Handy Holley Tuning Tip - Chevelle Tech
 7Likes
  • 2 Post By Reelysalty
  • 2 Post By Tom Mobley
  • 2 Post By lookback
  • 1 Post By gnicholson
post #1 of 13 (permalink) Old Jan 15th, 20, 7:09 PM Thread Starter
We learned this little tip from Phil Freelander at FST Carburetors based on his decades of experience. There are six flats on a Holley carburetor float adjustment hex-head screw. If you raise or lower the float level adjustor by four flats (two-thirds of a turn), this is the equivalent of two jet sizes. For example, raising the float level four flats would be the same as changing from 78 to 80 jets. Lowering the float level will lean the air-fuel ratio.
This is based on the height of the fuel level in the float bowl. Increasing the float-height richens the mixture because it increases the pressure on the main jets located at the bottom of the column of fuel in the bowl. This is not a carved-in-stone rule, but changing the float level will certainly affect the overall air-fuel ratio and can be used for minor changes in overall jetting. It’s best not to alter the float level beyond this point in either direction — but if you need to make a change in a hurry, it will work.
Thanks goes out to Hardcore Chevy. !
jeff swisher and DJsSS like this.
Reelysalty is offline
post #2 of 13 (permalink) Old Jan 15th, 20, 7:26 PM
Re: Handy Holley Tuning Tip
yeah, this is right. I used to use this trick on my 69 Z/28 if I was go on any kind of a hiway drive. I used 1/2 turn down on the primary. I knew I wasn't going to be lead footing it so I didn't care about the secs. Helped to the tune of about 1.5MPG.
jeff swisher and 69ZL1 like this.
post #3 of 13 (permalink) Old Jan 15th, 20, 7:44 PM
Read this same tip 1 day ago on Chevy Hardcore, along with some others. Take a look.
https://www.chevyhardcore.com/tech-s...nd-procedures/
DJsSS and rp930 like this.
lookback is offline
post #4 of 13 (permalink) Old Jan 15th, 20, 8:20 PM
Deon
Thanks, going to have to try it to see if I can better the 3 gallons / per mile I am currently getting.
72 Chevelle, 454, TH400, 3:73's
72SS454Chevelle is offline
post #5 of 13 (permalink) Old Jan 18th, 20, 5:04 PM
I worked at Holley for over 5 years, and I never saw the need, nor sensible reasoning to vary the float levels to change jetting, only needed to....change the jetting.
To each, their own insanity, it seems.
Dave Ray is offline
post #6 of 13 (permalink) Old Jan 18th, 20, 5:32 PM
I use this method now. Raising fuel level adds more volume which in turn adds more weight . Especially beneficial during high weather pressure by further increasing the super charge effect. I did not know about the 2 jet thing. I run my float levels at the top of the sight glass.
mrpaticular is offline
post #7 of 13 (permalink) Old Jan 18th, 20, 7:50 PM
This cant be a precise science since the fuel level in the sight window is basically an eyeball estimation. And since most garage floors have a pitch to them, getting the fuel level in the center of the window is probably off a bit when you're initially adjusting the floats.
So, I might be two or three flats above or below before I even start messing with the adjustor.
Or am I thinking too much into this ?
I guess I'll just leave it centered in the window, the way Holley designed it.
1775SS is offline
post #8 of 13 (permalink) Old Jan 18th, 20, 7:55 PM
My 3310 calls for the fuel level to be even with the bottom of the site screw hole.
oldcutlass is offline
post #9 of 13 (permalink) Old Jan 18th, 20, 8:27 PM
Gary
Obviously it doesn't matter where the fuel level was to start with .if you raise the fuel level over this arbitrary value or lower it you richen or lean the mixture it's just basic physics. Obviously you don't want to raise the fuel level enough to cause flooding. Raising or lowering Inlet fuel pressure accomplishes the same thing
gnicholson is offline
post #10 of 13 (permalink) Old Jan 18th, 20, 8:45 PM
Agreed..
It might be a quick hack to see if jetting should be changed.
artmalibu is offline
post #11 of 13 (permalink) Old Jan 18th, 20, 8:58 PM
Gary
The lesson here is not necessarily use float level changes to change afr but to know that it does effect it. Raising float levels richens the entire carb where changing jets idle intermediate etc only changes thier respective circuit. Changing float levels a few Flats is a good quick way make an afr change to see what the engine wants
boyd66k20 likes this.
post #12 of 13 (permalink) Old Jan 20th, 20, 3:47 PM
Used as a tuning check tool, extremely marginal info/feedback input, done the right way in setting the correct fuel liquid level, absolutely essential to doing it right.
And, it isn't the fuel volume weight that is in play, but the change in the amount of fuel pulled in for the vacuum level pull. At the same vacuum, lower liquid level, harder vacuum pull, higher, easier fuel pull, but, that is what the jets, fixed air bleeds and air correctors are for. Plus, too high can lead to fuel dribble into jet passages, richness and just plain rotten engine running.
This is a lot like soe sizes for one set dimension foot, too big, problems, too small, problems, and PAIN.
As far as carb angle being effected by vehicle attitude, none of you guys ever hear of a carburetor wedge for a BOAT?
Dave Ray is offline
post #13 of 13 (permalink) Old Jan 20th, 20, 4:17 PM Thread Starter
Pretty sure I remember wedge manifolds and or wedges for inboards of the 60’s ???
