Opinions please - Quadrajet carb flooding - Chevelle Tech
 23Likes
post #1 of 40 (permalink) Old Sep 18th, 19, 12:19 PM Thread Starter
James
Iíve got a quadrajet that was running great, and could make the engine scream and pull hard! Yesterday, I gave it a WOT before pulling into the driveway, then it stumbled and died right in front of my garage.
The carb appears to be leaking gas out of the gaskets and making the engine run rich. I can get the motor to start but stumbles then dies. Iím blasting some carb cleaner right now, it seems to help with the initial startup, but then runs rich. I tightened the idle AFR screws, but that didnít help. Could it be a stick float? How do I free it up?
A bad fuel pump and clogged filter wouldnít cause it to run rich, would it?
Hereís some pictures of the carb:
Itís a stock 66, 327, MT, points El Camino. Thanks!
69Chvll is offline
post #2 of 40 (permalink) Old Sep 18th, 19, 12:33 PM
Randy
Re: Opinions please - Quadrajet carb flooding
Probably a stuck float or trash in the needle and seat. Time for a rebuild, Q-jets are pretty easy to work on. Their weak spot is the epoxy plugs and the bottom of the fuel bowl, they tend to leak. If you're not comfortable building it yourself, someone here can recommend a reputable rebuilder.
Randy
TC # 5401
67 Project SS Clone
pnugene is offline
post #3 of 40 (permalink) Old Sep 18th, 19, 12:47 PM
Usual suspects, dirt in the needle and seat or the fuel pressure is too high.
hydro462 likes this.
68Chevele is offline
post #4 of 40 (permalink) Old Sep 18th, 19, 12:47 PM
Get a rebuild kit so you have that top gasket and a new needle/seat. That is likely what it is, OR your fuel pump all of a sudden decided to shoot 8+PSI at the Qjet, which it cant handle.
The only issue with disassembly are all those linkages and having to "lift an turn" the top of carb off to remove.
Maybe someone near you in CA can help out, but if not, there are a-plenty of Qjet gurus here that can guide you thru the process using this BB. ( I aint one).
In the mean, I'd get the numbers of the carb ( usually in rear, stamped vertically ) to order the right rebuild kit. Pop the carb off the engine, set up a workspace where gas fumes aint in the kitchen, and start disassembly.
As we suspect the issue is the needle and seat. In the pic below, if you follow the arms of the float up to the casting, its all that stuff under the odd looking C clip.
Name:	Qjet float.jpg
davewho1 likes this.
post #5 of 40 (permalink) Old Sep 18th, 19, 1:19 PM
If it's an original '66 Qjet, the numbers should be on a round metal tag embedded on the side, unless it has been removed.
427L88 likes this.
David
davewho1 is offline
post #6 of 40 (permalink) Old Sep 18th, 19, 1:24 PM Thread Starter
James
I just watched that video and sprayed a bunch more carb cleaner into the carb, plus I put some carb cleaner fuel additive into my fuel. That seemed to help. Itís not leaking out the sides and not running as rich. Hereís the latest picture after that:
I see some fuel sitting on the top. What is that part of the carb called? I need to get some fresh fuel in the tank too, I recently purchased the car last month and hadnít fueled it up yet. Iíd suspect the car has been sitting for a while, too.
69Chvll is offline
post #7 of 40 (permalink) Old Sep 18th, 19, 1:25 PM Thread Starter
James
I would say, yes. This carb does need a overhaul. I will be doing this in the future. Any kits to recommend for the rebuild? I donít mind doing it myself.
69Chvll is offline
post #8 of 40 (permalink) Old Sep 18th, 19, 2:26 PM
What Video?
Where is it?
LKN BCK is offline
post #9 of 40 (permalink) Old Sep 18th, 19, 2:32 PM
& Administrator
If the float is original ,I'd change it as they had a tendency to become gas logged and no longer would float.
Acted like a stuck needle.
427L88 likes this.
Mike is offline
post #10 of 40 (permalink) Old Sep 18th, 19, 3:59 PM Thread Starter
James
Lovely tailpipe gunk
69Chvll is offline
post #11 of 40 (permalink) Old Sep 18th, 19, 4:09 PM
Andy
One common issue sometimes is the accell pump.... and from the pictures there appears to be fuel around it, I would replace that...
Ialone is offline
post #12 of 40 (permalink) Old Sep 18th, 19, 4:18 PM
When you get it running well, The next order of business is to get a STEEL fuel line and replace the RUBBER FUEL LINE. With each heat cycle of the engine the rubber may and will become brittle.
Leaking fuel on a hot intake manifold,,,,,,,,, Is not a good thing. Just some advice from a GEESER that has " been there, done that and watched it burn ".
von, hydro462 and 68-13427 like this.
Robinls5 is offline
post #13 of 40 (permalink) Old Sep 18th, 19, 4:33 PM Thread Starter
James
What about a rebuilt carb from rockauto? It looks like they have replacements for $275 with core charge. Which Iíd keep the carb if it is indeed original to the car. Where can I find a good rebuild kit?
69Chvll is offline
post #14 of 40 (permalink) Old Sep 18th, 19, 4:33 PM Thread Starter
James
https://www.rockauto.com/en/catalog/...arburetor,5904
69Chvll is offline
post #15 of 40 (permalink) Old Sep 18th, 19, 4:50 PM
I'd get it rebuilt by someone who knows their QJs - well plugs epoxied, etc.
Does it have the round metal carb number/date tag on it?
Vintage Musclecar likes this.
David
davewho1 is offline
