SB2.2 Nascar small block - Chevelle Tech
 14Likes
post #1 of 21 (permalink) Old Nov 16th, 19, 8:14 PM Thread Starter
Just got back from a estate sale. Picked up a PME SB2.2 complete nascar motor. Looks like a 184 Block and 12480011 heads. Anyone know the specs on these motors. From my research its worth some cash. Not sure what to do with it. Part, flip or run it.
Sure looks to have some sweet parts inside
64 Chevelle 496
StevenS is offline
post #2 of 21 (permalink) Old Nov 16th, 19, 8:37 PM Thread Starter
Re: SB2.2 Nascar small block
Originally Posted by Steve R View Post
There is a 10051184 block listed on eBay with an opening bid of $700. Last time it was listed it, at the same price, it received no bids. I donít think these caught on beyond their primary use and probably donít have much value on the secondary market. When you checked, did you look at sale prices or asking prices?
Steve R
This is a complete running engine. Sold completed auctions were around 8 to 9K. Not saying mine is worth that much. This has a dry sump with serpentine belt setup and MSD ignition. So pan to intake and clutch to water pump.
64 Chevelle 496
StevenS is offline
post #3 of 21 (permalink) Old Nov 16th, 19, 9:34 PM
rick
SOOO... now what year Chevelle are you going to buy to put it in???
badrad, JimM1970 and Blown1932 like this.
shovelrick is offline
post #4 of 21 (permalink) Old Nov 16th, 19, 9:55 PM Thread Starter
Like to drop it in Vortecpros 68 just to do a test blast.
shovelrick and CRV CRW like this.
64 Chevelle 496
StevenS is offline
post #5 of 21 (permalink) Old Nov 16th, 19, 10:25 PM
Chuck it in my '69. I think it would like the gears and converter.
shovelrick likes this.
70 Camino...Roller
Tommy the Cat is offline
post #6 of 21 (permalink) Old Nov 16th, 19, 10:34 PM
rick
Tom I bet that 307 surprises people with your cars trans/conv/gears when you tell'em it's a 307
Steve you could always buy a mid 50's Dodge truck (I had a 56) and drop it in that then you'll have all Big 3's covered
StevenS likes this.
post #7 of 21 (permalink) Old Nov 16th, 19, 10:45 PM
It probably would if it didn't have several burned valves! Right now I can't give it more than half throttle without it sneezing uncontrollably out of both ends.
70 Camino...Roller
post #8 of 21 (permalink) Old Nov 16th, 19, 10:48 PM Thread Starter
Yea that would work well and be a blast. Might throw it on the dyno and see what numbers it will make.
64 Chevelle 496
StevenS is offline
post #9 of 21 (permalink) Old Nov 16th, 19, 11:37 PM
Nice score Steve !!!! what else sold at that auction ?
This site has some info on the heads and block
Chevy Casting Number identification - Block casting numbers
pretty accurate information too.
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #10 of 21 (permalink) Old Nov 16th, 19, 11:42 PM Thread Starter
Just your normal household stuff. Which ofcourse I did not look at. I think I might go to more estate sales. Thanks for the info.
71350SS likes this.
64 Chevelle 496
StevenS is offline
post #11 of 21 (permalink) Old Nov 17th, 19, 12:09 AM
Here's the heads info :
12480011----SB2.2 head 48 ~ 54 CC angle plug 284 CC intake runner Bare heads.
I can't find the block--yet
71 El Camino SS
71350SS is offline
post #12 of 21 (permalink) Old Nov 17th, 19, 10:53 AM
Jason
The R07 architecture replaced the SB2.2 in NASCAR competition in 2007.
The SB2.2 engines were used in many different racing series and on many different track sizes. Could be 500 HP to 900 HP depending on what it was built for and who built it.
In general, at 358 ci, plan on about a 8000+ RPM converter to make it run decent.
There is lots of SB2.2 stuff out there that has been "worked on" by the wrong hands and more importantly the wrong noggin.
Steve R and StevenS like this.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
post #13 of 21 (permalink) Old Nov 17th, 19, 12:32 PM
I have not seen one of those since the 90's pro mod era.
mrpaticular is offline
post #14 of 21 (permalink) Old Nov 17th, 19, 1:01 PM
427 ci SBC and slap those SB2.2 heads on it. Hopefully can still use the dry sump oiling system and accessories.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #15 of 21 (permalink) Old Nov 17th, 19, 1:57 PM Thread Starter
Looks like we are going to go thru the motor and drop it in my friends chassis fox body. Should be fun.
71350SS and Hotwire like this.
64 Chevelle 496
StevenS is offline
