Air bleeds - Chevelle Tech
post #1 of 8 (permalink) Old Oct 3rd, 19, 8:46 PM Thread Starter
Jack
Air bleeds
I have notice on my carb around the air bleeds there is fuel stains.. I removed one of the hsab and a little bit of fuel came out...What would cause this ??
Matthew 22: 37-39
R.I.P. Mike Romeo
DragRac69 is offline
post #2 of 8 (permalink) Old Oct 3rd, 19, 9:18 PM
Re: Air bleeds
Have you noticed any flooding? If your float sticks fuel comes out of all kinds of places. It could also be percolating when the engine is hot. Pretty common. As long as it's not a sticking float or debris in the needle and seat it's probably nothing to worry about. I'm guessing this is a Holley design?
70 Camino...Roller
Tommy the Cat is offline
post #3 of 8 (permalink) Old Oct 3rd, 19, 9:25 PM
Scott Foxwell
Re: Air bleeds
Could be pull-over fuel form the pump squirter nozzle.
FOXWELL MOTORSPORTS
steelcomp is offline
post #4 of 8 (permalink) Old Oct 3rd, 19, 9:32 PM
Re: Air bleeds
On most Holley designs the squirter outlet is lower and inboard of the bleeds and pullover occurs with airflow going away from the bleeds. Not saying it isn't possible but I haven't seen pullover cause fuel on the bleeds. It would be good to check that the needle is in fact under the squirter just for GP.
70 Camino...Roller
post #5 of 8 (permalink) Old Oct 3rd, 19, 10:06 PM Thread Starter
Jack
Re: Air bleeds
No flooding.. I turn off the electric fuel pump a few seconds before I shut the engine off. Just to drain down the fuel bowls. Yes holley design..
Matthew 22: 37-39
R.I.P. Mike Romeo
post #6 of 8 (permalink) Old Oct 3rd, 19, 10:07 PM Thread Starter
Jack
Re: Air bleeds
What can be done to prevent it...
Matthew 22: 37-39
R.I.P. Mike Romeo
post #7 of 8 (permalink) Old Oct 3rd, 19, 11:02 PM
Re: Air bleeds
I didn't realize you were talking about a Dominator. Those squirters are actually above the bleeds so in theory it could happen. Like I said earlier, make sure the weight is under the nozzles and make sure the gaskets are in good shape. It would be unusual to pull fuel out of there. Could it be running down from the vents? What sort of air cleaner do you run?
70 Camino...Roller
post #8 of 8 (permalink) Old Oct 4th, 19, 6:21 AM
Re: Air bleeds
I have the same carb and the same issue. Ive noticed fuel seep from the bottom of the squirters when pushing the acc pump lever. Ive replaced the squirter gasket, doubled up the gasket, tried new squirters, new squirter bolt, replaced acc pump umbrella, checked needle weight, even lightly filed squirter mounting surface to insure it is flat.
S
Still seeps fuel.
I gave up and just let it seep.
67Mike is offline
