Another pulley exploded. - Page 2 - Chevelle Tech
 21Likes
post #16 of 39 (permalink) Old Jan 13th, 20, 8:47 AM
rick
Re: Another pulley exploded.
Like Jeff said "Scratch & Dent" for $115 IMO it's too much $, I'd either get OEM at GM parts or JY? or the brand Mr. 4 Speed is running, CVF ? same as the scratch & dent but new
shovelrick is offline
post #17 of 39 (permalink) Old Jan 13th, 20, 9:06 AM
SO I hate to give away my local stashes, but if you folks call over to Bob Harris at Camaro Specialites in East Aurora NY , Bob has BARRELS full of GM oem pulleys. I got my new big deep groove alt pulley there as well. Maybe not barrels, but a good stash of them....
Some of you may have your own "local stash", and its a great place to look for those old , well made, GM pieces.
I have it easy with single groove short pump early bbc. You can use my name if you call over to Bob's. He or Craig will answer the phone. Good people.
RAIDER SS and carpoor like this.
post #18 of 39 (permalink) Old Jan 13th, 20, 9:08 AM
Lew
If the pulley breaks again I would look into that balancer causing something (harmonics). Your not even running a radiator fan (electric fans) which can put stress on things.
Lew540 is offline
post #19 of 39 (permalink) Old Jan 13th, 20, 9:10 AM
For sure, I would have had my cheap chicom mag base indicator on it already. The Moroso ought have lasted. ,
post #20 of 39 (permalink) Old Jan 13th, 20, 11:20 AM
What pulley did you have that let go? Was it stamped steel or billet aluminum? If solid, maybe the mating surface isn't flush and that is putting stress on it cracking it.
Pioneer4x4 is offline
post #21 of 39 (permalink) Old Jan 13th, 20, 1:13 PM Thread Starter
The broken pulley was a stamped steel unit. I’ll be putting a solid billet pulley on the crank because I’m going to be using a belt driven fuel pump in the very near future. The CFv 3 groove. Ok let that is supposed to be high speed built/balanced. I also have a new fluidamper I’ll be installing. I guess it doesn’t pay to buy cheep pulleys. The Moroso May have been a fake. I got it on eBay a while back for 35 bucks.
427L88 likes this.
71malibuu is offline
post #22 of 39 (permalink) Old Jan 13th, 20, 2:33 PM
Look into March pulleys.USA Made and billet.
Your part number is # 7121get it thru kegs or summit. I run one on my 548. Keeps standard ratio and its deep grove V to. Dont use the ones that slow down pump.
lookback is offline
post #23 of 39 (permalink) Old Jan 13th, 20, 4:49 PM
I went to a 1 " smaller diameter billet crank pulley to reduce fan noise, less strain on the accessories by the significant reduction in belt speed and eliminated belts throwing off. Probably would help in this setup.
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #24 of 39 (permalink) Old Jan 14th, 20, 1:05 AM
Originally Posted by 71malibuu View Post
The broken pulley was a stamped steel unit. Iíll be putting a solid billet pulley on the crank because Iím going to be using a belt driven fuel pump in the very near future. The CFv 3 groove. Ok let that is supposed to be high speed built/balanced. I also have a new fluidamper Iíll be installing. I guess it doesnít pay to buy cheep pulleys. The Moroso May have been a fake. I got it on eBay a while back for 35 bucks.
I'd search the site for opinions of Fluidamprs before I put one on.
Steve439 is offline
post #25 of 39 (permalink) Old Jan 14th, 20, 7:55 AM
Good job on the patch up...
hydro462 is offline
post #26 of 39 (permalink) Old Jan 14th, 20, 8:14 PM Thread Starter
Yah I’m just going to weld the 9 nuts together and use it as is. Should be worth about 7 hp.
In all seriousness do the above recommended pulleys wok with a belt driven fuel pump? Are there any particular brands that are better than others when it comes to a belt driven fuel pump? I’m going to have to start posting parts before I buy them to eliminate the chances of purchasing parts that are known junk. I’m just about to add a 300 kit direct and a 150 on a plate. Fuel issues are not something I want anything to do with at 6500rpm and all kits on. I also despise the sound of an electric pump grinding away on a street car. On a side note I got the turbo manifolds made up for the Camaro and will be dry fitting them this weekend if schedule allows. I’m in the process of building a new garage, just got the foundation pored 30x50 with a man cave upstairs, and I’ll be doing the rest so free time is an oddity lately. Being so busy 12-14 hr work days, spending hours researching specific parts and how well they work seems to be more of a put me to sleep thing instead of a learning thing as of late.
post #27 of 39 (permalink) Old Jan 14th, 20, 8:58 PM
Out of curiosity why a belt driven pump and not an electric?
Seems to create more issues than just using stock stuff with electric
tacomatrd is online now
post #28 of 39 (permalink) Old Jan 14th, 20, 9:02 PM Thread Starter
I can’t stand the sound of electric on a street car. Plus mounting it below the tank and all of the logistics don’t go with the stock look I’m after. “ with the hood closed”.
post #29 of 39 (permalink) Old Jan 15th, 20, 11:15 AM
Factory pulleys are prefered unless you use billet. No matter what you use you need the correct ratios. I have lots of pulleys and ended up going with CVF serpentine setup. Perfect alignment, never needs tightening and has not came. Plus they look great and the price is good. Great customer service.
mrpaticular is offline
post #30 of 39 (permalink) Old Jan 15th, 20, 12:45 PM
Kerry
For a mechanical a holley 12-454-20 will feed to the 750 hp range without issue. Brian Gooding (Drag Week winner? runs one on his car, no regulator). For pulleys I would look at March, but do not run the smaller underdrive crank pulley if you street drive your car. Reducing water pump speed and alternator speed will cause heating issues, and charging issues. It's a very small amount of HP to gain versus the issues which come up. I worked through both engine temp and poor charging at idle/stopped at lights by changing my underdrive pulley to a std size. I also recently helped someone with a heating issue when driving slow and in stop/go traffic by going to the proper size pulley. With more water turbulence from spinning the water pump faster, his heating issue went away.
pockets is offline
