Steam holes in Profiler heads - Chevelle Tech
 5Likes
  • 1 Post By cuisinartvette
  • 1 Post By WHT/73
  • 1 Post By langss
  • 1 Post By Calculated Risk
  • 1 Post By WHT/73
post #1 of 14 (permalink) Old Oct 24th, 19, 11:02 AM Thread Starter
Anyone ever drill steam holes in Profiler heads? In my search for heads for my 400 I looked into Profiler. I asked them about drilling the holes and they don't do it. I talked to a head guy and he said he drilled one set and won't do another. What's up with that?
nitrofox is offline
post #2 of 14 (permalink) Old Oct 24th, 19, 12:45 PM
Scott Foxwell
Re: Steam holes in Profiler heads
Drilling steam holes in aftermarket aluminum heads is hit or miss. You can't go by the same set up as with older iron heads from a 400. ON some alum heads you need a different angle and you may never hit water. Most guys just don't bother these days.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #3 of 14 (permalink) Old Oct 24th, 19, 1:13 PM
look up speir, ask Chad himself. Curious to see why they said that. Metallurgy problem? hope not
Jebchevelle likes this.
cuisinartvette is offline
post #4 of 14 (permalink) Old Oct 24th, 19, 1:14 PM Thread Starter
Scott, so no problems with steam pockets or running hot on the street?
nitrofox is offline
post #5 of 14 (permalink) Old Oct 24th, 19, 3:33 PM
Scott Foxwell
That seemed to be a GM issue. If you gooogle the subject you'll get a ton of explanations but I don't think it's a problem. I think GM did it because they "thought" there would be issues with the siamese cylinders in the 400 or something about if the engine had to idle too long it would cause issues...something like that.
FOXWELL MOTORSPORTS
Straub Technologies
post #6 of 14 (permalink) Old Oct 28th, 19, 8:05 AM
Dart does it if you request it or so I was told when talked to them about a set of pro1 230 heads for my 400 project.
Only thing for me is, I been looking at a set of 230 pro 1's local for $1400 they are complete assembled from Dart but gone through by a local builder that did some work to them as far as gasket matching and exhaust valve opening up in the chambers they started life as 64cc but are closer to 66cc now. So like you was looking to get the holes done after the fact lol. My local machine shop here in pueblo will drill them but said pretty much what Scot did about with aftermarket heads they don't see the need.
PS.They charge $60 for the pair if you really want them done.
78 Malibu, 402, eddy heads, 174 B&M blower, th350, holley sniper EFI, 9" 3:70, 26X8.50-15 slicks.
96 chevy 1500, tow vehicle.
03 yz85 fun bike.
04 scion XB daily driver.
Jebchevelle is offline
post #7 of 14 (permalink) Old Oct 28th, 19, 9:02 AM
I think you only need the bottom ones.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #8 of 14 (permalink) Old Oct 28th, 19, 10:53 AM Thread Starter
I just looked at the deck on the block and I think you're correct. You can see where steam would get trapped at the lower hole because of the siamese bore, but the top hole has a large water passage in the deck right above it so as the steam rises it could escape there.
nitrofox is offline
post #9 of 14 (permalink) Old Oct 28th, 19, 12:38 PM
I had deck plugs installed obviously before decking and had the holes done in my afr’s but prolly didn’t have to as mentioned prior.
Never had an issue running hot. Just a summit alum rad with 2 1” rows and a summit alum water pump. Elect fan or clutch same result. 170*
WHT/73 is online now
post #10 of 14 (permalink) Old Oct 28th, 19, 3:57 PM
Lang
I picked up a set of "Holley" Aluminum Heads a few years ago. The owner had no info, and he was pretty much giving them away, and I figured "How Bad Can They Be" compared to 882's. I emailed Holley, for information and specifications and they sent me (snail mail) everything I had asked for....even a couple of Holley Stickers.....About three days after, I got the package I got an email advising me "Under No Circumstance Drill Steam Holes In These Heads", it will void the warranty.
langss is offline
post #11 of 14 (permalink) Old Oct 29th, 19, 7:12 AM
I don't drill them.
1967 Chevelle Malibu 4 door
The 7.99 at 173mph pass:
8.02 at 171mph:
Calculated Risk is offline
post #12 of 14 (permalink) Old Oct 29th, 19, 10:11 AM
Originally Posted by WHT/73 View Post
I had deck plugs installed obviously before decking and had the holes done in my afrís but prolly didnít have to as mentioned prior.
Never had an issue running hot. Just a summit alum rad with 2 1Ē rows and a summit alum water pump. Elect fan or clutch same result. 170*
where did you get the deck plugs from? I may have them done to mine just for piece of mind.
03 yz85 fun bike.
post #13 of 14 (permalink) Old Oct 30th, 19, 10:27 AM
My engine builder bought and installed them then did all the machine work to the block.
I would think you could get them at summit/JEGS
post #14 of 14 (permalink) Old Oct 30th, 19, 4:45 PM
They are just 3/4" allen head pipe plugs but if you want a set already drilled Moroso has them
https://www.summitracing.com/parts/mor-37800
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
