2.56 vs. 2.73 vs. 3.08 - Chevelle Tech
 7Likes
post #1 of 29 (permalink) Old Sep 11th, 19, 10:25 PM Thread Starter
Send a message via AIM to dragginwagon406 Send a message via MSN to dragginwagon406 Send a message via Yahoo to dragginwagon406
Interesting debate in my mind...
Stick with the 2.56 12 bolt in my MC or change to 2.73 (I have a second 12 bolt with 2.73, and it is free) or look for a 3-Series carrier and pick up a 3.08?
The more I think about it, the more I'm inclined to stay with the 2.56.
So hear me out...
Car is very nice, my goal is at most an 11.50-12.00s cruiser with as conservative package as possible. If it ends up running 13.50 at first, so be it, but is it possible to have your cake and eat it too? Near stock stall and highway gears, at 4300 lbs?
Anyhow, the debate between 2.56 vs 2.73 vs. 3.08
Based on:
2.56 (rear gear) working with 1.52 (2nd gear)
117 mph @ 5700 rpm,
124 mph @ 6000 rpm
1911 rpm at 60 mph - cruising speed
2549 rpm at 80 mph - highway speed
5569 rpm @ 115 mph - hopeful 1/4 mile trap speed, finishing in 2nd gear
2.73 (rear gear) working with 1.52 (2nd gear)
110 mph @ 5700 rpm
116 mph @ 6000 rpm
2038 rpm at 60 mph - cruising speed
2718 rpm at 80 mph - highway speed
5939 rpm @ 115 mph - hopeful 1/4 mile trap speed, 2nd gear
3.08 (rear gear) working with 1.52 (2nd gear)
103 mph @ 5700 rpm
98 mph @ 6000 rpm
2300 rpm at 60 mph - cruising speed
3066 rpm at 80 mph - highway speed
6700 rpm @ 115 mph - hopeful 1/4 mile trap speed, 2nd gear
4408 rpm @ 115 mph - hopeful 1/4 mile trap speed, drive gear
I'm inclined to go no deeper than 2.73, because of the highway cruising rpm. As little difference as switching to 2.73 would appear to make, it seems sticking with 2.56 would make sense.
I don't plan on an engine capable of 6700 rpm in this car, and shifting to Drive with the 3.08 will kill power at the end of the track.
I'm thinking a big stroker, conservative cam, good working heads, and my goal is achieved with 6000 rpm shift points. This makes sense if you can get off the line with prodigious amounts of torque.
Kudos to anyone willing to read this babble and comment.
1981 Malibu wagon
406/350/4.10
Best ET NA 12.20 @ 110
Best ET w/N2O 11.47 @ 117
dragginwagon406 is offline
post #2 of 29 (permalink) Old Sep 11th, 19, 10:33 PM
Re: 2.56 vs. 2.73 vs. 3.08
You are going to find with the torque of the BBC that changing gear will not help that much, I switched my 2.56's out for 3.42's back in the day the car did not feel that much faster or quicker being mine was a big torque engine only pulling 5K . A new converter will make a bigger difference. While I think 12.0 is possible with what you have, 11.50's will take a lot more effort with 4300 lbs. Think of 2.56's like a power glide only with a more aggressive 1st gear. You will most likely go through just before the end of the 1/4 shifting into 3rd.
Hotwire and dragginwagon406 like this.
68Chevele is offline
post #3 of 29 (permalink) Old Sep 11th, 19, 10:35 PM
I don't see much difference in all three to be honest...
There was a guy locally that ran a 327 with about 375 horse with a 3 speed manual and 3:08 rear gears....this is back in the early 90's.....car was lowered and it would shoot sparks off the asphalt at night between shifts.....was very quick.....not body every out ran this guy on the street to my knowledge.
dragginwagon406 likes this.
Aaron is offline
post #4 of 29 (permalink) Old Sep 11th, 19, 11:04 PM
George
I went from 3:31 to 3:90 in my Chevelle with the 355 in it. It ran 12.90ís @104-05 before the switch. Just shifting into drive at the 1/4 mile stripe...after the switch it ran 12.90í[email protected] I was crossing the stripe at 5900/6000 in drive.
So no difference in et or mph, but being able to use all three gears.
The 454 wagon I have has a 700r4 /stock stall and 3:73 gears. It cruises at 2000rpm @62 mph. It has alittle giddy-up but no idea what it would run.
'71 Malibu
355 [email protected]
125 [email protected]
100 shot [email protected]
Geo71 is offline
post #5 of 29 (permalink) Old Sep 11th, 19, 11:21 PM Thread Starter
Not sure what that means...other than that was a healthy 355. What were the details? Stall?
