Pump gas 557 Build Dyno results.... - Chevelle Tech
 16Likes
post #1 of 18 (permalink) Old Nov 27th, 19, 10:53 AM Thread Starter
4.5 x 4.375 x 6.385" 9.800 Deck ***********edited by Tom to correct per OP
AFR Castings with Foxwell Port Program
Sniper Jr Fully Ported by Foxwell
QFT Dominator
Lemons 2 1/8" header **Note over the Dyno 2.5" headers the lemons gain a max of 60#/ft and an average of 35#. Nice Gain
Straub Custom Solid Roller 4/7
Morel Black Mamba
Stef's Wet Sump Chassis Pan
Star Vacuum Pump
Driven Oil
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 18 (permalink) Old Nov 27th, 19, 1:03 PM
Guy
Re: Pump gas 557 Build Dyno results....
Chris,why did you use a tall deck block ??
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is online now
post #3 of 18 (permalink) Old Nov 27th, 19, 1:21 PM Thread Starter
Guy
I will revise, it is a low deck...6.385 rod.
GuysMonteSS likes this.
Chris Straub
cstraub is offline
post #4 of 18 (permalink) Old Nov 27th, 19, 1:22 PM Thread Starter
To late to edit...
GuysMonteSS and badrad like this.
Chris Straub
cstraub is offline
post #5 of 18 (permalink) Old Nov 28th, 19, 10:26 AM
Interesting results with the headers shows how detrimental going to big on something can have on the combo.
steelcomp likes this.
78 Camaro,3495,Driven to the track.
UD Harold hydraulic roller
REC90/112
1.27
5.87 @116.76
9.24 @141.64
vp 109
1.35
[email protected]
[email protected]
Jesse 496 is offline
post #6 of 18 (permalink) Old Nov 28th, 19, 5:46 PM
yeah and it's worse on the real road or track. Still can't drive a dyno or a flowbench.
edited your OP per your update Chris
post #7 of 18 (permalink) Old Nov 28th, 19, 8:06 PM
Jarad
Very nice combo.
JBoggs is offline
post #8 of 18 (permalink) Old Nov 29th, 19, 10:28 AM
Lew
What cc are the intake runners?
Lew540 is offline
post #9 of 18 (permalink) Old Dec 1st, 19, 1:48 PM
Scott Foxwell
These runners are probably in the 340cc range. Haven't checked one so I'm guessing.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #10 of 18 (permalink) Old Dec 1st, 19, 2:42 PM
You guys just don't like oil pressure.
Yeah, yeah, it's a dyno
BossHogg69 likes this.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #11 of 18 (permalink) Old Dec 1st, 19, 3:07 PM
Scott Foxwell
That last pass is the only one where oil pressure fell off like that. I think a few things played into it (as usual); yes, it's on the dyno and sitting flat, so a lot of oil is draining back to the front of the engine into the shallow part of the pan. That oil is going to get picked up by the crank, especially with a 4-3/8 stroke and short rods. That becomes a windage issue and it's oil NOT getting back in the sump, so on a longer, higher rpm pull like that, the oil level drops significantly and takes longer to recover. That stroke and rod combo, in and of itself, is going to start showing windage issues above 7000, which is where it showed on the dyno. If you look at the other pulls, the oil pressure was steady to 7K. On that pull, I also think the oil got hot. We heated up the engine to do the lash. Water temp came down pretty quick as it was a cool day so we had to heat the water back up and I think the oil came up a little hotter than usual. (We didn't have the temp probe in the pan because of the headers). By the time we did that last pull I'm guessing oil was over 200*. I can tell by the way it didn't recover at idle very quickly at the end of the pull...that, and the oil level was lower than normal.
I've said it before and I'll say it again...yes, it's the dyno, not a moving engine. I've had 3 drivers put go-pro's on their oil gauges going down the track and never an issue, ever. Never had a single bearing issue in any engine I've ever built, so I quit worrying about it.
Here's a vid of the pull:
https://www.facebook.com/17683172238...649326687/?t=2
FOXWELL MOTORSPORTS
Straub Technologies
post #12 of 18 (permalink) Old Dec 1st, 19, 3:35 PM
Scott Foxwell
Few more pics;
Big 'ol headers...just like heads that are too big...can kill power.
Best pull with customer headers before lash change. Notice how power peaks around 6700 and just sort of hangs out for a few hundred rpm. Also notice oil pressure is solid.
This is the difference between dyno headers and customer headers;
And here's what .004" of lash can get you:
GuysMonteSS and horton409 like this.
FOXWELL MOTORSPORTS
Straub Technologies
post #13 of 18 (permalink) Old Dec 4th, 19, 7:50 PM
Curious to know the cam spec`s.
Care to share ?
68 BISCAYNE 4060lb
468-9.4:1
1.76 60FT Drag Radials
11.69 [email protected] 116.30 MPH
BigRed-L72 is offline
post #14 of 18 (permalink) Old Dec 5th, 19, 9:52 AM Thread Starter
Care to share ?
Mid 700 range lift
Duration high 260 range/low 270's
LSA lower than 110
Cam is customers and he wants exact specs to himself.
Chris Straub
cstraub is offline
post #15 of 18 (permalink) Old Dec 6th, 19, 10:15 AM
Originally Posted by cstraub View Post
Mid 700 range lift
LSA lower than 110
Thanks Much
68 BISCAYNE 4060lb
468-9.4:1
