full race 383 build. - Chevelle Tech
 8Likes
post #1 of 30 (permalink) Old Oct 7th, 19, 8:59 AM Thread Starter
I have a fellow race who is looking to race a new class next year. Car is a h body that weighs 2820 with him in it. he currently has a vortec headed 355 don't know much about it as it was a online rebuild engine, car went high 11's on a 125 shot of N20. He wants to go 10 flat N/A and save the spray just in case. I said since his block needs bored he might as well go 383CI and run 110ll since he has been running 91 oct as that is all we have up here at the pump, he does use some kinda octane booster currently not sure what.
My thoughts on the 383 would be 550hp N/A, I was thinking 1k200 or afr 195's with 12:1 comp and a solid roller cam. how far off am I in thinking on this combo?
78 Malibu, 402, th350, holley sniper EFI, 9" 3:70.
96 chevy 1500, tow vehicle.
04 scion XB daily driver.
Jebchevelle is offline
post #2 of 30 (permalink) Old Oct 7th, 19, 11:08 AM
Re: full race 383 build.
550 hp should get high 9's if the car works. But 550 hp might be hard to find on the mountain top.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #3 of 30 (permalink) Old Oct 7th, 19, 11:37 AM
George
A buddy has one he races....3000#, not sure if that is with him in it. He just went to a Dart block 427, 230 Dart heads, .700ish lift solid roller, 14:1 compression on e85. Runs 6.teens consistently. Only a few weekends on the 427...
With his old 406 similar compression, same heads and smaller cam ran 6.20's consistently. In the 1/4 was 9.80's I think he said.
You probably will want more head than the 195's. Another friend has a 70 Camaro with a 383, AFR 195's, .580 lift solid roller, about 10-11:1 range compression, and he runs 7.30's...Should be around 11.40-50's in 1/4
We spec'd out my 383 for mid 10's in my chevelle and went with the ported profilers / intake from Eric W and a solid roller from Jones. Somewhere in the 12-13:1 compression range.
10.0 on motor isn't an easy task.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #4 of 30 (permalink) Old Oct 7th, 19, 12:18 PM
Anyone think a 210 or 220 comp port would get him there?
cuisinartvette is offline
post #5 of 30 (permalink) Old Oct 7th, 19, 12:28 PM
I'd look at these AFR 210s
https://www.airflowresearch.com/210c...cylinder-head/
add the full competition option and the Ti retainers. if he can hack it, the Ti valves are good option, those big valves are heavy.
these are still stock style, no valve relocation or shaft rocker requirement.
if not in his budget, the 195s with comp option are still good.
Tom Mobley is online now
post #6 of 30 (permalink) Old Oct 7th, 19, 12:31 PM
If you are going to build a race gas motor, build enough compression to use it. Don't build an engine too high for pump gas, but too low for race gas. Aim for 13-14:1 compression and go. My friend had one with Brodix Track 1 heads and a small roller that made 575 hp the first time and went 10.40's in a 3140 lbs Chevelle. The second time with more head work and a bigger, (not huge roller) I seem to remember, 262/272 .630 lift and it made 615 hp. This time it was put in a 2600 lbs nova and went 9.76.
Ray
bracketchev1221 is offline
post #7 of 30 (permalink) Old Oct 7th, 19, 1:00 PM
Contemplating selling my Dart not sure if it would be enough for him
230cc ported by Mamo 294/230ish...Jesel 1.6 62cc chamber 2.02 valve??
post #8 of 30 (permalink) Old Oct 7th, 19, 1:47 PM
I just spoke to my guy. He said 383 and 550 hp is pump gas with hydraulic roller and 200 to 220 heads. He has 383 10 and a haft compression with there personal designed heads and hyd roller that easily does that. He said skip white offers basically the same 550 horsepower 383 for about 5000.00 complete with there chinese heads. So it can easily be done and a lot more with race gas and a silid roller cam.
RH
RickyHill is offline
post #9 of 30 (permalink) Old Oct 7th, 19, 2:19 PM
Those are 260ishcfm at .650, under 190exh if I remember right.
Its going to have to be one hell of a HR to make 550 Id think.
post #10 of 30 (permalink) Old Oct 7th, 19, 3:08 PM Thread Starter
white performance machine claims they have a 383 engine that makes 565hp with afr 210's and 10.5:1 with a hydro roller cam.
post #11 of 30 (permalink) Old Oct 7th, 19, 3:14 PM Thread Starter
I thought that too went 13:1 on my 468 when I did it and it ran on 110ll. Thing is was looking at pistons for this deal and most I seen are 12:1 with 64cc chambers if the heads had 58cc chambers would open up a new set of pistons choices.
Truth be told not had time to shop around, his budget is tight. He has a stock 400 crank that could be used but I told him to look into a scat 9000 crank and scat pro I beam 6"rods the pistons are up for debate for sure.
post #12 of 30 (permalink) Old Oct 7th, 19, 3:21 PM Thread Starter
It might be a mute point but block will have to go .040 at least as he butted the rings or so he thinks on the 355. All I know at this point is he bought the short block off ebay and got the heads done locally, he ran it for 2 seasons and it started to smoke when he upped the n20 to see how fast it would run on a larger shot. So now it needs a rebuild.
post #13 of 30 (permalink) Old Oct 7th, 19, 4:57 PM
Sonic test the cylinders and make sure you have 2482 center caps as those are the performance caps on some of the old GM blocks.Running N02 you should have a good foundation to start with.
Jebchevelle likes this.
Website is up and running
Machine shop tour
Monthly Specials
CNC BLOCKS N/E is offline
post #14 of 30 (permalink) Old Oct 7th, 19, 5:55 PM Thread Starter
Actually I just got a line on a stock bore 817 casting 400 block, it needs bored .030 over. got to go look at it at 4:30 pm my time today.
post #15 of 30 (permalink) Old Oct 7th, 19, 6:04 PM Thread Starter
If he picks up the 400 block this might turn into a 3.875 or even 4.00 stroke build then he will have no trouble getting 550 out of it. Might even squeak 600 out of it. That assuming the 400 block is any good. Crank is same price for either stroke, thing is though then rod and pistons choice will make a difference as well as heads. Cam most likely be on a small base circle not sure how that all will effect cost of build. He was looking at a 3.875 stroke crank to try and put in the 350 block, local machine shop told him they can clearance a 350 block for that crank stroke and scat procomp I beams. They want $450 to bore and clearance the block that includes hot tank but no tq plate hone that is extra, as is is cam bearings. total for the 350 to 383 machine work he was looking close to $585 cost wise. Sounded reasonable to me.
