Holley Strip Dominator VS Performer RPM - Chevelle Tech
 11Likes
post #1 of 35 (permalink) Unread Sep 14th, 19, 5:31 PM Thread Starter
Wes
Question Holley Strip Dominator VS Performer RPM
1967 Nova, 385, 700R4, 2800 Converter, 3.55 Posi
385 - 9.8:1 compression, 8.33 DCR, AFR 195 Eliminator heads
1 3/4" fenderwell headers, 3.00" Dual Exhaust. No crossover
HR Cam .521/.530 230/238 @ .050" 109 LSA, 106 IC
The Strip Dominator had runner extensions welded in and a gasket match done by Mike Stark at CFM in Indy
The RPM is the older style, non-air gap, with the plenum divider milled similar to the air gap intakes
Car will primarily be street driven, with a few quarter mile passes a year. Contemplating installing a Holley Sniper I already have and a possible swap to a TKO with a 2.87 1st and a .64 OD. The engine is a fresh build, and hasn't been in the car yet. I'd like to keep the oil fill tube in the front of the intake.
Thanks in advance.
Wes
Wes
1970 Factory 2WD Blazer
1967 C10 SWB
1967 Nova SS
1957 Corvette
wes migletz is offline
post #2 of 35 (permalink) Unread Sep 14th, 19, 6:14 PM
Derek
I would suggest the dual plane air gap.
With your intended use, gear and over drive transmissions I'm guessing you'll spend most of your time below 3500 rpm.
Steve R and -SS454- like this.
77 Trans Am: 461 BBC with CS HR, Brodix RR ovals, TH400, 3200 stall, 3:90 gear.
Best 1/4 NA 11.4 @ 119, and 10.8 @ 123 with 125HP shot of NOS.
DK77TA is offline
post #3 of 35 (permalink) Unread Sep 14th, 19, 7:58 PM
Re: Holley Strip Dominator VS Performer RPM
Go for the strip dominator and rev it. That runner extension was the hot thing in the 80s. We had one on my dads big block bracket car.
WHT/73 and Geo71 like this.
Ray
bracketchev1221 is offline
post #4 of 35 (permalink) Unread Sep 14th, 19, 8:42 PM
I can tell you the 330-25 is weak down low and on a street car that may be a factor. I would either use the Street Dominator 300-36 (same as the Z/28 intake) or the Air Gap. The Super Victor is good if you rework the plenum area.
68Chevele is offline
post #5 of 35 (permalink) Unread Sep 15th, 19, 12:14 AM
George
Strip Dominator would be my vote. I like single planes though....
WHT/73 likes this.
'71 Malibu
355 [email protected]
125 [email protected]
383 Mud Motor- [email protected]
100 shot [email protected]
Geo71 is offline
post #6 of 35 (permalink) Unread Sep 15th, 19, 12:20 AM
The dual plane will be much better with that short duration cam. Now if you get into the 240 to 250 range I can see the 300-25 working pretty good. My cam was at 254 and 264 on a 106 LCA and it screamed to 7200.
post #7 of 35 (permalink) Unread Sep 15th, 19, 8:37 AM
To me 3.55 is dual plane territory. Real drag gears are open plenum stuff. imho.
post #8 of 35 (permalink) Unread Sep 15th, 19, 11:59 AM Thread Starter
Wes
Looks like the dual plane is the way to go. Im also not sure that the strip dominator would fit under the stock hood.
Ill probably end up trying the Strip dominator, too, once I get the car sorted.
Thanks for the recommendations.
427L88 likes this.
Wes
1967 C10 SWB
1967 Nova SS
1957 Corvette
post #9 of 35 (permalink) Unread Sep 16th, 19, 12:07 AM
Nice wes....love single planes also they just rip. EFI on the single plane seems to work real well I cant see where it would be a slug thats going to make good torque. Let me know how that sniper works out
Havent seen a 300-36 in ages fwiw
cuisinartvette is offline
post #10 of 35 (permalink) Unread Sep 16th, 19, 12:54 AM Thread Starter
Wes
Hey Ron,
I have an old style RPM and a 67-68 Z/28 intake. The RPMs plenum is notched like an air gap, tempted to notch the Z/28 intake and run it. BTW, Im back in TX now. After a year, I can start playing with my cars again.
68Chevele likes this.
Wes
1967 C10 SWB
1967 Nova SS
1957 Corvette
post #11 of 35 (permalink) Unread Sep 16th, 19, 3:41 AM
Fitting a SBC in the Nova is tight EVERY WHERE. The Victor Jr looks good to fit the flat hood, but you seem to be in a lower RPM range.
Mike Lewis street 572
Cale Aronson
Black Magic clutches
Cam by UDHarold
Menscer Motorsports
TRZ
CEAutoelectric
aukai is offline
post #12 of 35 (permalink) Unread Sep 16th, 19, 10:48 AM
Wes a 7530 Weiand has good hood clearance and wont be soggy. Put some work to mine real happy with it.
post #13 of 35 (permalink) Unread Sep 16th, 19, 3:24 PM
Single planes are very well suited to manual trans.
If keeping the auto, I'd go with dual plane.
70GS455 is offline
post #14 of 35 (permalink) Unread Sep 16th, 19, 3:33 PM
No lack of low end tq even with a too big head/cam and tears it up as rpm increases
Trying to appeal my retirement, matter of time Ill be out of here finally!
Ill be poverty stricken but free and happy..and single.
post #15 of 35 (permalink) Unread Sep 16th, 19, 5:58 PM
Originally Posted by wes migletz View Post
Hey Ron,
The trick on the old Z/28 intakes used to be, cut the divider down 1" and add a 1" open spacer. Was supposed to be worth 15 to 20hp @6500rpm .
