Pump gas BBC 475 CID with AFR265/Straub GTA Hyd roller.. - Chevelle Tech
 15Likes
  • 2 Post By cstraub
  • 5 Post By cstraub
  • 3 Post By BillK
  • 4 Post By steelcomp
  • 1 Post By Dragginwagon467
post #1 of 11 (permalink) Old Oct 18th, 19, 4:35 PM Thread Starter
Pump Gas BBC 475CID (4.350 x 4" x 6.535") AFR 265 Out of the Box, Straub GTA Semi custom hyd roller .600/.600 243 @ .050" on a 109, Morel 5374, Dart Block fully prepped, Victor 2904, AED 850, B&B Oil pan, Straub Crank and H-Beam rods. Goal was 600HP. Going to AL to live in a Camaro!!!
Jerry Briggs and horton409 like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #2 of 11 (permalink) Old Oct 19th, 19, 10:50 AM
Todd
Re: Pump gas BBC 475 CID with AFR265/Straub GTA Hyd roller..
Why was a Dart block used for such a small big block? No good GM cores available?
1970 Chevelle SS 396 (491 now) 4spd
1969 Nova 496 Turbo 400 Dana 60
496blaze is offline
post #3 of 11 (permalink) Old Oct 20th, 19, 9:38 PM
Very nice. Should be a lot of fun. If it’s anything like my straub street set up, start buying rear tires now.
71malibuu is offline
post #4 of 11 (permalink) Old Oct 20th, 19, 11:04 PM
Jason
I’m guessing the customer maybe already had pistons?
Otherwise, you are right. Why not go straight to a 4.500” bore and pick up displacement and power and still have plenty of room for rebuilds.
Jason Gore
AKA DragRacer
Naturally Aspriated 450 SBC - 915 HP / 714 lb-ft
3370 lbs
1.36 - 60', 5.93 @ 116.7 MPH - 1/8th
DragRacer is offline
post #5 of 11 (permalink) Old Oct 21st, 19, 10:16 AM Thread Starter
The customer wanted a Dart block.
Chris Straub
cstraub is offline
post #6 of 11 (permalink) Old Oct 21st, 19, 11:47 AM
Gary
i agree with the guys above. why in the world would you not run atleast a 4500 bore. i wouldn't even consider smaller than that. otherwise great combination and power
gnicholson is offline
post #7 of 11 (permalink) Old Oct 21st, 19, 11:55 AM Thread Starter
Hotrodding roots come from being different and building something that you wanted, not what somebody else had. We all want what we want. Customer wanted 600HP and a Dart block. Hotrodding goals achieved.
Chris Straub
cstraub is offline
post #8 of 11 (permalink) Old Oct 21st, 19, 12:07 PM
Mr Bill
Originally Posted by gnicholson View Post
i agree with the guys above. why in the world would you not run at least a 4500 bore.
I see nothing wrong with the small bore or the Dart block. By the time you find a decent used 40 year old GM block and do all of the prep work and machining you are not that far off from the Dart. As far as the bore size goes 4.500 bore does not leave a lot of room between cylinders for gasket seal plus not everyone wants or needs any more power. This should be a very nice reliable street engine
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #9 of 11 (permalink) Old Oct 21st, 19, 12:45 PM
Scott Foxwell
600hp, 620 tq...not many street cars, even with contemporary aftermarket suspension and tires, can use all that power on the street and very few people have any idea what that kind of power is like.
BillK, Jeff65SS, horton409 and 1 others like this.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #10 of 11 (permalink) Old Oct 21st, 19, 1:22 PM
Why only taken to 5500? Power was still climbing judging from the torque peak, I'd assume peak HP would be close to 6000 rpm.
Youtube Channel.
Instagram:
Twitter:
-SS454- is offline
post #11 of 11 (permalink) Old Oct 21st, 19, 6:37 PM
Hey, let’s keep this in mind when we chat about my standard deck height, factory block, 4.5” stroke 525 build 😉
I want it to run like a Buick, powering into those 2.56 gears on 255/60 radials using a very small converter.
Tarheel Chevelle likes this.
Proving every day hindsight is 20/20.
Dragginwagon467 is offline
