Cam for stock ‘71 402 - Page 2 - Chevelle Tech
 28Likes
post #16 of 35 (permalink) Old Oct 20th, 19, 1:47 PM
Re: Cam for stock ‘71 402
Id guess wtih a stock converter and your gearing it may be a little iffy
cuisinartvette is offline
post #17 of 35 (permalink) Old Oct 20th, 19, 2:22 PM
From mildest to wildest:
https://www.summitracing.com/parts/c...make/chevrolet
With a heavy tank, no compression and no gears, forget about anything over 5000 rpm, you need everything downstairs you can get.
Carburetor Rebuild & Restoration
Engine & Driveline Parts & Services
Check out
on Facebook
Vintage Musclecar is offline
post #18 of 35 (permalink) Old Oct 20th, 19, 3:16 PM Thread Starter
Thanks Eric, I’m liking the one in the middle.
Vintage Musclecar likes this.
Tony N.
Chevelles, Camaros, and Pontiacs
70L34 is offline
post #19 of 35 (permalink) Old Oct 20th, 19, 9:14 PM
Kerry
This https://www.summitracing.com/parts/crn-133901/
1000-4800 powerband. Good duration split for factory heads and restrictive exhaust.
pockets is offline
post #20 of 35 (permalink) Old Oct 21st, 19, 12:52 AM
jeff
That cam calls for 9.5-10.5 compression. and some gear.
But is that because they want their cam to impress you so they do not get a bad rap.
That is the thing about camshafts. They will get blamed for bad performance ..when it could be the rest of the parts.
It is nice if someone ran the EXACT same combo you have and can tell you this is good and this is junk.
That is hard to do really.
My friend at the cam shop told me I change cams like he changes underwear
Yea I like to try things.
But one thing I learned when I was 18 or 19 I need to run ported heads.
That cam in the link is [email protected] .050
I have ran 224 at .050 single pattern and it was a little down on power vs my [email protected] .050 in a 350".
Made up for it past 4500 rpm and took me from 14.50 to 13.8 et.
But 350" with ported iron heads.
I like to swap cams and see what they do but most people do not.
My 4 door 57 that pulls my boat has 10.87 compression so it runs well with just about any cam I stick into it.
I quit playing with 8.5 compression when I was around 21.
I do want to revisit it but use a turbo in the process.
But even that low compression Turbo trend is not what some of my quick buddies are doing.
10.3 compression and 27 PSI on top of that and running into the 4's in the 1/8 mile!
Friend had stock heads 76cc on his 355" with thick head gasket and non decked block .. ran the 292H with stock springs. valve float at 5600 so he shifted at 5500. It was a turd that sounded awesome.
I raced him and smoked him by 5 bus lengths.
I told him I was shifting at 6900rpm and ran the 270H which was 224 @ .050 on a 110 LSA.
I told him he needs a much smaller cam and he said he did not want to rev it too much past 5500.
I seen him the next month and he installed the 268H which was [email protected] .050.
He said it is the fastest engine he had ever built and it had the smallest cam he ever used.
Low compression and NON ported iron heads
Yep!
jeff swisher is offline
post #21 of 35 (permalink) Old Oct 21st, 19, 7:13 AM
Yes, Crane 969391 stock replacement cam for the L34 402 motor. If anything, you can go similar and tighten the LCA to 112.
Status: Car-Less
GRN69CHV is offline
post #22 of 35 (permalink) Old Oct 21st, 19, 10:54 AM
With 402" and no compression and a cruise rpm of ~2K, you don't really want--or need a split pattern cam, a single pattern will make better low end power.
Personally I would use the 10303 cam and install a decent 2 1/4" or 2 1/2"dual exhaust (retaining the manifolds), close the hood and cruise the wheels off of it.
Oh yeah, keep the QJet.
Check out
on Facebook
post #23 of 35 (permalink) Old Oct 21st, 19, 12:00 PM
Isky MEGA_Hydraulic 264. Cam And Complete Kit [390264] - $650.00 : ISKY Racing Cams, Do It Right
PS. The "MEGA" series are typically tight LSA, while the CompuCam series are typically wider LSA. The wide will give a smoother idle and a bit more top end pull with a broad flat TQ curve. The tight (108) gives a slight chop at idle and a mid range hump in the TQ curve, sacrificing some top end. I personally would use the MEGA series.
71454Chevelle and badrad like this.
post #24 of 35 (permalink) Old Oct 21st, 19, 9:38 PM
Darren
This was my choice as well.
427L88 likes this.
Darren
1971 Chevelle
496
10.5 scr
CFM Ported Victor Jr / Pro Systems Venom VX 1050
T-56 Magnum 6 Speed, DFX
12 Bolt TrueTrac, 4.56 gear 33 spline Moser axles
30x12.5 ET Street Radial
525++ rwhp
71454Chevelle is online now
post #25 of 35 (permalink) Old Oct 22nd, 19, 1:08 AM
I just stumbled across the cam card from a rebuild I did many years ago. Same situation, stock ‘72 402 with measured compression barely over 8:1, stock converter, gears, etc.
At that time Harold Brookshire recommended the following two cams.
https://www.lunatipower.com/high-eff...k-262-272.html
https://www.lunatipower.com/high-eff...k-266-270.html
I went with the smaller of the of the two. Not much to say, it’s a very mild streetable cam that fit the combo and was a healthy bump over the stock 193/204 and .398/.430 lift cam.
My opinion is, unless you bump up the compression and do other supporting mods, stick in this cam size range for a street cruiser and be happy you gained power over stock with no real trade off.
68post and hydro462 like this.
72BBC is offline
post #26 of 35 (permalink) Old Oct 22nd, 19, 12:42 PM
put a weiand st blower on it along with a small cam that will get it moving
friend used a 264 Isky 144 blower on a 70 convertible with 3.08 stock converter it was nuts how hard/long that car pulled even in high gear.
71454Chevelle likes this.
post #27 of 35 (permalink) Old Oct 22nd, 19, 12:44 PM
The .515 lift,[email protected] 110 LSA Crane works great in a low compression,bone stock 454 and I would imagine it would do the same in a 396/402
JMHO and experience with that cam.
Dan Orgill and 427L88 like this.
mr 4 speed is offline
post #28 of 35 (permalink) Old Oct 23rd, 19, 3:48 PM Thread Starter
Hey folks! I ended up buying the Isky 264 Mega cam which is just a bit more aggressive than the cam Chris recommended. Wish me luck...I’ll report back when I get it into the car.
Tony N.
70L34 is offline
post #29 of 35 (permalink) Old Oct 23rd, 19, 5:36 PM
Darren
Good choice!
Darren
1971 Chevelle
496
10.5 scr
525++ rwhp
post #30 of 35 (permalink) Old Nov 1st, 19, 2:49 PM
Anxious to hear your impressions of this cam in this combo. Seems like a great fit!
novadude is offline
