540 take 3 - Chevelle Tech
post #1 of 17 (permalink) Old Jan 17th, 20, 4:23 PM Thread Starter
540 take 3
So hopefully 3rd times the charm. I ran the 540 all last summer and after the final cam change it ran pretty good. Sometime last fall I noticed a popping sound in the exhaust and sounded like a valve issue so I ran a compression test and #6 had 0 psi. Pulled the head and found a burned exhaust valve and loose valve guides. The exhaust guides were way loose and the intakes were starting to get loose. So trying to be thorough I put the head back on with checking springs to recheck the rocker arm geometry. The intake checked out right on (using the Foxwell video) with the contact pattern right at .060. The exhaust was off center toward the exhaust port and the pattern was a bit wide. But the length came out the same as when I set it up a year ago. So even though the pushrod is the right length, the pattern on the tip of the valve is wide and off center. My understanding is as long as the pattern is in the center 1/3rd of the valve it's ok so if that's the case I just need to narrow up the pattern. I tried going about .050 shorter and longer on the pushrod to see if it would narrow up the sweep but it made no difference. It seems like some use different (setback) rocker arms. But I would think that would just center the roller more not change sweep. I also read that on BBC a lot of times it's the intake that's off but my intakes look good? Also why are my intake guides loose when the pattern looks good on them? Makes me wonder if I have more than one issue. I will attach pictures of the patterns on the valve tips shortly.
540 BB
10 to 4 comp.
Brodix Race Rite BB-2 Plus heads
Edelbrock RPM Air Gap
Quick Fuel 950 CFM Carb
Lunati Voodoo HR 231/239 @ .050, 600/600, 110 LSA
Johnson 2116 BBR lifters
Hooker Super Comp 2" primary headers
Tremec TKO 600 .82 overdrive
3.73 Posi
William Hennke is offline
post #2 of 17 (permalink) Old Jan 17th, 20, 5:03 PM Thread Starter
Pattern https://imgur.com/gallery/TpzjEKO
540 BB
10 to 4 comp.
3.73 Posi
post #3 of 17 (permalink) Old Jan 17th, 20, 5:38 PM
Re: 540 take 3
how many miles did you put on them. Adjustable guideplates?
cuisinartvette is offline
post #4 of 17 (permalink) Old Jan 17th, 20, 5:44 PM Thread Starter
About 3000 miles. Yes, adjustable guide plates. The heads came assembled from Brodix. Before I put them on I took them to my machine shop and they checked the guide clearance and that was ok. I don't think they checked the run out though.
540 BB
10 to 4 comp.
3.73 Posi
post #5 of 17 (permalink) Old Jan 17th, 20, 7:04 PM
Re: 540 take 3
I would replace with the Brodix's better guide. The stock heads come with the std guide.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #6 of 17 (permalink) Old Jan 17th, 20, 7:10 PM Thread Starter
My machinest is getting the Manganize bronze guides I think those are the better ones? I still feel like I should do something with that exhaust side with the sweep and position of the pattern on the valve. I guess the question is what?
540 BB
10 to 4 comp.
3.73 Posi
post #7 of 17 (permalink) Old Jan 17th, 20, 7:13 PM
Re: 540 take 3
The reason we came out with the rockers we use is for the best sweep pattern for BBC's with aftermarket heads. That's the reason AFR says what they do about rocker geometry. We used the rockers several Brodix heads. If you want 1 of each to mock up I don't mind sending you 1 of each. It's eye opening.
Chris Straub
cstraub is offline
post #8 of 17 (permalink) Old Jan 17th, 20, 7:48 PM Thread Starter
What about my intakes? They seem to be about right? Doesnt look like I need different rockers for intake? However I obviously would buy a matched set, dont think I want different brand rockers on intake and exhaust.
540 BB
10 to 4 comp.
3.73 Posi
post #9 of 17 (permalink) Old Jan 17th, 20, 7:59 PM
Re: 540 take 3
Offer stands.....I'd try both and see the difference.
Chris Straub
cstraub is offline
post #10 of 17 (permalink) Old Jan 17th, 20, 8:02 PM Thread Starter
Ok, heads are still at machine shop so once I get them back I will order a set and give it a try.
540 BB
10 to 4 comp.
3.73 Posi
post #11 of 17 (permalink) Old Jan 17th, 20, 10:21 PM
Re: 540 take 3
Thx Chris for being willing. Stuff like this is why Chris gets talked up here a lot.
shovelrick likes this.
post #12 of 17 (permalink) Old Jan 17th, 20, 10:27 PM
Re: 540 take 3
Sorry to hear about your troubles. That thing sure has been challenging. Iím curious how loose were the guides? Did the shop measure clearance?
Roadknee is offline
post #13 of 17 (permalink) Old Jan 17th, 20, 10:33 PM Thread Starter
Originally Posted by Roadknee View Post
Sorry to hear about your troubles. That thing sure has been challenging. I’m curious how loose were the guides? Did the shop measure clearance?
Exhaust was bad loose, no point in measuring them. Intakes were too loose to run so changing them too. Looks like I might need a valve or 2 also. Funny thing is the intake pattern looks good. I was really surprised they were loose.
540 BB
10 to 4 comp.
3.73 Posi
post #14 of 17 (permalink) Old Jan 17th, 20, 11:03 PM
rick
Re: 540 take 3
Bill I'm also sorry to hear of the trouble your having, I'm also hoping 3rd times the charm for you
shovelrick is offline
post #15 of 17 (permalink) Old Jan 18th, 20, 9:04 AM
Re: 540 take 3
chris what about the moldstar 90? Guides
opinions? Can you sell them?
