MSD 6A digital - Chevelle Tech
 5Likes
post #1 of 33 (permalink) Old Nov 9th, 19, 7:17 PM Thread Starter
MSD 6A digital
I have 2 of these. First one died and was repaired by MSD and failed a second time. Purchased another and that soon failed. Is there a way to test them off vehicle ? Not buying anymore.
Slick87gn is offline
post #2 of 33 (permalink) Old Nov 9th, 19, 8:09 PM
Re: MSD 6A digital
Yes, do not use an MSD Blaster coil of any kind.
LeoP likes this.
Dave Ray is offline
post #3 of 33 (permalink) Old Nov 9th, 19, 11:03 PM
Re: MSD 6A digital
Most failures are due to low supply voltage.
oldcutlass is online now
post #4 of 33 (permalink) Old Nov 9th, 19, 11:05 PM
Kerry
I have also seen them fail from low voltage. MSD specs say that it will run with less than 12 volts (such as when a car has poor alternator output at idle), but my experience is that as soon as voltage drops below 12 the msd will misfire.
pockets is online now
post #5 of 33 (permalink) Old Nov 10th, 19, 12:16 AM
Re: MSD 6A digital
Bu the voltage should NEVER drop below 12.2 volts anyway, regardless of what ignition system is used. If the voltage is dropping below that during engine operation, then there's either a defective alternator at fault, or a serious wiring problem. This is not neccessarily directed at you, but this reminds me of a trend for some guys to put at least $15K- $30K in a 40 or 50 year old muscle car, and then skimp on the wiring harness by using the original onethat's nearly a half centrury old, or buying one cheap from a junk yard that's just as old, simply because they're too cheap to spend $500 on a new wiring harness.
BillyGman is online now
post #6 of 33 (permalink) Old Nov 10th, 19, 10:34 AM
Re: MSD 6A digital
I remember reading somewhere that Blaster coils were made in 3 different locations. Only one was any good. Look on the bottom of your coil to see location. China was one of the bad ones.
mrpaticular is offline
post #7 of 33 (permalink) Old Nov 10th, 19, 10:38 AM
Re: MSD 6A digital
I agree about old wiring not flowing like it should. Check every connector for voltage. Simple reference is why do we change spark plug wires that still look good? Even new ones are possibly different from each other. Remember misting your wires with water at night and starting the engine.
post #8 of 33 (permalink) Old Nov 10th, 19, 11:43 AM Thread Starter
Re: MSD 6A digital
A new harness from AAW was the first thing changed. Using a delco HEI distributor along with the internal coil. Dave Ray how do you test it ?
post #9 of 33 (permalink) Old Nov 10th, 19, 12:35 PM
Marcus
Re: MSD 6A digital
Do you use the low resistance bushing?
I would change to one if not and a modified dust cover so you can run a extern coil.
https://www.holley.com/products/igni...nts/parts/8412
https://www.holley.com/products/igni.../parts/8401MSD
One of these coils should work if you decide to try the remote coil the fast is made in Us according them, summit and jegs
https://www.fuelairspark.com/fast-ps...ance-coil.html
https://www.jegs.com/i/FAST/244/730-0060/10002/-1
https://pertronix.com/pertronix-4501...itional_tabbed
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #10 of 33 (permalink) Old Nov 10th, 19, 1:04 PM
Re: MSD 6A digital
I was told that the 8253 was a good coil, but it is a Blaster. My digital six is out of the Chevelle 8 years ago, now it's in the Nova.
Malibu ss 64 likes this.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #11 of 33 (permalink) Old Nov 10th, 19, 1:04 PM
Re: MSD 6A digital
I was told that my new 8253 was a good coil, but it is a Blaster. My digital six is out of the Chevelle 8 years ago, now it's in the Nova.
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #12 of 33 (permalink) Old Nov 10th, 19, 4:26 PM
Mike that's the coil I run...and for what it costs it better be a good coil Lol!!
B433 is offline
post #13 of 33 (permalink) Old Nov 10th, 19, 6:01 PM
Re: MSD 6A digital
LOL, you ain't kidding.....
Cale Aronson
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #14 of 33 (permalink) Old Nov 10th, 19, 7:44 PM
Jack
Re: MSD 6A digital
I use the same coil many years.. No problems to date.
aukai likes this.
Matthew 22: 37-39
R.I.P. Mike Romeo
DragRac69 is online now
post #15 of 33 (permalink) Old Nov 11th, 19, 9:49 AM Thread Starter
Re: MSD 6A digital
Used a MSD low resistance bushing.
