Roller Cam .116 Endplay? - Chevelle Tech
 11Likes
post #1 of 19 (permalink) Old Nov 12th, 19, 7:36 AM Thread Starter
rick
I installed a Lunati 20010722 hyd. roller cam with retaining plate in my '75 MKIV block and have .116 back and forth, I stacked my feeler gauge .026 .028 .030 .032, when I bolt the rollmaster timing gear with a Torrington bearing to the cam will that take care of the endplay? or do I need shims somewhere? I did do a search first but only came up with cam button threads, TIA, rick.
I have to chase the threads on left button head hole it's not tight but other side is, and anyone use blue lock tight on those?
ID:	607622   Click image for larger version
shovelrick is offline
post #2 of 19 (permalink) Old Nov 12th, 19, 7:58 AM
Scott Foxwell
Re: Roller Cam .116 Endplay?
You have to attach the cam gear. That sets the thrust clearance. I use red loctite.
FOXWELL MOTORSPORTS
steelcomp is offline
post #3 of 19 (permalink) Old Nov 12th, 19, 8:10 AM Thread Starter
rick
Thank You, I was a little worried when I seen that much play and this is my first roller cam
steelcomp likes this.
post #4 of 19 (permalink) Old Nov 12th, 19, 9:14 AM
Mr Bill
Make sure the timing set is the correct one for the new style camshaft like you have.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #5 of 19 (permalink) Old Nov 12th, 19, 1:30 PM Thread Starter
rick
hi Bill, its a timing set from Strain tech thats for a roller cam and can use a stock type cover but I bought an alum cover 😀
post #6 of 19 (permalink) Old Nov 12th, 19, 1:31 PM Thread Starter
rick
Straub, auto correct lol
post #7 of 19 (permalink) Old Nov 12th, 19, 9:12 PM
Im sure it will be fine. Does it have thrust bearing on the timing set?
shovelrick likes this.
461" BBC 11.25:1 Compression
Orig Exhaust Manifolds
Straub (Clay Smith) Hyd Roller cam, .050 229/241 .600/.569 109.
TH400, 3500 stall, 4.10 12 bolt posi
rp930 is online now
post #8 of 19 (permalink) Old Nov 12th, 19, 9:18 PM
Mr Bill
hi Bill, its a timing set from Strain tech that's for a roller cam
Yes but is it for a new style "step nose" cam like you have ?
By the way personally I think the torrington bearing is just one more thing to go wrong. Especially in this application.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #9 of 19 (permalink) Old Nov 13th, 19, 1:12 AM
Never had a problem with the bearing and I think it will be hard to find a set for this application without it.
rp930 is online now
post #10 of 19 (permalink) Old Nov 13th, 19, 7:07 AM
Mr Bill
To be honest with you I have never seen a timing set with the bearing for the late model setup, but I haven't really looked for one. Every 502 Mercruiser engine in the world uses the stock GM single roller setup with no bearing and they run hundreds of hours at near wot with no problems. Cloyes has a double roller setup for them with no bearing.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is offline
post #11 of 19 (permalink) Old Nov 13th, 19, 7:45 AM Thread Starter
rick
It's made for this application I'm told, MKIV block, step nose cam and thrust retainer, dual roller and will fit under factory cover, I changed my mind on factory cover and bought an alum. summit cover, I'll take a pic today and post it, nice set and made in Australia, RollMaster is brand name, I also have Howards Max Effort roller lifters and hoping all these needle bearings or roller pins in these parts stay put.
post #12 of 19 (permalink) Old Nov 13th, 19, 9:22 AM
Scott Foxwell
There is absolutely nothing wrong with the Torrington bearing and it does reduce a significant amount of friction. The Gen6 timing set will only fit the step nose cam. Aside form the step, the Mk4 gear won't physically bolt to it because the bolt pattern is different. You can't mix the parts.
FOXWELL MOTORSPORTS
post #13 of 19 (permalink) Old Nov 15th, 19, 6:14 AM
https://www.chevelles.com/forums/sho...d.php?t=319529
The only one I've ever seen blown up.
post #14 of 19 (permalink) Old Nov 15th, 19, 9:47 AM Thread Starter
rick
Here's a couple pics, going to test fit this afternoon
ID:	608058   Click image for larger version
ID:	608060   Click image for larger version
post #15 of 19 (permalink) Old Nov 15th, 19, 7:15 PM Thread Starter
rick
The gear fits the cam perfectly but when I ordered parts & fasteners I forgot to order arp cam gear bolts I recently ordered the Brodix heads from Mike Lewis so I have a few weeks before it's ready to go back to Johns dyno at Muscle Machining & Race Engines, hoping before Xmas
PS seen the thread that the Torrington bearing came apart due to low/no oil pressure , thinking of pre oiling it or Lucas syn assembly lube?
