70 Chevelle cam change w engine in car - Chevelle Tech
 2Likes
post #1 of 22 (permalink) Old Dec 4th, 19, 6:32 PM Thread Starter
Hey all - Planning a winter project here. My Chevelle has a fairly weak 454 and it needs a little pick me up. Currently its a 86 454 w peanut ports, mild cam, air gap and 650 carb. I picked up a set of closed chamber Vortec heads with some bowl work and upgraded springs and hardware, voodoo Hydraulic FT cam 60203 227/230 @.050 , .542/.554, Quick fuel SS 830 carb, new pushrods and rockers, etc.. It has hooker headers (i believe 2") and 2 1/2" exhaust too. My plan is to pull the heads and cam in the car...am I nuts? Or should I pull the engine? I know if I pull the engine I cant just leave the rest alone. Was hoping for a relatively quick and budget type upgrade.
If I were to do this in car, I'm guessing grill might have to come out for cam access. Also, looks like the oil pan will need to be dropped a bit, and I can only imagine these headers are going to be a bear to get in and out. Any other road blocks you can think of? I've done this before on Mopars, but my first Chevelle.
Thanks for any pointers!
Tonys451 is offline
post #2 of 22 (permalink) Old Dec 4th, 19, 6:41 PM
Re: 70 Chevelle cam change w engine in car
The center support where the hood release is located. I removed the engine mount bolts so I can pivot the engine to one side or the other.
oldcutlass is offline
post #3 of 22 (permalink) Old Dec 4th, 19, 6:45 PM
Gary
If it's a non- A/C car sould be easy to to do in the car.
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is offline
post #4 of 22 (permalink) Old Dec 4th, 19, 7:00 PM
Easy job. Done many this way. Remove radiator and possibly hood release. Get a 2 piece timing cover to ease future cam changes in car. The hardest part will probably be getting the distributor back in. Set timing mark at #1 and mark intake and distributor for reference. Or put tape on the firewall and mark dist location there.
mrpaticular is offline
post #5 of 22 (permalink) Old Dec 4th, 19, 8:11 PM Thread Starter
Thanks for the tips guys! My car is non AC, so shouldn’t be as bad.
Tonys451 is offline
post #6 of 22 (permalink) Old Dec 5th, 19, 9:44 AM
Stop questioning yourself and just do it. Lots of help here if needed. You might put progress reports here for us to follow and offer suggestions.
post #7 of 22 (permalink) Old Dec 5th, 19, 9:51 AM
Mr Bill
Tony,
Camshaft is 23" long. That should give you an idea if you want to measure.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #8 of 22 (permalink) Old Dec 5th, 19, 10:17 AM
Bart
the worst part will be lifting the heads off the block and over the fender. lol I have the same cam, you will like it.
Bart_Swisher is offline
post #9 of 22 (permalink) Old Dec 5th, 19, 10:28 AM
Mr Bill
I was thinking the same thing Getting too old for that stuff. LOL
I would definitely pull the hood off and get it out of the way.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #10 of 22 (permalink) Old Dec 5th, 19, 10:58 AM Thread Starter
My lower back is gonna love it! Good to hear about the cam. Thanks
Tonys451 is offline
post #11 of 22 (permalink) Old Dec 5th, 19, 11:28 AM
Don't lift the heads over the fender. Stand between engine and core support and place them on a table. Help is advisable.
ChevelleFan70 likes this.
post #12 of 22 (permalink) Old Dec 5th, 19, 11:30 AM
Cam is 23" but don't forget the length of the handle if using one so you can prelube on a bench.
post #13 of 22 (permalink) Old Dec 5th, 19, 11:32 AM
You will have to take the oil pan off for a new gasket. Don't forget to change the filter as the prelube can clog them. Break in oil also.
post #14 of 22 (permalink) Old Dec 5th, 19, 12:06 PM Thread Starter
Thanks for all the pointers Mrparticular. I appreciate them
Tonys451 is offline
post #15 of 22 (permalink) Old Dec 6th, 19, 8:40 PM
rick
When I changed iron heads in the car my front end/dog house was off and still used a cherry picker to lift the second head after killing my back on the first head then used the cherry picker to reinstall the 063 heads, also used it to lift the PP head I used as a guide for the Isky piston valve notch tool, IIRC one side of engine MM had to be involved and raise the engine to get the header in, DRV side I think
shovelrick is offline
