Wider lsa for performance vs tight - Page 5 - Chevelle Tech
 60Likes
post #61 of 85 (permalink) Old Dec 5th, 19, 10:40 AM
Re: Wider lsa for performance vs tight
Originally Posted by 77 cruiser View Post
Tempted to try a different cam in my 421.
Chris's cam in there now.
227/239
.359/.340
107lsa/103icl
Other cam that was speced by a well known guy.
232/240 @.050"
.360"/.365" Lobe Lift
112 LSA
What would you expect to see with this?
What are you wanting to achieve?
Roadknee is offline
post #62 of 85 (permalink) Old Dec 5th, 19, 12:46 PM
Reason I had it speced was to see if I could broaden torque & get it to 60' a little better. Guy said it would pull better under peak since my converter stalls 12-1300 below peak tq.
In reality I probably wouldn't achieve anything except a slightly smoother idle & move peak hp up a bit. My thoughts.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #63 of 85 (permalink) Old Dec 6th, 19, 6:41 AM
I've always stayed conservative with valve timing, tending to 106-108 ICL, which typically works well with a LSA at 110-112. I think what's missing most in this thread is the understanding and explanation that once you set the intake opening and closing points for the combination, you set the exhaust timing events, net is ICL and LSA. The discussion of wider LSA to bleed off cylinder pressure has nothing to do with LSA, it is ICL that causes that. I've ran 114 LSA cams, which typically install at 110-112 ICL, guess what, the idle changed noticeably at 104 ICL (intake opened early creating that bumpy idle). {FWIW, this was way before the days of information on the internet, this is what we did to try to wake up an engine and didn't have deep pockets to just go buy new parts}.
Status: Car-Less
GRN69CHV is offline
post #64 of 85 (permalink) Old Dec 6th, 19, 10:35 AM
Dale
Originally Posted by cstraub View Post
Thank you sir for the DATA. See you next week.
What's also impressive is how his 555 idles relatively smooth with, I think, a 107 LSA. It sounds more like a RV cam (said respectively).
66 Chevelle
1/8 mile
1/4 mile
Building more of a race car than driver but driving it more than I race. "simple old school shake, rattle & roll".
Monk is offline
post #65 of 85 (permalink) Old Dec 6th, 19, 11:05 AM
Dale
...LSA......Advertised Duration...
Chris, can you say if you spec your camshafts LSA off lobe "centerline" or "lobe peak"? I remember an argument about this on another forum and wonder what your thoughts are on this?
Also, can you say what lift you spec advertised duration numbers? Thanks-
66 Chevelle
1/8 mile
1/4 mile
Monk is offline
post #66 of 85 (permalink) Old Dec 6th, 19, 2:14 PM Thread Starter
So what would be a happy medium of opening/closing events that dont beat things up, make power and have better idle quality than the proverbial tight lsa?
Examples
Is that 232/240 a Jones grind?
cuisinartvette is online now
post #67 of 85 (permalink) Old Dec 6th, 19, 3:06 PM
Examples
Good guess.
77 Monte
post #68 of 85 (permalink) Old Dec 6th, 19, 7:41 PM
Gerry
Less cranking compression and loss of power.
Help us understand how you came up with this assessment of the other cam grind after everything else you (and others) explained about how difficult it is to compare two cams?
Very little information was given on the cam grind.
Iím just trying to learn here.
67 SS BBC
4.11's
bradley67 is offline
post #69 of 85 (permalink) Old Dec 7th, 19, 5:59 PM
Russ
There's an Excel spreadsheet over on a HP Tuners forum that I used to adjust fuel injector timing. You can enter different cam specs to see how that affects overlap. I've no idea how accurate -- or not -- the valve lift curves are in the graphs. As I said, we used that spreadsheet to play with injection timing, not cam design. I tried to attach the xlsx file but apparently files with that extension aren't allowed so I renamed it as a ".txt" file. This version of the spreadsheet has cam specs for a LPE GT9 cam that I'm using in a supercharged Gen IV LS.
pannetron is offline
post #70 of 85 (permalink) Old Dec 7th, 19, 9:51 PM
I just found a quote from the late great expert cam designer Harold Brookshire, that I had saved in my notepad, and this has to do with an earlier post I made in this thread. I guess i was getting the [email protected] specs mixed up with [email protected] specs which is what Harold often focused on to display what he called "MAJOR INTENSITY"of a cam lobe profile which is the difference in degrees between the [email protected]" lift and the [email protected]" lift of any cam. The lower that this "major intensity" number is, then the steeper the ramps of the camshaft lobe are. What this means is, the closer in degrees that the [email protected]" spec is to the [email protected]" spec, the steeper the closing and opening ramps of the lobe is, and the bigger the "area under the curve" of the lobe profile is. This "major intensity" number of the cam lobe profile, represents how long and wide the valves are held open by the cam lobe profile. I have not found any racing cam lobe profiles with a Major intensity number lower than 27 with most high perf street cam lobes having a Major intensity number of 34-39 and going as high as 42. Harold's cam family that he mentioned here having a MI number of 31 represents some very intense lobe profiles which should make some major power in properly matched engine combinations. Here's is quote below: (BTW, I do not know what he ment by "Peak positive acceleration rates" concerning lobe profiles)....
"I have a family of cams in .725", .775", .825" and .875" that all have the same opening ramps, and the same closing ramps, even the same peak positive acceleration rates. I use the .725" lift cams as daily street drivers in 496-540 engines. All lifts are in every 4 degree spacings, and we have had no trouble in valve spring life, either on the street or the track.....
LSA for the stroke and stick transmission would be 114. This would flatten out your torque curve, so you could try to hook it up on the street. The torque curve would be very flat. A 499 with a 284/292 on a 112 had 625 ftlbs at 5000 and 7200, 689 at 6100.
You would have usable torque even at 2500.
This family of cams has 31 degrees Major Intensity, so a 276/288 at .050 would be 307/319 at .020. If you want to go smaller at .050, we should look at lower valve lifts, like the .775" or the .725" series."
bradley67 likes this.
BillyGman is offline
post #71 of 85 (permalink) Old Dec 7th, 19, 11:11 PM
Mark
My memory of going through lobe catalogs is they give you 0.050 and 0.200 durations, but not 0.020.
I shouldn't answer for Chris, but my guess is the 2 profiles are fairly close but the one with the larger LSA will spend less time with the valves closed, which typically lowers compression.
69 Chevelle Malibu
427 sbc, TH400, 3.55 12-bolt
n/a best: 11.24sec/118mph
MadmanMark is offline
post #72 of 85 (permalink) Old Dec 7th, 19, 11:16 PM
Mark
I just found that most advertised durations are at 0.020 but can vary between 0.018-0.022 depending on advertising requirements.
69 Chevelle Malibu
post #73 of 85 (permalink) Old Dec 8th, 19, 10:07 AM
This is the 2 cams. Chris's cam closes the intake 4.5 deg. sooner that's where the higher cranking comp. would come in.
Name:	Cam compare_html_4ea83be3.jpg
77 Monte
post #74 of 85 (permalink) Old Dec 8th, 19, 11:19 AM
Bill, so the "MI" number is the .020 - the .050 number?
WHT/73 is offline
post #75 of 85 (permalink) Old Dec 8th, 19, 12:05 PM
Yes. And 31 is pretty intense. Most cam lobe profiles that I've looked at don't get that low with the MI number. I guess Harold found a way to design lobe profiles that are that radical to not beat up valve train parts. The guy was the best at what he did.