1981 Malibu wagon
406/350/4.10
post #6 of 29 (permalink) Old Sep 11th, 19, 11:43 PM
Here is one I had in the race car. I have 4.10 gears in it and replaced them with 4.88's, guess what the car ran?, the same ET 11.42 at the time. Did not pick up anything, waste of money on that one.
post #7 of 29 (permalink) Old Sep 11th, 19, 11:52 PM Thread Starter
It's really hard to go wrong with a 4.10 for the quarter mile...unless the engine makes too much torque, or you like to drive on the highway.
1981 Malibu wagon
406/350/4.10
post #8 of 29 (permalink) Old Sep 11th, 19, 11:53 PM
George
It was nothing special:
9.7:1 Edelbrock Performer RPM heads and intake, Clay Smith Hyd roller 221/235 .516 lift. 1-5/8 headers into 2-1/2Ē exhaust.
The converter stall did change from 4000 with 3:31 to 3800 with 3:90ís.
We thought it might pick up something, but no real difference...still running the 3:90ís now.
'71 Malibu
Geo71 is offline
post #9 of 29 (permalink) Old Sep 12th, 19, 12:09 AM Thread Starter
Some inspiration:
https://www.chevelles.com/forums/155...ack-wow-2.html
12.985 @108.72 with 2.56 and stock stall.
The motor is a 454 .030 over, 781s with 2.19/1.88 valves, .133 dome KB pistons, 286H Isky hydraulic cam (.510/.510 224/234), edelbrock RPM Air Gap, and a Quick Fuel 750 carb.
9.3 or somewhere around there when we were planning out the motor. The package dynoed 435 hp @5500 and 506 lb/ft @ 4300 with the carb straight out of the box.
1981 Malibu wagon
406/350/4.10
post #10 of 29 (permalink) Old Sep 12th, 19, 9:12 AM
I have a 69 el Camino with a 454/Turbo 400 and non posi, ten bolt 2:73. I like everything about it. I wonder if having this ratio lets the stator multiply torque higher. I'd like to find a non posi 12 bolt 2:73...
If you want to sell the 2.73, let me know, I'm in Pittsburgh.. Thanks..
hydro462 is offline
post #11 of 29 (permalink) Old Sep 12th, 19, 9:25 AM
Claude
I find that 3:55 or 3:73's are ideal for most street use.
Claude.
Kirk's67SS likes this.
1971 Chevelle SS
toofastforyou is offline
post #12 of 29 (permalink) Old Sep 12th, 19, 9:31 AM
If you don't find anything let me know in a few weeks, I'll be home then.
hydro462 likes this.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is online now
post #13 of 29 (permalink) Old Sep 12th, 19, 9:36 AM
Thank you.. I'm in no hurry... I'd love to get a 12 bolt under there though..
hydro462 is offline
post #14 of 29 (permalink) Old Sep 12th, 19, 9:54 AM
I know thereís a lot of opinion and anecdotal evidence posted here and I mean no disrespect with my response. I donít see how a 20% increase in torque could not improve ET significantly.
I had a 70 SS 396 with a fresh stock engine, t400 and 3.31 gears. I wanted to drive it more easily at 70 highway speeds so changed the rear to a 2.73. It was definitely less snappy.
I also had a Ď71 El Camino with a hopped up LS3 (MKIV) and changed it from a 3.08 to a 2.55 (10 bolt) and it was a resultant dog to drive.
Without an overdrive, I think a 3.08 is the perfect rear gear ratio for highway driving. I have one in a box waiting for my next project.
Originally Posted by Jordan Peterson
The motivation that drives the commission of the worst human atrocities is an inevitable social consequence of the refusal of the self conscience individual to make the sacrifices appropriate to establishing a harmonious life and their consequent degeneration into a kind of murderous and resentment filled rage propagating endlessly through its variations in society until everything comes to an end.
Alan F is offline
post #15 of 29 (permalink) Old Sep 12th, 19, 7:38 PM
Originally Posted by Alan F View Post
I know there’s a lot of opinion and anecdotal evidence posted here and I mean no disrespect with my response. I don’t see how a 20% increase in torque could not improve ET significantly.
I also had a ‘71 El Camino with a hopped up LS3 (MKIV) and changed it from a 3.08 to a 2.55 (10 bolt) and it was a resultant dog to drive.
I’m a little confused how a well matched gear produced similar times as well but can reason that lack of improvement with, what appears to be better gearing, comes down to one thing - average power applied over the 1/4 mile. This could be lack or traction at the beginning or lack of rpm at the end.
Now my babbling in my initial post becomes clear...I believe with enough torque (or converter), the 2.56, or possibly 2.73, is better than 3.08 since you can finish the 1/4 without shifting to drive, and dropping the engine out out it’s peak horsepower range. This fact will increase the average lower applied over the course of the 1/4 mile.
The bonus of the 2.56 gears is better highway manners.
Proving every day hindsight is 20/20.
Dragginwagon467 is offline
