Torque Converter - Chevelle Tech
 41Likes
post #1 of 59 (permalink) Old Nov 23rd, 19, 7:10 PM Thread Starter
Torque Converter
Posting here because this is more performance oriented . Turbo 400 , 3.73 , 28'' tire Motor is 11.1 comp 509 cid. with260 - 266 @ 50 duration cam . Just doing short trips around town maybe 10 - 20 miles highway 70 -80 mph. I know a lot here do both street and strip with there rides looking for opinions on converter sizing and brand let me know what you have or recommend . Thanks in advance
blasttime is offline
post #2 of 59 (permalink) Old Nov 23rd, 19, 7:18 PM
Re: Torque Converter
I have 2 Edge converters and I'm very happy with them. They are built for your combo so there's no compromises. Give them a call.
ChevelleFan70 likes this.
70 Camino...Roller
Tommy the Cat is offline
post #3 of 59 (permalink) Old Nov 23rd, 19, 7:46 PM
Gary
Ultimate Converter concepts.. Give Lenny a call best converter I've ever had..
DragRac69 likes this.
1955 Chevy
496 bbc
best 60' 1.36
best ET 6.23
best MPH 110.67
TAG55 is offline
post #4 of 59 (permalink) Old Nov 23rd, 19, 7:50 PM
Like 'The Cat' said, choose a brand, call them, and have one built for your combo. The right converter makes a huge difference. Anything off the shelf is just a waste of money.
Steve R, BillyGman, WHT/73 and 2 others like this.
69SS454 is offline
post #5 of 59 (permalink) Old Nov 23rd, 19, 8:30 PM
I agree with Bill but also ran pretty good with a TCI street fighter too. Different combo tho.
I had great results with Charlie at ATI. He made me a 8" converter that drove almost as tight as the 10" street fighter.
That converter (and trans) is still in service in my sons 78 malibu with totally wrong gearing (3.42's) for it and still clicked off 1.53 60's.
He drives it all the time too.
Not that you would want an 8" converter just passing along our results.
Oh yeah, this was/is a th 350 which I think can be used for a 400 too.
71350SS likes this.
WHT/73 is offline
post #6 of 59 (permalink) Old Nov 23rd, 19, 9:53 PM
Best 10" cheap converter's I used are the Jeg's XHD models. Lots of different stalls and have anti-balloon plates front and rear, all the good stuff inside and worked great. They are made by Transmission Specialty's, most of them are around $362 bucks. My 4100 stall converter from Jeg's did just that 4100, on the money and it not loose on the street.
WHT/73 and fr8dog like this.
68Chevele is offline
post #7 of 59 (permalink) Old Nov 24th, 19, 12:13 AM
MARK
What would you guys consider a good 60 foot for a high 10 sec NA 3600 pound car, 6.80 in the 1/8 mile? ATI no longer makes a good 8 inch foot brake converter.
Machined GM production heads
Oil pan modifications
VORTECPRO is offline
post #8 of 59 (permalink) Old Nov 24th, 19, 9:20 AM
Mark that's a loaded question lol.. we talking A stock or your average Joe's street/strip full weight car. I'll bite my old 427 ran 6.70/80 in the 1/8 and 10.70's in the 1/4 @3775 the 60's were always in the mid 1.40's that was on a 289 biased slick. I thought that was about right for what the car was,looking back it would have been fun to try a radial slick and see how it would have worked. I know others that have much better 60's but the cars are dedicated race cars. FWIW my new setup has been 1.31 with less gear and converter and more weight...but more power.
427L88 and TAG55 like this.
B433 is offline
post #9 of 59 (permalink) Old Nov 24th, 19, 9:38 AM
ATI doesn't make an 8" converter anymore or good enough for your specs?
Either way I'm keeping mine, well it's on "loan" to my son.
WHT/73 is offline
post #10 of 59 (permalink) Old Nov 24th, 19, 9:55 AM
I have a TCI converter, but not one of their run of the mill streetfighter deals. it's a high dollar 10" PRO-X race converter, so you wouldn't want nor need that.
If I were you, I would call ATI racing about their 10" Streetmaster. People I talk to who had TCI converters rave about them. This one is usually about $550 but it often doesn't pay to get a cheepie off-the-shelf $300 deal. It's hit or miss. You might luck out, or you might have to spend more money on another one. ATI will ask you about approx engine power, rear tire height, approx vehicle weight, cam specs, engine size, rear gear ratio, and first gear trans ratio, just like any good reputable converter place will. If a place doesn't require that info from you before you buy, then it's a cheap peice of garbage....
ATI Streetmaster Torque Converters for Street and Strip use!
BillyGman is offline
post #11 of 59 (permalink) Old Nov 24th, 19, 11:53 AM
Call FTI - they will hook you up. No affiliation with me other than I am a happy customer.
https://ftiperformance.com
lucifershammer is offline
post #12 of 59 (permalink) Old Nov 24th, 19, 12:54 PM
Greg.
May 26/09 bought new TCI # 890-240901 .... 2400 - 2600 Stall
http://www.jegs.com/i/TCI/890/240901/10002/-1 TCI 11" Breakaway
Dual Bolt Pattern / Non Lock-up / 168-Tooth / with Front Anti-Balloning Plate
It performed great on the Street and okay at the Track for 10 years in my TH400
See my sig for details
Fall 2018 the Shift from 2nd to 3rd was lagging/slow so in 2019 decided to rebuild the TH400
May 2019 bought a 9.5" Race/Street - Dual anti-ballooning plates (where applicable), triple bearing package,
full furnace brazing, all fins are hand welded for extra reinforcement, bulletproof sprag and stator design
great for bracket cars or serious street cars. Super efficient.
Dynamic Converters / Pro-Formance Transmissions
gave them the needed specs so they could build to suit my Engine/Car and the way I use it
It has performed great on the Street and at the Track
67 Chevelle Malibu SS Cdn
Born 283 / PG / A51
60' = 1.664
1/8 = 7.532 et / 91 mph
1/4 = 11.814 et / 115 mph
60' = 1.547
1/8 = 7.311 et / 91.76 mph
1/4 = 11.595 et / 114.28 mph
Kirk's67SS is offline
post #13 of 59 (permalink) Old Nov 24th, 19, 2:29 PM
When my car had the 406 in it running 6.80's in the 1/8 I had my TCI 8" converter in it, 60 ft. was 1.48 at that time. Probably be better with a converter from Lenny at ultimate, that guy knows his stuff.
post #14 of 59 (permalink) Old Nov 24th, 19, 2:48 PM
My 8" treemaster did 1.45 leaving off idle with my 10.5:1 406.
900 rpm. 6.75
BillyGman likes this.
WHT/73 is offline
post #15 of 59 (permalink) Old Nov 24th, 19, 5:10 PM
MARK
I've seen this @ 3650 with 514 HP 29.3 baro
1.383 4.306 6.810 98.18 8.983 10.838 120.79
