Another cam recommendation. Hyd roller - Chevelle Tech
 20Likes
post #1 of 43 (permalink) Old Sep 17th, 19, 10:52 AM Thread Starter
Ron
I currently have the Clay Smith "Old School" Hyd roller cam in my 496,( https://www.claysmithcams.com/hr-880...x-of-5700-rpm/ ).When I had the 4 speed trans the engine would surge at lower rpms and was pretty annoying, I tried to tune the surge out of it but never could, I eventually changed the trans to a 700r4 and the surge was absorbed by the converter, I can still hear the surge but cant feel it in the car. I am changing back to a 4 speed and don't want the same issue. So, I want a different hyd roller cam that will cruise smoothly at lower speeds.
70 Chevelle, total street car.
496 10.3 compression
iron 049 heads with bigger valves and a little porting work.
3.73 rear gear with 275/60/15 tires (28" tall)
70 Chevelle SS396 (496) Straub roller, 700r4
69 Malibu convertible (sold)
TC #54 Gold
ToocoolZ28 is offline
post #2 of 43 (permalink) Old Sep 17th, 19, 2:45 PM
Andy
Re: Another cam recommendation. Hyd roller
Not completely sure, but surging to me sounds like a carb tuning issue.
Ialone is offline
post #3 of 43 (permalink) Old Sep 17th, 19, 2:53 PM
Ron,FWIW I run a 248/[email protected] 110 LSA and I have no surge. What does the timing curve look like?
mr 4 speed is offline
post #4 of 43 (permalink) Old Sep 17th, 19, 3:14 PM Thread Starter
Ron
Timing is at 18 initial ,gives me 36 around 2800 rpm. Vacuum can hooked to manifold vacuum. I have tried the initial up to 24 and down to 12 no difference except I get a lot of detonation at the higher setting.
I have tried to tune the carb every which way but ran out of ideas.
Actually I think the cam is a little small for a 496, on the dyno it made peak power just shy of 600hp, at 5300 and began falling off fast after that.
I know some people want it to have that rumpity sound at idle, I don't care about how the idle sounds, I just want it to run good and not surge, I want the drivability. The car runs great with a lot of power, this cam makes great power until I get to a little over 5000.
Thanks guys, any specific cam to recommend?
TC #54 Gold
post #5 of 43 (permalink) Old Sep 17th, 19, 3:26 PM
I would try running without the vacuum advance and see if the surge goes away. If it does,then the amount of vacuum advance needs to be limited.
427L88 and Geo71 like this.
post #6 of 43 (permalink) Old Sep 17th, 19, 3:59 PM
In that CID Ron, I haven't had anyone with a surge issue. Have you borrowed a carb from someone and tried something else? I have a ton of C3 customers with factory 4 speeds and they all love that cam in 454 to 468 CID. A 496 should swallow it and with the power dropping the way it does after 5300 it does swallow it.
The 229's little brother is .221/235 on a 109 LSA. I have a ton of guys with C-10's that love this thing as it will haul the heavy's down the road.
Pat_McNeil and blue_69_malibu like this.
Chris Straub
Mfg Performance Parts
cstraub is offline
post #7 of 43 (permalink) Old Sep 17th, 19, 5:56 PM Thread Starter
Ron
Thanks Chris, yes I have tried 2 other carbs, Now I have a Quick Fuel 750 Vac secondary carb, I have also tried a Holley 750 vacuum sec carb and an AED 850 double pumper, all act the same. I haven't tried disconnecting the vacuum advance, I'll try it tomorrow.
TC #54 Gold
post #8 of 43 (permalink) Old Sep 17th, 19, 6:02 PM
With that iddy biddy cam I would think it would be smooth.
I have a much larger cam and only had surge if I did it with the pedal!
I also don't surge in OD unless it is at less than 1800 rpm which is when the cam clears up
tacomatrd is offline
post #9 of 43 (permalink) Old Sep 17th, 19, 6:03 PM
George
TRy your vacuum advance on ported...see if that helps. Or try without it.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is online now
post #10 of 43 (permalink) Old Sep 17th, 19, 6:34 PM
what gear/rpm was it surging at?
cuisinartvette is offline
post #11 of 43 (permalink) Old Sep 17th, 19, 6:36 PM
Your cam is a solid flat tappet. When comparing a flat tappet lobe to a roller lobe for area you need to subtract 18 degree if your comparing the lobes for area. 18 is not set in stone but a good starting point. So your Flat tappet that is 250/256 in roller area would be 232/238 @ .050"
ToocoolZ28 likes this.
Chris Straub
cstraub is offline
post #12 of 43 (permalink) Old Sep 17th, 19, 7:15 PM Thread Starter
Ron
It surges anywhere from 2200 to 2800 rpm in 4th gear (od) at steady speeds
TC #54 Gold
post #13 of 43 (permalink) Old Sep 17th, 19, 8:56 PM
Is it really 18 degrees??
I thought it was around 6 or so. That's pretty crazy. I am going to switch to a roller cam in the next year or so, expect a call when I'm ready!
post #14 of 43 (permalink) Old Sep 17th, 19, 9:19 PM
Chris, what about HFT to HR? Have a friend with a 454 thats getting a set of 290s and a Edelbrock street ram
Had a bottom of the page HFT trying to get him into a roller. Not sure he knows what hes missing.
post #15 of 43 (permalink) Old Sep 17th, 19, 9:51 PM
A flat is physically limited to lift rate. Modern day heads flow air quick. You want to open a valve and shut it as quick as possible to make the biggest bang in the shortest amount of time. Delphi shut down the flat tappet lifter production line. Flat tappet lifters today are coming from China.
Chris Straub
cstraub is offline
