El caminos - Chevelle Tech
 7Likes
  • 1 Post By cuisinartvette
  • 1 Post By Tommy the Cat
  • 1 Post By 69Chvll
  • 2 Post By usc2001gc
  • 1 Post By AZCamino
post #1 of 15 (permalink) Old Dec 23rd, 19, 12:47 PM Thread Starter
El caminos
I just happen to read a post on another thread that 1966 el caminos are really light and have better frames??
RickyHill is offline
post #2 of 15 (permalink) Old Dec 23rd, 19, 2:40 PM
Re: El caminos
My first car was a 66 El Camino with a 283 and a powerglide. Sure didnít feel light. Ha.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #3 of 15 (permalink) Old Dec 23rd, 19, 3:15 PM
Re: El caminos
I know the 68-72 has a massive frame. I don't see why the 66 would be different. The front to rear weight bias is better then the Chevelle because the elco is longer and has more steel in the back..
hydro462 is offline
post #4 of 15 (permalink) Old Dec 23rd, 19, 3:28 PM
Jon N.
Re: El caminos
For what it's worth, NHRAracer.com says a 66 El Camino weighs about 10 pounds more than a 66 Chevelle two door hardtop.
Jon N.
dyno jonn is offline
post #5 of 15 (permalink) Old Dec 23rd, 19, 7:11 PM
Re: El caminos
Like wagons they are boxed...if that means better.
shovelrick likes this.
cuisinartvette is offline
post #6 of 15 (permalink) Old Dec 23rd, 19, 8:42 PM
Re: El caminos
The Camino and wagon frames are dimensionally the same, but the wagon frame isn't boxed. I thought they were also but was recently corrected by a wagon owner.
The convertible frames are boxed, though.
hydro462 likes this.
70 Camino...Roller
Tommy the Cat is offline
post #7 of 15 (permalink) Old Dec 24th, 19, 4:18 AM
James
Re: El caminos
I weighed my 66 el Camino in the scale. It came in at 2,800 lbs. my 69 Chevelle weighs 3,500 lbs
69Chvll is offline
post #8 of 15 (permalink) Old Dec 24th, 19, 10:09 AM
rick
Re: El caminos
Boxed frames, I also thought wagon frames were boxed
shovelrick is offline
post #9 of 15 (permalink) Old Dec 24th, 19, 10:58 AM
Re: El caminos
I have one 71 and two 72 wagons. None are boxed. An el camino frame swap is a popular upgrade for a wagon (direct interchange).
hydro462 and shovelrick like this.
New Project: 72 Concours 5.3/4l60e
71 Chevelle LS2/TKO-600 on the road again...... (oo ss oo)..
Project on hold: 71 Concours Wagon
Project on hold: 70 Chevelle 5.3/4l60e
usc2001gc is offline
post #10 of 15 (permalink) Old Dec 24th, 19, 4:16 PM
Dennis
Re: El caminos
I was always told that convertibles and El Caminos used the same frames because they needed structurally beefier frames to resist twisting. Don't know how true that is, but it makes sense to me.
Too soon old and too late smart.
Progress is not always forward.
Sludge is offline
post #11 of 15 (permalink) Old Dec 24th, 19, 4:49 PM
Re: El caminos
It's true that they are both boxed but they have different dimensions. The convertible frame is a boxed hardtop frame and the Camino frame is a boxed wagon frame. The Camino/wagon frames are longer than the two door frames.
Sludge likes this.
70 Camino...Roller
post #12 of 15 (permalink) Old Dec 24th, 19, 6:49 PM
Bruce
All 1964 to 1967 Chevelle frames (including wagon and El Camino) have
115 inch wheelbases and are dimensionally the same in front of the rear axle. The El Camino and wagon have a longer rear overhang than other Chevelles and therefore a longer overall frame.
streetperf likes this.
66 El Camino 396/325HP 4-Spd
My Build Thread:
62 Corvette 327/360HP (original RF engine and Fuel Injection) (future restoration project)
66 Corvair My son's project. Small block, Powerglide, C5 differential and rear suspension
72 Chevelle wagon project
AZCamino is offline
post #13 of 15 (permalink) Old Dec 25th, 19, 1:09 AM
Re: El caminos
Thx Bruce.
Wanna fire up your Elky?
post #14 of 15 (permalink) Old Dec 25th, 19, 10:38 AM
Allen
Re: El caminos
My 64 El Camino was 3394 when I bought it. See post #2 of this thread for car details and photo of the scale readout: https://www.chevelles.com/forums/17-...el-camino.html
I'll reweigh it when finished (many changes including alu head 383, EFI, glass hood, T56, alu center 9", alu driveshaft, 4 wh disks, buckets, AC, PS, PB, tilt, etc.......) and I'm hoping to not gain much if any weight due to the hood and aluminum parts but everything else I added is heavy so likely gained some pounds... To pull ~ 600 lbs out to match the 2800 would take extreme measures, wish I could but I don't see it happening.
As another point of reference, my 71 El Camino (Alu head 383/700R4, steel hood, PS, PB, tilt, alu center 9", alu driveshaft, 4 wh disks, etc...) is about 3700 (I have scale photos somewhere).
Blown1932 is online now
post #15 of 15 (permalink) Old Dec 25th, 19, 9:12 PM
Re: El caminos
My 67 frame *camino* is boxed.
