Time for an engine rebuild! - Chevelle Tech
 30Likes
post #1 of 49 (permalink) Old Aug 30th, 19, 2:05 AM Thread Starter
Iím rebuilding my 496. It had rectangular port Chevy heads, mechanical roller cam, Crower crank & rods and Wiseco pistons. I originally built it in about 1988, itís a four bolt 445 block. This motor dynoed at 598hp and 592tq on pump super, it was all over by 5500 RPM. An original Crower lifter, from before they started putting wheel lube holes in them broke. Of course the engine needed to be torn down to get out all the junk. There wasnít much and the filter was clean but I didn't want to chance damaging the crank. It wasnít, itís perfect.
Iím having the custom Bullet cam re-ground for hydraulic lifters, itíll have .650 lift. Heads will be oval port Brodix. Lifters will be Isky needle free bushing lifters.
My machinist, Glenn at B&B Machine in Oceanside N.Y. is running the block through the washer, doing a clean-up hone, installing cam bearings and fitting new rings. A Shumann oil pump, new bearings, timing chain, gaskets-this will be about the 15th engine Iím building. While I was pretty happy with itís power before, Iím told that I should pick up 80hp with the modern heads, Iíll be happy with 50.
ID:	601854   Click image for larger version
Name:	On hoist.jpg
ID:	601856   Click image for larger version
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is offline
post #2 of 49 (permalink) Old Aug 30th, 19, 7:35 AM
Marcus
Re: Time for an engine rebuild!
Sounds like a nice combo!
Race rites?
What intake?
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
57 3/4Ē wide 12 bolt: Eaton posi, Us gear 3.31, Toms KA 33 splines axles
Malibu ss 64 is offline
post #3 of 49 (permalink) Old Aug 30th, 19, 9:28 AM Thread Starter
yessir, Race Rites.
Every component in this resulted from conversations with their makers.
I'm even replacing my headers, the current ones are Hooker SC Chevelle headers, modified by George Kryssing (Papa Kook) back in the day to fit better. ARH has a 2" x 3" Monte Carlo specific stainless header.
71350SS and dragginwagon406 like this.
How may I help you?
1999 Trans Am-500hp
post #4 of 49 (permalink) Old Aug 30th, 19, 9:32 AM
Jarad
Sounds like a nice combo. Should be a tire fryer.
Sent from my SAMSUNG-SM-N920A using Tapatalk
dragginwagon406 likes this.
72 Slovelle
555 Pump Gas BBC
Best so far:
5.87-118.52 MPH
JBoggs is offline
post #5 of 49 (permalink) Old Aug 30th, 19, 9:38 AM
Nice Build! Post some pics when you get it done!!!!
DragRac69 and dragginwagon406 like this.
ZEN357 is offline
post #6 of 49 (permalink) Old Aug 30th, 19, 10:00 AM
Good to hear Glenn is still at it. My dad raced with Glenn and Henry back in the 80ís and they did a couple engines for me in the mid 90ís. I think I last saw Henry maybe 5 years ago.
Ray
bracketchev1221 is online now
post #7 of 49 (permalink) Old Aug 30th, 19, 10:06 AM
Lew
And you will loose about 70 pounds from the front with the Brodix heads. I think you will also like not having to adjust the valves. Should be a good build keep us posted.
Lew540 is offline
post #8 of 49 (permalink) Old Aug 30th, 19, 10:22 AM
Beth
650+ HP in a beautiful Monte !
NICE
nashville beth is offline
post #9 of 49 (permalink) Old Aug 30th, 19, 10:57 AM Thread Starter
Yeah, they're both still at it.
Glenn is running a third gen Camaro and Henry is still welding and grinding ports, he'll do some port matching for this project.
How may I help you?
1999 Trans Am-500hp
post #10 of 49 (permalink) Old Aug 30th, 19, 10:58 AM Thread Starter
Hey Lew, the heads I've removed were aluminum.
NICE
Thanks!
How may I help you?
1999 Trans Am-500hp
post #11 of 49 (permalink) Old Sep 7th, 19, 2:07 AM Thread Starter
Small update, the Brodix oval port heads are 270cc intake ports then they jump to 332cc. 270 is a bit too small for my engine and 332 is a bit too big, I'm shooting for 300cc.
AFR has a 300cc oval port head that's CNC ported. It's a bit more money but it's right where my engine needs it. And with a little less cc in the chamber should put my compression ratio a hair below 11:1. Perfect.
How may I help you?
1999 Trans Am-500hp
post #12 of 49 (permalink) Old Sep 7th, 19, 2:16 AM
Kerry
Scott Foxwell says the 300cc oval ports have turbulence in the port. The 290’s flow enough to make 700 hp and make better power from what I understand. Don’t get hung up on the port size as much as size/flow. Also what rpm do you want peak power?
I would also look at a different piston with a modern ring pack, like the Mahle power pack pistons.
paul bell likes this.
pockets is offline
post #13 of 49 (permalink) Old Sep 7th, 19, 7:54 AM
Send a message via AIM to dragginwagon406 Send a message via MSN to dragginwagon406 Send a message via Yahoo to dragginwagon406
Originally Posted by paul bell View Post
yessir, Race Rites.
I just installed the Hooker SC 2455 on my '70, the driver's side rubs the steering column depending on throttle position. I suspect you noticed the same thing on your '71. I'd love to hear what you find on the ARH as they are very pricey but claim they are specific for Monte Carlo.
1981 Malibu wagon
406/350/4.10
Best ET NA 12.20 @ 110
Best ET w/N2O 11.47 @ 117
dragginwagon406 is online now
post #14 of 49 (permalink) Old Sep 7th, 19, 10:08 AM
What are the heads youíre taking off?
Ray
post #15 of 49 (permalink) Old Sep 7th, 19, 10:16 AM Thread Starter
Originally Posted by pockets View Post
Scott Foxwell says the 300cc oval ports have turbulence in the port. The 290ís flow enough to make 700 hp and make better power from what I understand. Donít get hung up on the port size as much as size/flow. Also what rpm do you want peak power?
Turbulence in the port, eh? OK, I'll look into the 290cc head. 700HP? That'd be nice.
It's been a lot of years since I had the header work done, I don't remember why modifications were needed.
And yes, the AHR headers are expensive, they better be perfect in every way with good ground clearance and access to spark plugs.
How may I help you?
1999 Trans Am-500hp
