355 sbc Horsepower estimate - Chevelle Tech
 16Likes
post #1 of 38 (permalink) Unread Jan 8th, 20, 7:55 PM Thread Starter
Gary
Just what to know what you guys think of this 355 build.. Hoping it gets sons car to 7.30's to possible 7.20's in the 1/8 mile.. I think it might make 450 to no more than 500..
350 sbc .30 over
JE flat top pistons 2v reliefs
Sealed power file fit rings
6" Scat rods
GM stock crank
Brodix IK 200 heads ( no extra porting )
Victor Jr. copy intake not real sure of the brand
650 double pumper Proform main body ( may need a 750 )
1"5/8 Headman headers
Howards hydraulic roller
.550/.540 .247/.253 @.050 ground on 110
Car should weigh about 3500, it has a 700r4 with a FTI 4000 stall, Moser 9" with 4:56 gears.. thanks, Gary
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is online now
post #2 of 38 (permalink) Unread Jan 8th, 20, 9:01 PM
MARK
Re: 355 sbc Horsepower estimate
454 HP = 119 MPH @ 3500 pounds. 119 MPH / 1320=11.09. 1.57 X 7.10 = 11.14. So there you have it. So....now it comes down to the drive line, can it do it, I don't think so, but please keep us informed.
Machined GM production heads
Oil pan modifications
VORTECPRO is online now
post #3 of 38 (permalink) Unread Jan 9th, 20, 12:13 AM
My 9 to 1 358 with Home ported Sportsman II heads, 300-25 Strip Dominator, 850 Mighty Demon 1 3/4 Super comps went 7.24 last outing a couple of years ago
so you should be able to do it.
68Chevele is offline
post #4 of 38 (permalink) Unread Jan 9th, 20, 9:04 AM
I could imagine 7.30's out of that if everything is working as it should.
But it's going to take a very low density altitude to get there. During the summer heat I'd say 7.50s would be more realistic.
PileDriver is offline
post #5 of 38 (permalink) Unread Jan 9th, 20, 9:07 AM
I think you'll be close. We had a 355 in my friends 69 camaro. The car looked factory original except for the wheels and tires. 2 valve relief flat tops, World Sportsman II heads, Ultradyne 251/251 solid flat tappet, .518/.530 cam. T-400 with a 4400 converter and 4.56 gears. The car went 11.58 at 115 mph.
bracketchev1221 is offline
post #6 of 38 (permalink) Unread Jan 9th, 20, 11:04 AM Thread Starter
Gary
Thanks for the replys guys.. Just a little history on this build and why we are doing it. My son bought this car last fall, it had some Edelbrock 185cc heads and a Comp 305 magnum cam with a flat lobe. With this set up the other owner the car went 7.66 1/8th mile. My son pulled the engine, sold the old heads and bought the Brodix and we are installing the Howards cam. So basically this is a new build.. I sent out the block and crank to the machine shop, for cleaning, new cam bearings, I also had the block zero decked... My thinking with the way we are building it should run close to our goals.. The chassis is set up pretty good with all Spohn adjustable torque arm, rear sway bar, lower control arms, it has Hole Shot wheels, no heat or air, going to get a manual steering box. We are installing a S &W roll bar, might be lighter than 3500 lbs... This is his first fast car, so hopefully it gets close to our goal.. It will be midsummer before the first pass, but I will let everybody know how it does.. thanks, Gary
427L88 likes this.
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is online now
post #7 of 38 (permalink) Unread Jan 9th, 20, 7:07 PM
Pretty basic build, probably closer to 400 hp.
Somewhere in the 12's for 1/4 mile.
You never mentioned new body bushings or anti roll bar.
mrpaticular is offline
post #8 of 38 (permalink) Unread Jan 9th, 20, 9:58 PM
My Nova went 7.40's @ 94 mph, 11.78 @ 113/114 in good air with a pooch 1.68 60' with my 2 bolt .030 over 355.
Stock rods,Trw dished 4 relief pistons. Custom Cam Motion HR cam 224/232 .528" lift, 64cc AFR 195 Comp ported heads, Hurricane intake w/780ps carb, 1-3/4 super comps with full exhaust to the bumper, th350 w/ 3k tci converter and 3.73's
The compression I guess was around 9/9.5:1
Shell super as always.
