Battery thoughts? - Chevelle Tech
 23Likes
post #1 of 33 (permalink) Old Dec 13th, 19, 11:56 AM Thread Starter
Battery thoughts?
Not sure if this is the right place for this, but I think I may be needing a new battery soon.
I have an optima that is roughly 8 years old and it may be dying. It holds a charge of 11.9(which is considered dead) but will still BARELY start the car.
My alternator is in great shape, it holds voltage right at 14.7, with everything on 14.3. I put the battery charger(rated for AGM) on it and it went to 12.4, then after about 2 hours it went back to 11.9 and has sat there for about 3 weeks now.
What batteries are you guys using? I have thought about going with an Odyssey?
Thanks!
tacomatrd is offline
post #2 of 33 (permalink) Old Dec 13th, 19, 12:07 PM
Have you load tested it yet?
I’ve only used off the shelf batteries with a tender on them with no issues.
WHT/73 is offline
post #3 of 33 (permalink) Old Dec 13th, 19, 12:17 PM
Re: Battery thoughts?
Iím done with Optima. Died right after the warranty was up. Just using a mid grade NAPA battery. At least Iím not out much if it fails.
69 461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #4 of 33 (permalink) Old Dec 13th, 19, 12:54 PM
I see we have put some Optima batteries in some equipment here with lack luster results as well. Not worth it in my opinion.
70montee is offline
post #5 of 33 (permalink) Old Dec 13th, 19, 1:18 PM Thread Starter
Iíve only used off the shelf batteries with a tender on them with no issues.
I have not, I don't have a load tester, but I can turn all the lights, fans etc on and see what it does.
post #6 of 33 (permalink) Old Dec 13th, 19, 1:41 PM
I just buy the Interstate blems now, $39 bucks, can't beat it and last as long as most other batteries.
shovelrick likes this.
68Chevele is offline
post #7 of 33 (permalink) Old Dec 13th, 19, 1:45 PM
Kurt
Interesting..... I need a battery, and didnít know Interstate offered that ....Thanx ....
1966 Black/Red SS coupe .....
thebeast is offline
post #8 of 33 (permalink) Old Dec 13th, 19, 2:04 PM
I have started buying the Walmart Everstart Maxx batteries. They are $40 to $50 cheaper than the Duralast Gold batteries at Autozone and have the same warranty (and I have a feeling that they are coming off of the same assembly line, just with a different label). They have been working just fine.
My Chevelle w/ open headers:
WakkoWarner is offline
post #9 of 33 (permalink) Old Dec 13th, 19, 2:42 PM
Eddie
I have never had issues with Optima. I have them in all my cars including wife's mini van. the one in my cutlass is probably 9-10 years old. They sit on the trickle charger most of the time and they never failed me yet.
IMO if it lasted 8 years on a car that doesn't get driven a lot, you got your moneys worth.
Eddie K is offline
post #10 of 33 (permalink) Old Dec 13th, 19, 3:01 PM
They say that Costco currently has the best price on batteries.
post #11 of 33 (permalink) Old Dec 13th, 19, 3:16 PM
Tried all of them on my ‘68, optimas, odyssey, etc. been using autozone battery in my ‘66 for 3 years, no issues.
yanniziomas is offline
post #12 of 33 (permalink) Old Dec 13th, 19, 3:59 PM
rick
I bought an Odessey battery for 1 of my Harleys once, lasted as long as any cheap battery so I wouldn't spend $$ on one, I put a Duracell from Sams Club in my 68 a few years ago and it's fine
shovelrick is offline
post #13 of 33 (permalink) Old Dec 13th, 19, 4:01 PM Thread Starter
That is honestly how I feel.
Especially for 2 of those years it only got drive ONCE each year.
I also drained it twice..once due to a dead alternator and the second due to not having enough alternator both times it came back.
I dont know what I will go with yet. I want a decent battery so it can really spin the engine over.
post #14 of 33 (permalink) Old Dec 13th, 19, 4:40 PM
I've got two Optima red tops in my 2004 Silverado 2500 Duramax diesel pickup. I installed them in January 2009 so they're almost eleven years old. Original Delco batteries lasted five years one month.
USAF Retired (1968-1988)
David Bates is offline
post #15 of 33 (permalink) Old Dec 13th, 19, 4:59 PM Thread Starter
I do like the oddesey batteries, that may be what I go with unless I find a deal on an Optima.
I want to stay with AGM.
David Bates and bradley67 like this.
