Johnson lifter wear pattern on rollers - Chevelle Tech
 12Likes
post #1 of 22 (permalink) Old Sep 15th, 19, 10:52 PM Thread Starter
Changing cams in the 540. I have about 800 miles on these Johnsons and the rollers seem to have a strange wear pattern. Rollers feel smooth and I can't catch a fingernail or anything but the wear pattern worries me. Running a billet cam with springs set at 175 on the seat 400 open.
Lifters
https://imgur.com/a/OYfL4Ss
540 BB
10 to 4 comp.
Brodix Race Rite BB-2 Plus heads
Edelbrock RPM Air Gap
Quick Fuel 950 CFM Carb
Lunati Voodoo HR 231/239 @ .050, 600/600, 110 LSA
Johnson 2116 BBR lifters
Hooker Super Comp 2" primary headers
Tremec TKO 600 .82 overdrive
3.73 Posi
William Hennke is offline
post #2 of 22 (permalink) Old Sep 16th, 19, 2:15 AM
Re: Johnson lifter wear pattern on rollers
I don't see anything to worry about. Don't worry, be happy.
Wolfplace and B433 like this.
Tom Mobley is online now
post #3 of 22 (permalink) Old Sep 16th, 19, 2:18 AM
Probably little dirt that made some minor wear. How Did the cam look?
Chevelle 1969 is offline
post #4 of 22 (permalink) Old Sep 16th, 19, 2:51 AM
Marcus
Looks like the wheels have seen some debris, hard to tell if it matters.
If you cant catch a nail run them imho.
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is online now
post #5 of 22 (permalink) Old Sep 16th, 19, 6:10 AM
Lifters
Are you running a plugged oil bypass?
Video:
fr8dog is offline
post #6 of 22 (permalink) Old Sep 16th, 19, 7:54 AM Thread Starter
It could be dirt but I don't think that's it. I had the engine apart last winter and I cleaned everything about a bazillion times before assembly. I also changed the oil after driving it about 10 miles and cut the filter open. I changed the oil again at 400 miles and again cut oil filter open. The by pass is plugged. There was some tracking on the cam. It also feels smooth but looks similar to the lifter pictures. I will take a couple pictures of the cam in a bit
fr8dog likes this.
540 BB
10 to 4 comp.
3.73 Posi
post #7 of 22 (permalink) Old Sep 16th, 19, 8:14 AM
There is nothing wrong with your lifters. No dirt or debris either. Everything I have taken apart in the last 40 years look similar. Anything you use and run for a while will look the same.
Wolfplace and 540 Olds like this.
sleeper is offline
post #8 of 22 (permalink) Old Sep 16th, 19, 9:35 AM
Scott Foxwell
Seriously?
Perfectly normal.
It's an engine, not a Swiss watch.
FOXWELL MOTORSPORTS
Straub Technologies
steelcomp is offline
post #9 of 22 (permalink) Old Sep 16th, 19, 10:08 AM
Marcus
My 489s Morel lifters and cam with around 20 000 miles was told by Chris my marks was from debris. When it was apart for inspection and valve spring check, went back together again lifters on same kines since I reused everything.
Thought yours looked similar? Mine looks better in real life vs the pictures and you cant feel the marks on either the lifter wheels or cam or catch a nail.
My bypass is also blocked engine but it has eaten two bronze tip fuelpump pushrods.
ID:	603554   Click image for larger version
ID:	603556   Click image for larger version
ID:	603558   Click image for larger version
post #10 of 22 (permalink) Old Sep 16th, 19, 10:11 AM Thread Starter
Some cam pictures.
https://imgur.com/a/mYxeL1v
540 BB
10 to 4 comp.
3.73 Posi
post #11 of 22 (permalink) Old Sep 16th, 19, 10:46 AM
Some cam pictures.
The second lobe on first picture looks strange?
Almost looks pitted and heatmarks?
post #12 of 22 (permalink) Old Sep 16th, 19, 11:12 AM Thread Starter
That's oil, I didn't wipe it off.
540 BB
10 to 4 comp.
3.73 Posi
post #13 of 22 (permalink) Old Sep 16th, 19, 11:40 AM Thread Starter
I sent the pictures to Johnson yesterday and received a reply back from their Product Manager just now. He also said everything looked fine.
Wolfplace and fr8dog like this.
540 BB
10 to 4 comp.
3.73 Posi
post #14 of 22 (permalink) Old Sep 16th, 19, 1:00 PM
Johnson makes some outstanding lifters.
'66 SS Chevelle
565 BBC Mamofied 300cc Ovals
4.11 12 bolt
Best e.t. to date [email protected] @115.31
1.315 60'
Stokerboats is offline
post #15 of 22 (permalink) Old Sep 16th, 19, 2:44 PM
Lifters
So you are changing it already?? You have to let me know how it works. I got my car on the road on saturday. Does quite well, but 6th is nearly useless--5th is perfect. 6th is only good for 70+
William Hennke likes this.
tacomatrd is offline
