454 shim head gasket - Chevelle Tech
post #1 of 9 (permalink) Old Oct 31st, 19, 11:18 AM Thread Starter
Curious to know if a shim head gasket can be used on an '86 block w Vortec heads? I've heard certain gaskets might be an issue with these heads. The compression benefit of the shim gasket would be nice, be definitely want a good leak free seal first and foremost. Thanks in advance for any info.
Tonys451 is offline
post #2 of 9 (permalink) Old Oct 31st, 19, 12:30 PM
Re: 454 shim head gasket
Should be fine Tony. Call Felpro and ask them if there shim gasket will work with those vortecs.
Aaron is offline
post #3 of 9 (permalink) Old Oct 31st, 19, 2:34 PM
What is the quench distance now, and what will it be after the gasket change? If it ISN'T right, expect problems in a lot of different areas.
Dave Ray is offline
post #4 of 9 (permalink) Old Oct 31st, 19, 5:19 PM Thread Starter
good place to start. Thank you
Tonys451 is offline
post #5 of 9 (permalink) Old Oct 31st, 19, 5:24 PM Thread Starter
I dont know the quench distance. Currently an '86 engine w peanut port heads, w cam and intake change. I can only guess that the pistons are factory stock. Havn't pulled the old PP heads yet. What kind of problems are we talking?
Tonys451 is offline
post #6 of 9 (permalink) Old Nov 1st, 19, 2:47 PM
Surface finish on OE SBC heads is probably not good enough for a shin gasket. Not sure about BBC heads.
novadude is offline
post #7 of 9 (permalink) Old Nov 2nd, 19, 9:24 AM Thread Starter
My heads are brand new and the surface looks freshly machined. Haven’t verified trueness but they “look” very good
Tonys451 is offline
post #8 of 9 (permalink) Old Nov 2nd, 19, 11:27 AM
Beth
They should be fine. The gasket has a silicone coating on it
https://www.summitracing.com/parts/mrg-1131g/
nashville beth is offline
post #9 of 9 (permalink) Old Nov 2nd, 19, 1:11 PM Thread Starter
Thanks for the link!
Tonys451 is offline
