bad" cyl was over 220psi cranking pressure. This was from the lobe being wiped out and the intake valve closing WAY late. If someone was to do the math on the "dynamic compression" it would probably be somewhere around 11:1 or more. For all those who worry about "DCR" and how much is "too much" for pump gas, one would have to ask; why didn't that cylinder detonate itself to death with that much cylinder pressure?
427L88 likes this.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #4 of 12 (permalink) Old Jan 21st, 20, 10:42 AM
Scott, wouldn't the intake valve have to close early to raise the cranking pressure? Also, why was just one lobe affected? If the core wasn't up to the task, wouldn't more lobes show wear? The other ones in the pic look pretty good still.
72BBMonte likes this.
nitrofox is offline
post #5 of 12 (permalink) Old Jan 21st, 20, 12:47 PM
Scott Foxwell
Yes...the valve was closing early, not late. Wrote that in a bit of a hurry. Thanks for the correction (too late to edit). Why one lobe was effected... good question. Could have been a million things. That particular valve spring spring was most likely the culprit.
FOXWELL MOTORSPORTS
Straub Technologies
post #6 of 12 (permalink) Old Jan 21st, 20, 1:23 PM Thread Starter
No 1 chamber in excellent shape and shows no sign of detonation.
Chris Straub
cstraub is offline
post #7 of 12 (permalink) Old Jan 21st, 20, 4:55 PM
Doesn’t surprise me. With a wiped lobe the VE of that cylinder was probably really low at cruise rpm and above.
77 cruiser and bradley67 like this.
Roadknee is offline
post #8 of 12 (permalink) Old Jan 21st, 20, 6:55 PM
Gerry
EXACTLY ^^^
With almost nothing to burn it wouldn't detonate. That cylinder was making no power when it fired.
The cranking pressure on that hole was higher because the intake valve was closed for most of its duration. There was no bleed off from the exhaust valve overlap.
77 cruiser and 72BBMonte like this.
67 SS BBC
4.11's
bradley67 is offline
post #9 of 12 (permalink) Old Jan 22nd, 20, 3:36 PM
Originally Posted by bradley67 View Post
EXACTLY ^^^
Cranking pressure is reduced because of a late closing intake valve, and has nothing to do with exhaust overlap
70GS455 is offline
post #10 of 12 (permalink) Old Jan 22nd, 20, 4:07 PM
Scott Foxwell
EXACTLY ^^^
It didn't suddenly get that way, to that extreme. This happened slowly over time. There was a period of time where the valve timing on that lobe was dramatically reduced but still plenty of lift to fill the cylinder.
bradley67 likes this.
FOXWELL MOTORSPORTS
Straub Technologies
post #11 of 12 (permalink) Old Jan 22nd, 20, 4:09 PM
Scott Foxwell
Cranking pressure is increased because of an early closing intake valve. From the second that lobe started wearing, cylinder pressure was increasing over what it was from the start.
427L88 likes this.
FOXWELL MOTORSPORTS
Straub Technologies
post #12 of 12 (permalink) Old Jan 23rd, 20, 10:23 AM
Interesting, a "reverse" reading from what we're used to.
