holley 3310 jetting and power valve advice - Chevelle Tech
 4Likes
post #1 of 36 (permalink) Old Oct 6th, 19, 11:21 PM Thread Starter
I am trying to dial in my holley 3310 on a 30 over 396 with builder forged pistons (not zero decked so prob 9.7 to 1 comp) stock 702 heads and the cam in picture with exhaust manifolds and 2 1/4" exhaust (not Ideal).
The issue is black sooty plugs that foul and cause performance loss pretty quickly.
Carb is set as built with 72 jets on primary, stock plate on secondary 6.5 pwr valve. lighter yellow spring in secondaries, mixture screw want around 1 3/4 turns out and that gets around 10-11 inches vacuum.
I am at 3445 ft elevation.
So do you guys think the jets or the power valve is causing plugs to foul?
I was thinking lower jets to 70 or 68 because small chamber head inefficiency, manifolds flow, and a bit too big cam for the manifolds, and also elevation...
Dtrue2 is offline
post #2 of 36 (permalink) Old Oct 7th, 19, 12:26 AM
Re: holley 3310 jetting and power valve advice
The one thing I suggest checking before doing anything else is the float levels.
427L88 likes this.
oldcutlass is online now
post #3 of 36 (permalink) Old Oct 7th, 19, 12:32 AM
Vince
68 jets is next after the float levels check; or needle and seat replacement...
3310 carbs are pretty foolproof
VinceS427bb is offline
post #4 of 36 (permalink) Old Oct 7th, 19, 1:09 AM Thread Starter
Float level in primary was good and secondary was maybe 32nd inch too high but now lowered and good. The needles and seats seem to be holding fuel back once adjusted as there was no trickle out the sight plug when idling.
I'll get a set of 68 jets and give that a go.
427L88 likes this.
Dtrue2 is offline
post #5 of 36 (permalink) Old Oct 7th, 19, 8:06 AM
Lean the primary jets down till it surges at a 50mph cruise rpm.
Then go up 2 numbers see how it feels and install new plugs
rp930 likes this.
1968 hot rod is online now
post #6 of 36 (permalink) Old Oct 7th, 19, 12:27 PM Thread Starter
Ok,
thanks Bob.
Dtrue2 is offline
post #7 of 36 (permalink) Old Oct 7th, 19, 12:31 PM
What does your ignition look like? You need to get that right first.
always and forever. what's the initial timing, how much mechanical advance at what RPM? how much vacuum advance? hooked up to manifold or ported vacuum. Onmce you know the answers to these questions we can sort the carb.
Do you have a PCV hooked up? and a breather?
Apparently you have a 3310-x carb, not an original 3310?
70 Camino...Roller
Tommy the Cat is offline
post #8 of 36 (permalink) Old Oct 7th, 19, 12:55 PM
Tommy, sorry, but when I posted it somehow merged into your post instead of making a new post.???
oddball deal.
post #9 of 36 (permalink) Old Oct 7th, 19, 2:03 PM
oddball deal.
I've been told that two Toms don't make a right....
Our carb advice is usually almost identical so maybe even the computer is confusing us.
No worries!
70 Camino...Roller
post #10 of 36 (permalink) Old Oct 7th, 19, 3:51 PM
Rich
^^^This. (Whoever wrote it!!!)
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #11 of 36 (permalink) Old Oct 7th, 19, 4:45 PM Thread Starter
Yes 3310-2 and not original
Initial is 22deg idling at 700rpm with vac unplugged.
at 2800rpm its at 40deg
at 3300rpm its at 44deg.
Manifold vacuum plugged in raises it to 37deg and 850rpm
at 3000rpm all timing is done and stops at 55deg total.
It seems happy timing wise no rattling with 4th gear and low rpm load, no light load low rpm bucking and plenty of pull and responsive all through rpm range until the plugs foul and the noticeable miss shows up.
I very rarely hear any rattling with this engine/car/rear gear combo but did have the bucking at low rpm syndrome from timing coming in way too quick, that was really annoying to drive.
Dtrue2 is offline
post #12 of 36 (permalink) Old Oct 7th, 19, 5:43 PM
Have you checked that the power valve is good? What is vacuum at a steady cruise?
That's a lot of timing. Have you ever verified your balancer indicates correctly?
70 Camino...Roller
post #13 of 36 (permalink) Old Oct 7th, 19, 6:04 PM
Kerry
What plugs are you running? Gap? What is the ignition system, and what coil?
pockets is offline
post #14 of 36 (permalink) Old Oct 7th, 19, 9:25 PM Thread Starter
Tom,
Balancer was good last time I checked.
Power valve is good.
Cruise vacuum is probably in the 16 to 18 range but never really paid attention to it to be honest.
Kerry,
Plugs are AC R43XLS gapped 40thou
Hei with MSD module (same place in distributor as regular gm module) with the builtin rev limiter from 10 years ago or so when they came out.
Hei stock coil.
Dtrue2 is offline
post #15 of 36 (permalink) Old Oct 8th, 19, 12:33 AM
My math says you should probably be around a 70 jet but two jet sizes isn't enough to foul plugs. You're pulling fuel from somewhere. Have you made sure there's a weight ball/needle under the squirter? Is your transfer slot square on the primary at idle? Are your secondaries open at all at idle?
I would recommend going to a 10.5 or 8.5 power valve if your carb were working right but right now that would exacerbate your problem so leave the 6.5 for now.
70 Camino...Roller
