Fuel tank or fuel cell? - Chevelle Tech
 2Likes
  • 1 Post By Kirk's67SS
  • 1 Post By The Flying Clutchman
post #1 of 9 (permalink) Old Jan 11th, 20, 10:59 AM Thread Starter
Todd
Didn't see a fuel system section so I'm gonna ask here. I'm close to dropping the body back on the roller. My question is do I go with a tank from Tanksinc or a drop a fuel cell in the trunk? I see they are both 20 gallon and priced different. I will be DDing the car when the weather is good. Going to run E85 as well with a ProSystems carb and mech fuel pump on the motor.
91c1500sleeper is offline
post #2 of 9 (permalink) Old Jan 12th, 20, 12:05 PM
Greg.
Re: Fuel tank or fuel cell?
Todd
when my 50+ yr old Gas Tank had to be replaced I went with a stock like replacement
of a 24 Gal Holley Sniper EFI Fuel Tank w Pump
https://www.jegs.com/i/Holley/510/19-105/10002/-1
also Removed the Mech Fuel Pump & installed a BlockOff Plate
went with new Russell Braided Feed & Return Lines & Ends
https://www.jegs.com/i/Russell/799/632080/10002/-1
Holley # 12880 Fuel Pressure Regulator https://www.jegs.com/i/Holley/510/12-880/10002/-1
Russell # 650310 Fuel PSI Gauge https://www.jegs.com/i/Russell/799/650350/10002/-1
Installed a Fuel Filter before & at the Fuel Regulator to Carb http://www.jegs.com/i/Earls/361/230106/10002/-1
plus a Metal Fuel Filter from NAPA https://www.napacanada.com/en/p/NGF3033
was installed on the Feed Line back 1/2 way along the Frame Rail
I run a 950 cfm Pro Systems carb and I drive it when the weather is nice on the Street/Hwy/Track
Todd some questions ;
1. what size is the Carb
2. do you do any Hwy trips
3. SBC or BBC
bradley67 likes this.
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #3 of 9 (permalink) Old Jan 12th, 20, 7:07 PM
Not sure on your budget, but Rick's has nice stainless tanks which is a good thing to have for a DD on E85 in my opinion.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #4 of 9 (permalink) Old Jan 13th, 20, 11:12 AM Thread Starter
Todd
Originally Posted by Kirk's67SS View Post
Todd
3. SBC or BBC
It's going to be an 850 CFM Venom, yes I plan on some highway trips to different car venues in the area. BBC with a TKO600.
I ended up ordering a Tanksinc tank, pickup and straps the other day. I already have the mechanical pump for the motor. My hang up now is do I run metal fuel line or the appropriate bi-rubber line that the E85 won't eat through?
post #5 of 9 (permalink) Old Jan 13th, 20, 12:35 PM
Greg.
I would think that running a Metal Stock type fuel Line with the Bi-rubber in certain spots would be fine
I went the Route I did as I am looking down the road to go EFI
specifically a Holley Sniper TB https://www.jegs.com/i/Holley/510/550-516K/10002/-1
https://www.jegs.com/p/Holley/Holley...25601/10002/-1
Born 283 / PG / A51
60' = 1.664
60' = 1.547
post #6 of 9 (permalink) Old Jan 14th, 20, 9:06 AM
David
I had a 1st gen Aeromotive Stealth tank in my 71 and the fuel would slosh away from the pump at the track if I had less than 3/4 tank. My bowls would run dry a little after 1/8 mile. This is with around 700 hp and I run high 6s in the 1/8 (no 1/4 times yet because of the fuel issue.) On the street it worked just fine. The 2nd gen tank moves the pump to the middle of the tank, so fuel slosh won't be as much of an issue, but when I called Aeromotive they recommended the fuel cell if I'll be taking it to the track.
Edit: I went with a Stealth 340 20 gallon fuel cell and it worked perfectly with 5 gallons at my last 1/8 mile test and tune session.
DragRac69 likes this.
1971 Chevelle SS
572 Merlin, 4L80, 12 bolt
1969 AMX
390, G-Force T5, Control Freak suspension
1980 Pinto wagon
2.3 turbo, Megasquirt, G-force T5, ported head, fabbed intake, big turbo
1970 Torino Squire wagon
Turbo Barra swap coming
The Flying Clutchman is offline
post #7 of 9 (permalink) Old Jan 14th, 20, 9:55 AM
George
My Tanks Inc tank does the same thing...may get rid of it and do afuel cell or sump a stock tank. Havenít decided yet.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #8 of 9 (permalink) Old Jan 14th, 20, 12:25 PM Thread Starter
Todd
The tank arrived today. I'm gonna run it and see if I have the starvation issues ya'll mentioned. It's mostly gonna be a pavement pounder and see lil track time if any. I'm also gonna go with the nylon 3/8's fuel line and run it through the frame through a piece of 1/2 PVC pipe and clamp it on the inlet and outlet. Then use the barbed fittings and attach the proper alcohol apporved rubber lines to connect the sending unit, FP, filter(s) and the carb line.
post #9 of 9 (permalink) Old Jan 14th, 20, 2:35 PM
George
On the street you wonít have any issues. Mine is fine on the street. Its on hard launches where mine has issues. There was no mention of not using it for drag racing when I bought mine....other than that its a nice tank, pump is quiet and looks nice.
'71 Malibu
Geo71 is offline