60' was killing it.
3515#'s with me.
Is the 3500 with driver?
blue_69_malibu likes this.
WHT/73 is offline
post #9 of 38 (permalink) Unread Jan 9th, 20, 10:47 PM
MARK
60' was killing it.
3515#'s with me.
355ci NA - YouTube
People need to understand what it can mean to race in "good conditions" at Englishtown. These conditions today at Englishtown could very well be 1/2 second quicker than a normal near sea level day at the track anywhere else. Incredible power making conditions that I will never see in my racing.
temperature = 30.16 deg f
relative humidity = 54 %
uncorrected barometer* = 30.64 inHg
corrected barometer* = 30.73 inHg
wind speed = 0.73 mph
wind direction* = SW (241)
more info: current metric | historical | forecast | help
dew point = 17 deg f
saturation pressure = 0.167 inHg
vapor pressure = 0.090 inHg
grains = 12.9
air density (w/o water vapor) = 109%
air density (w water vapor) = 108%
density altitude = -2766.43 ft
post #10 of 38 (permalink) Unread Jan 9th, 20, 11:12 PM
Are you dissing my passes? We all know it will be slower waaaaaaaaaaaaaay up in the mountains where your located. You have mentioned this many times.
Imagine if I was at atco! Below sea level?
It's not my fault I live where I live and the track that I used (45 miles in either direction from me) has good conditions or "better air" conditions then tracks up in Denver.
I'm well aware of what good air can do as I watched my son run 11.01 up at island in 97* heat and humidity and know FULL well he would have went 10's at Englishtown or even quicker at Atco but he wanted to go so we went.
Oh yeah we don't have to worry about having good air anymore as Englishtown is a dirt lot when we went to island and we didn't want to travel 2.5hrs to atco.
Name:	matts drag a bu.jpg
WHT/73 is offline
post #11 of 38 (permalink) Unread Jan 10th, 20, 6:44 AM Thread Starter
Gary
No body bushings, its a 83 Camaro, it has a Spohn rear sway bar and all the adjustable stuff they make for these cars.. It has already been 7.66 in the 1/8th, which works out to about a 12.10 in the 1/4 with the junk cam and heads it had.. 7.66 x 1.58 = 12.10
60' was killing it.
3515#'s with me.
355ci NA - YouTube
On the weight I'm just taking a SWAG we have no idea what it weighs until I get the engine together and weigh it at the track.. It has alot of stuff already removed A/C, heat, inner bumper support, glass hood, light weight wheels, ect.
WHT/73 likes this.
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is online now
post #12 of 38 (permalink) Unread Jan 10th, 20, 7:09 AM
Removing all that stuff will definitely help make it lighter.
Got a JY near you? We paid the guy at ours $10 to use his scale.
This helped me get the weight for the front Santhuff springs.
WHT/73 is offline
post #13 of 38 (permalink) Unread Jan 10th, 20, 10:22 AM
MARK
Not at all. Denver has nothing to do with this. Results one gets at Englishtown in certain times of the year will be difficult to reproduce at low altitude tracks in other parts of the country due to the extreme high barometer this area can get, 30.64 corrected baro is super charging a NA engine. When Ed Bigleys brought up, remember he raced in these unheard of conditions regularly.
427L88 likes this.
post #14 of 38 (permalink) Unread Jan 10th, 20, 1:19 PM
Well you certainly have some nice parts in that engine. I assume its balanced. That's a pretty hot cam for the street. I had a 230 degree roller at 50 in my 74 L82 with World Product 64 CC heads and the rest is pretty much the same as your engine.. I would put you in the 450-475HP gross range if it is properly setup. My 650DP ran better then a 750DP but you have a hotter cam so you may be able to use it. The difference wouldn't be huge though. No matter what it runs it will be a quick fun car. Mid to low 12's in the quarter. Enjoy
Billdini is offline
post #15 of 38 (permalink) Unread Jan 11th, 20, 11:14 AM
Chris, your combo is very different that OP's. No comparison. I think if all works good he will be 13.0-12.5. Maybe mid 13's until all is worked out and driving improves. In the beginning everything is going against your goal.
