Start Retard for MSD Ready To Run Distributor - Chevelle Tech
 14Likes
post #1 of 32 (permalink) Old Jan 18th, 20, 10:00 AM Thread Starter
I want to lockout my timing but need a start retard to prevent kickback. Unfortunately it looks like all the start retard units MSD makes have a 2 wire hookup to the distributor but my distributor (MSD Ready to Run) has a 3 wire. I'm also running an MSD 6 box. I just can't imagine MSD doesn't make something to work with their ready to run distributor but I can't find it.
Anyone know of a product or a way to retard the timing when I start the car?
'70 Malibu, 454 w/Brodix Ovals, TH400 w/10" ATI, 12 bolt with 4:11's
2013 ZL1 Camaro, Ashen Gray Metallic, No Mods YET
rednecks70 is offline
post #2 of 32 (permalink) Old Jan 18th, 20, 10:27 AM
mark
Re: Start Retard for MSD Ready To Run Distributor
On my car I have a toggle switch for the power wire to crane box,,spin it over then flip the switch,,no issues and simple
71350SS and DragRac69 like this.
1965 malibu,03 silverado ss
M.J. 496
th350,4.11 3250lbs,+185 FOR ME
28x10.5 Hoosiers
9.85,135.50,1.35
mino65 is offline
post #3 of 32 (permalink) Old Jan 18th, 20, 10:33 AM Thread Starter
That's my backup plan .
I'm concerned I will forget to use it and have mashed up teeth
post #4 of 32 (permalink) Old Jan 18th, 20, 10:59 AM
Vince
You can always just knock a few degrees out for the street, say like 4-5* then crank it back in on race day. You will still get all the benefits of the locked-out timing and wont notice the slight loss of top-end power (on the street).
PS - Consider a stronger starter if you haven't already. I'm running a used zz502 starter on my 502 and it cranks the engine over easily with locked out timing. I dont think its anything different that comes on GM engines. I'm only 9.8:1 though.
WHT/73 likes this.
*2011 Mustang GT premium
*61" Scag Kohler 22hp 7mph
69-CHVL is offline
post #5 of 32 (permalink) Old Jan 18th, 20, 1:49 PM
I had tried to use the MSD 8984 but it wasn't a successful venture. It worked well enough for the retard function but the car would simply stop running at the most inconvenient times for no reason. MSD told me it was my wire routing but
that was not the case. It didn't matter how the wires were routed, the car would shut off when it would shut off, meaning sporadically. Disconnected the unit and it ran fine. I tried 3 of them and they all did it.
'66 SS Chevelle
bored small big block
performance to be determined.
91 octane special.
Stokerboats is offline
post #6 of 32 (permalink) Old Jan 18th, 20, 2:46 PM
This?
https://www.summitracing.com/parts/msd-8680/
VinceS427bb likes this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #7 of 32 (permalink) Old Jan 18th, 20, 2:57 PM Thread Starter
To be honest I'm not addressing the real problem...my converter is too tight and unless I run at least 20* of initial timing it stalls when I put it in gear. Due to money and my one car garage I'm just trying to figure out a quick, cheap fix.
post #8 of 32 (permalink) Old Jan 18th, 20, 3:02 PM Thread Starter
Originally Posted by aukai View Post
I looked at that unit too. Not sure how it works...I'm assuming I can dial back to 1 when i start the car to retard the timing and then crank it up to 15 once it's started to get my full initial timing. Can anyone confirm? Will it still let the distributor advance per the set curve?
post #9 of 32 (permalink) Old Jan 19th, 20, 8:06 AM
How small is the converter and what are the cam spec and cubic inch engine?
68 malibu 402 cid w/iron ret ports
[email protected] 1.47 60ft so far
[email protected] 1.452 60ft more to come!
Support our Troops!!!
1968 hot rod is offline
post #10 of 32 (permalink) Old Jan 19th, 20, 9:29 AM
Use a single points distributor and remove the springs to the weights...
hydro462 is online now
post #11 of 32 (permalink) Old Jan 19th, 20, 11:15 PM
Jack
Did you lockout the distributor. When you started it. Did the engine kick back ?
Matthew 22: 37-39
R.I.P. Mike Romeo
DragRac69 is offline
post #12 of 32 (permalink) Old Jan 20th, 20, 12:03 AM Thread Starter
Yes, I locked the timing and started the car...it bent the crap out of the starter bolts and trashed the threads.
Converter is a 10" from ATI. They originally sent me an 8" and it was way too close for the street. Just need to find a happy medium.
post #13 of 32 (permalink) Old Jan 20th, 20, 7:50 AM
Eng size & what camshaft are you using
post #14 of 32 (permalink) Old Jan 20th, 20, 9:14 AM
If you are using a 6 box then you can use the start retard box part number 8984. It would go between the distributor and 6 box on the white points wire.
Points wire from distributor goes to retard box, retard box has an output wire that goes to the white points wire for msd box.
Lay the two sets of instructions next to eachother and you will see how it works.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #15 of 32 (permalink) Old Jan 20th, 20, 9:54 AM
mark
here is my setup,,clear toggle is to ign box,,push button to spin and flip switch to start,,2 fingers
Name:	IMG_0826 switch.JPG
M.J. 496
28x10.5 Hoosiers
9.85,135.50,1.35
mino65 is offline
